Libec LS38M(2A) Tripod System with T72 Tripod, H38 Fluid Head, PH-3 Pan Handle, MS-2 Spreader & TC-60 Case, Supports 17.6 lbs
#326
4.3
based on 10 reviews
from $639.95 - $649.95
Ratings Distribution
5 star
3
4 star
7
3 star
0
2 star
0
1 star
0
Category Average
4.4
Low Price:
$639.95 at Adorama
 Trusted:
$649.95 at B&H Photo Video
Find it at Amazon
More Images
Pros
  • Easily adjusted (4)
  • Good stability (4)
  • Smooth movement (4)
  • Lightweight (3)
  • Locks in tight (3)
  • Rugged (2)
  • Unfolds quickly (2)
  • Folds small (1)
  • Good footing (1)
  • Quick and easy to setup (1)
See less See more
Cons
  • Heavy / bulky (1)
  • Jerky movement (1)
  • No drag controls (1)
  • No variable pan drag (1)
Best Uses
  • Stabilization (4)
  • Special events (3)
  • Home (2)
  • Office (2)
  • Everything (1)
  • Field productions video (1)
  • Filmmaking (1)
  • Long exposures (1)
  • Looking professional (1)
  • Movies (1)
Provided by B&H Photo Video
LS-38M(2A) Professional Tripod System
Specification Description
Model LS38M2A
Maximum Capacity 10 To 19.9 Lbs
Maximum Height 60" to 72"
Select Aluminum
Libec LS38M(2A) Tripod System with T72 Tripod, H38 Fluid Head, PH-3 Pan Handle, MS-2 Spreader & TC-60 Case, Supports 17.6 lbs Questions
Questions and Answers
Where to Buy
$649.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$639.95
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Nov 2, 2009
Libec LS38M(2A) Tripod System with T72 Tripod, H38 Fluid Head, PH-3 Pan Handle, MS-2 Spreader & TC-60 Case, Supports 17.6 lbs Reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
So you like smooth Pans?
5.0
    Pros
  • Good Stability
  • Lightweight
    Cons
  • None
    Best Uses
  • Movies
  • Stabilization
"This tripod and fluid head is used daily in documentaries and indie films. I am very pleased with it because it has a very smooth drag and locks into place without any troubles.
The unit is lightweight yet strong enough to hold my HD camera with the Mini 35 adapter kit with no trouble at all. T …"  Read Full Review »
Was this Tripod Leg review on the Libec LS38M(2A) Tripod System with T72 Tripod, H38 Fluid Head, PH-3 Pan Handle, MS-2 Spreader & TC-60 Case, Supports 17.6 lbs helpful to you?
 Report Abuse  (2)  (0)  0 comments
Apr 30 2008
Benny
El Paso, TX
I am:
  • Film Professional
Reviewed at:
Price: $649.95
Great tripod , better than the Bogen
4.0
    Pros
  • Good Stability
  • Unfolds Quickly
    Cons
  • None
    Best Uses
  • None
"After have a Bogen/ Manfrotto 503 head for a year. I was told by a friend to check this out.
What back drift? it doesn't exist on this tripod. Not like the Bogen 503 or 501 heads.
Good payload, I use it with a 35mm adapter and a Sony EX1 without any problems. Still pretty smooth while pannin …"  Read Full Review »
Nov 2 2009
george
L.A
I am:
  • Pro Photographer
Reviewed at:
Price: $649.95
Solid Tripod all around.
4.0
    Pros
  • Good Stability
    Cons
    Best Uses
  • Long Exposures
  • Looking Professional
  • Stabilization
"I needed a semi pro tripod to support my slider and camera. This tripod did not disappoint. It's got great stability -no twist at all, and the ball head is easy to level.
The only con is no variable pan dra, but it's butter smooth as is.
I've noticed that when this is on one's shoulder, they d …"  Read Full Review »
Sep 10 2009
SunnySideDown
Oakland, CA
I am:
  • Photo Enthusiast
Reviewed at:
Price: $649.95
Great Affordable Tripod
5.0
    Pros
  • None
    Cons
  • None
    Best Uses
  • Stabilization
"My office owns a few Sachtler & Manfrotto tripods at close to twice the cost and I gotta say this is a deal. Well made, not too heavy, smooth head. Comes with a weird elastic band built in to one of the legs that i had to remove cause it was annoying. The only drawback is initially I kept pinching m …"  Read Full Review »
Oct 26 2009
Damian
Chicago, IL
I am:
  • Pro Photographer
Reviewed at:
Price: $649.95
Great quality for an even greater price
4.0
    Pros
  • Easily Adjusted
  • Locks In Tight
  • Rugged
  • Smooth Movement
    Cons
  • Jerky Movement
    Best Uses
  • Home
  • Office
  • Special Events
  • Sports
  • Travel
"Great product for a good price. Even though it's a heavy tripod the footing on it isn't all that great. It does pan and tilt just fine on the Canon XL2's telephoto settings, but be careful that you don't bump it, but in windy conditions it won't move at all, I'd recommend this product to professiona …"  Read Full Review »
Jun 12 2008
Scott
WI
I am:
  • Professional
Reviewed at:
Price: $649.95
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
