Linksys CM100 Ethernet Port Cable Modem
#2
4.7
based on 21 reviews
Ratings Distribution
5 star
14
4 star
2
3 star
2
2 star
0
1 star
0
Category Average
3.9
$62.50 - $79.99
from 8 stores
More Images
Pros
  • Easy setup (4)
  • Reliable connection (3)
  • Fast connection (1)
  • Fast connection speed (1)
See less See more
Best Uses
  • Home network (1)
  • Surfing the web (1)
Provided by Dell
Experience the savings of owning your own cable modem! The Linksys Cable Modem is an easy and affordable way to get a blazing fast connection to the Internet - far faster than a dial-up, and without tying up your phone line. The "always on" connection eliminates dial-up wait time and busy signals. Web surfing and your e-mail are instantly available, anytime. And with the extra speed, online gaming is a whole new experience, and download time on big music, video, and other files goes from minutes to seconds. Installation is quick and simple. Connect it directly to any PC with an available USB or Ethernet port, and you're ready to surf the Internet. Or connect it to a Linksys router and share that high-speed Internet access with everyone on your home network. The Linksys CM100 Cable Modem is fully compliant with all industry standards - DOCSIS 1.0, 1.1, and 2.0 - so you know it'll work with any DOCSIS cable Internet service provider. When you own a Linksys Cable Modem, you'll avoid monthly equipment rental charges, and make the most of your high-speed cable Internet connection.
Specification Description
Model CM100
UPC 745883576074
Accessory Indicator Yes
Benefits DOCSIS 1.0, DOCSIS 1.1 Certified, DOCSIS 2.0 Certified, 802.3, 802.3u & USB 1.1 compliantSave the monthly rental fee to your cable pr
Capacity UOM mAh
Compliant Standards DOCSIS 1.0, DOCSIS 1.1 Certified, DOCSIS 2.0 Certified,802.3, 802.3u, USB 1.1
Connections USB (1)RJ-45 Ethernet (1)F connector cable (1)
Country Of Origin China
Description Header Why rent?
Display Catalog Number 55033618
Enclosure Color Black
Humidity Range Operating 10~90%
Included in the Box Cable modemPower adapterUSB cableCAT5 Ethernet network cableUser Guide and USB drivers CD-ROMQuic
Manufacturer Labor Warranty 12
Manufacturer Part Number CM100
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model CM100
Modem Cable modem
Networking Ethernet
Networking Features DOCSIS 1.0, DOCSIS 1.1 Certified, DOCSIS 2.0 Certified, 802.3,802.3u, USB 1.1
Operating Temperature UOM ° F
PC Interface Supported USB
Power Device AC adapter included
Product Depth 4.8
Product Dimensions UOM inches
Product Disclaimer *Internet service subscription required from your cable service provider, not included.
Product Height 1.1
Product Type Digital
Product Weight 7.9
Product Weight UOM ounces
Product Width 4.8
Required to function Windows 98SE, Me, 2000, or XP with USB portComputer with 10/100 RJ-45 Ethernet network adapterCD-ROM driveDOCSIS 1.
Supported Languages English
Linksys CM100 Ethernet Port Cable Modem Questions
Questions and Answers
Where to Buy
$62.50
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$65.99
$69.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
Show all 8 stores
Product Reviews
Last update: Oct 17, 2009
Linksys CM100 Ethernet Port Cable Modem Reviews
Most helpful positive review
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Amazing Speed Increase
"Not sure I would attribute to this modem specifically, but since I upgraded from an older Linksys BEFsomething, my speeds have been amazing.Using [@] (which is free and recommended, by the way) I went from 3 Mbps up and 1 Mbp down to 25 Mbps and 10 Mbps, respectively. I use Comcast.I think it's a matter of my old modem not supporting the new standards DOCSIS 2.0 and the new one doing so.In any case, best [$] I'..." Read Full Review »
Nov 09, 2008 by Davzillions
See more positive Linksys CM100 Ethernet Port Cable Modem reviews
3.0
I purchased this product ...
"I purchased this product back in August of 08. I've been having performance issues with my cable internet suppose to be running at 16mbs, never really achieved those speeds. Then finally I keeped loosing internet connection then it quit totally. It turns out the modem had failed. Replaced it with the motorola surfboard sb5010. Oh my God, What a difference!!!. I had modem speeds, downloading speeds exceeding 20mb..." Read Full Review »
Jun 02, 2009 by jackal
See more negative Linksys CM100 Ethernet Port Cable Modem reviews
Displaying 1 - 5 of 21 Reviews
Show
Sort by
5.0
    Pros
  • Easy To Setup
  • Fast Connection Speed
    Cons
  • None
    Best Uses
  • Home network
"Not sure I would attribute to this modem specifically, but since I upgraded from an older Linksys BEFsomething, my speeds have been amazing.Using [@] (which is free and recommended, by the way) I went from 3 Mbps up and 1 Mbp down to 25 Mbps and 10 Mbps, respectively. I use Comcast.I think it's a m …"  Read Full Review »
Was this Computer Modem review on the Linksys CM100 Ethernet Port Cable Modem helpful to you?
Nov 9 2008
San Francisco, CA
I am:
  • high bandwidth user
Excellent Cable Modem
5.0
"I've had about 8 SurfBoard modems from my cable company in the last 2 years. When my latest one gave up the goat on a weekend, I went to Best Buy and picked this on up. I noticed only about a 5%-10% increase in up and down speeds, but reliability has been absolutely superb. I'm using Entouch in the …"  Read Full Review »
Nov 16 2009
TroyS
Katy, TX
Reviewed at:
Price: $79.99
Pluug and play with typical Linksys quality.
5.0
"Product Uses:Connecting with Friends, Finances
Review:Plugged it. called the my cable ISP to recognize it and I was off to the races. My four year old Motorala was beginning to freeze and all my other network hardware is Linksys, so I decided to go with this unit. Not that therte is anything wrong …"  Read Full Review »
Oct 17 2009
CraigWS
Undisclosed
Reviewed at:
Price: $65.99
[2 of 2 customers found this review helpful]
Great Upgrade
5.0
"I am using this with the cable company service Time Warner. This replaced a venerable 2 year old Motorola which I thought was performing well...but suffered signal drop out during video streaming (Hulu.com). The Linksys CM 100 power supply is a high quality "Green", type. Installation and provisioni …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Aug 10 2008
HDheaven
Undisclosed
Reviewed at:
Price: $79.99
It works great!
5.0
    Pros
  • Easy To Setup
  • Reliable Connection
    Cons
  • None
    Best Uses
  • Surfing The Web
"I got it to replace my old Motorola cable modem. I plugged it in, called my provider to change the MAC address and that was it. It does what it is supposed to flawlessly. "
Aug 10 2009
Gabe
Seattle, WA
I am:
  • Value Oriented
Reviewed at:
Price: $62.50
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$62.50
$65.99
$69.99
$69.99
$1.99 Shipping on Orders Over $75 ends 12/31/09
$72.99
$72.99
$79.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$79.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
