Linksys EZXS-55W 5-Port 10/100 Switch
#2
4.5
based on 39 reviews
from $19.95 - $24.99
Ratings Distribution
5 star
62
4 star
30
3 star
2
2 star
1
1 star
2
Category Average
4.1
More Images
Pros
  • Easy setup (63)
  • Reliable (47)
  • Small (47)
  • Fast (40)
  • Easily expanded (26)
  • Affordabe (1)
  • Easy to install (1)
  • Low cost great product (1)
See less See more
Cons
  • Unreliable (2)
  • Can't add wep (1)
  • I can't find anything (1)
  • Incompatible (1)
  • Rubber feet feel off (1)
  • Too light (1)
Best Uses
  • Home (46)
  • Small networks (43)
  • Desktop (29)
  • Larger networks (4)
  • Rack mounted (1)
  • Temporary networks (1)
Provided by MAGo Enterprise
The EtherFast 10/100 5-Port Switch migrates your network to the power of Fast Ethernet and boosts your network performance all at once providing you with the easiest and most versatile upgrade. MODEL- EZXS55WVENDOR- LINKSYS FEATURES- EtherFast 10/100 Dual-Speed 5-Port Workgroup Switch 5 10/100Mbps ports which autosense full and half duplex transfermodes allowing your network to run speeds of 10Mbps 20Mbps 100Mbps and even an incredible 200Mbps! Switched Uplink Port for easy expansion and maximum scalability. Eliminating data bottlenecks to increase network efficiency theSwitch surges every port with dedicated bandwidth and its auto-partitioned ports shield your PCs from downed network lines.* NWAY Technology detects cabling type speed and duplex operation. * Connect File Servers and key users directly to the Switch to improve bandwidth and access times.* Advanced Store-and-Forward Packet Switching. * Auto-Partitioning protects PCs from downed network lines. * Preamble Regeneration and Incoming Frame Retiming. * Extensive VLSI/SMT hardware support for reliability. * Compact footprint for desktop use. STANDARD(s)- IEEE 802.3 802.3u PROTOCOL - CSMA/CD CONNECTORS - ( 5) 10BaseT/100BaseTX/RJ45 ports( 1) shared uplink port MAC ADDRESSES - 1032 Unicast Table Entries and Unlimited Multicast Broadcast Entries. FRAME SIZE - Max. 1536 bytes BUFFER MEMORY - 1 MBINDICATORs - Power Link/Activity Full Duplex Collision 100Mbps APPROVALS - FCC B CE POWER- External AC Adapter 3.3v DC 300mA SIZE - 7..25w x 2.5h x 6.0d WT.- 16.9 ounces
Specification Description
Model 10273676, EZXS55W, NP111AA#ABA
UPC 745883549030
#per pack 1
Accessory Indicator Yes
Auto Sensing Yes
Benefits 5 Port 10/100 auto-sensing ports with both half and full duplex modesPerfect for integrating your 10BaseT and 100BaseTX network hardw
Capacity UOM mAh
Compliant Standards IEEE 802.3, IEEE 802.3u
Country Of Origin China
Data Link Protocol CSMA/CD
Description Header Switch to a faster network.
Display Catalog Number 55028256
Enclosure Color Blue
Humidity Range Operating 10-85%
Included in the Box EtherFast 10/100 5-Port workgroup switchAC adapterUser guide
Inputs 5 x RJ45(10/100 Fast Ethernet), 1 x RJ45(Shared uplink)
Manufacturer Labor Warranty 5
Manufacturer Part Number EZXS55W
Manufacturer Parts Warranty 5
MAP Price 0.0
Max Operating Temperature 122 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model EZXS55W
Networking Fast Ethernet
Networking Compliant Standards 802.3, 802.3u, 802.3x
Operating Temperature UOM ° F
Outputs 5 x RJ45(10/100 Fast Ethernet), 1 x RJ45(Shared uplink)
PC Interface Supported Windows
Power Device AC adapter included
Product Depth 3.4
Product Dimensions UOM inches
Product Height 1.25
Product Type Switches
Product Weight 12
Product Weight UOM ounces
Product Width 4.4
Supported Languages English
Voltage Required 7.5VDC, 700mA
Linksys EZXS-55W 5-Port 10/100 Switch Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
Linksys EZXS-55W 5-Port 10/100 Switch Reviews
Most helpful positive review
Most helpful negative review
5.0
Simple, as it should be
"I purchased this switch to use in a small office that needed some additional Ethernet ports beyond those that were on the Wireless DSL router. I was able to set up the product in 5 minutes, including reading the instructions. All of the ports are auto-sensing and will adapt to the protocol used by the device on the other end of the cable. You can't connect cables to the wrong port, because none of the ports are..." Read Full Review »
Sep 09, 2009 by Geoff the IT evangelist
See more positive Linksys EZXS-55W 5-Port 10/100 Switch reviews
1.0
Watch out, this is a "Workgroup Switch"
"I wanted a dumb switch. This unit has the characteristics of a HUB. I wanted to spread my cable modem to ethernet unit aroud the house. The computers work, the wireless Router works, but the new Dishnetwork Satelite Recievers would not. The key I should have seen was the total of 6 RJ45 ports on the back. Could not get any info as to why it would not work. When I put a dumb switch in it's place, 5 RJ45 ports on ..." Read Full Review »
Jun 12, 2009 by JJB66
See more negative Linksys EZXS-55W 5-Port 10/100 Switch reviews
Displaying 1 - 5 of 39 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
Very easy, very good!!!
5.0
    Pros
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • None
    Best Uses
  • Home
  • Small Networks
"I had a hub in the home office network to separate a business computer behind a hardware firewall from another machine for general usage. I was experiencing lots of network hangups. When I researched the hub I found that a switch is a much better choice. This little item is perfect, it's about the s …"  Read Full Review »
Was this Networking Hub & Switch review on the Linksys EZXS-55W 5-Port 10/100 Switch helpful to you?
 Report Abuse  (2)  (0)  0 comments
Mar 31 2009
Max the Tech
West Hills, CA
I am:
  • High bandwidth user
Reviewed at:
Price: $24.99
Small and easy to install
4.0
    Pros
  • Easy To Set Up
  • Fast
  • Small
    Cons
  • None
    Best Uses
  • Home
  • Small Networks
"Used to extend current home network. Not the same housing as advertised but does not really matter as long as the unit works. Adverstised unit has blue front housing, the unit I received is plain and all black. Perhaps an older model. "
Sep 3 2009
Dennis
Alexandria, VA
I am:
Reviewed at:
Price: $24.99
1.0
"I wanted a dumb switch. This unit has the characteristics of a HUB. I wanted to spread my cable modem to ethernet unit aroud the house. The computers work, the wireless Router works, but the new Dishnetwork Satelite Recievers would not. The key I should have seen was the total of 6 RJ45 ports on the …"  Read Full Review »
Jun 12 2009
JJB66
Hampton Roads, VA
Great switch to add extra computers to your router
4.0
"Linksys has long been a leader in Ethernet connections. This is a great little switch that enables me to add 5 more computers to my present 5 port router. So less the one from my 5 port router that runs this little beauty gives me 9 ports total. I tend to like wired connections over wireless any day …"  Read Full Review »
Sep 17 2009
RagenRat
Undisclosed
Reviewed at:
Price: $24.99
mostly great
4.0
"I bought this a while back because in my room, i have two computers, an xbox 360, and a ps2 and i wanted them all online without the hassle of replacing wires. For a while, i only had one computer and my 360 plugged in, i tried getting online and couldn't. All i had to do was switch the ports that t …"  Read Full Review »
Jul 2 2008
JustinS
New York
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
