LG 42LG70 42-Inch 1080p 120Hz LCD HDTV
#436
4.4
based on 52 reviews
from $879.99 - $1,329.00
Ratings Distribution
5 star
37
4 star
9
3 star
2
2 star
0
1 star
4
Category Average
4.4
Low Price:
$879.99 at All American Direct
 Trusted:
$1,329.00 at Rainbow Appliance
Find it at Amazon
More Images
Pros
  • Fast setup (1)
  • Good connection options (1)
  • Great picture quality (1)
  • High resolution (1)
  • Simple controls (1)
  • Wide viewing angle (1)
See less See more
Best Uses
  • Movies (1)
  • Video (1)
Provided by OneCall
FULL HD 1080p RESOLUTION
Displays HDTV programs in full 1920 x 1080p resolution for a more detailed picture.
INTELLIGENT SENSOR
Unlike other sensors which can only sense brightness of ambient light, LG`s "Intelligent Sensor" uses 4,096 sensing steps to evaluate its surroundings. Using a sophisticated algorithm, the LG processes picture quality elements including brightness, contrast, color, sharpness and white balance. The result is a picture optimized for it`s surroundings, more pleasing to watch and which can also save up to 50% in power consumption.
24p REAL CINEMA
Hi-def movies run at the 24 frames per second speed that they were originally filmed in, making your home-cinema experience one step closer to a "Real Cinema" experience.
CLEAR VOICE TECHNOLOGY
Automatically enhances and amplifies the sound of human voice frequency range to provide high-quality dialogue when background noise swells.
LG SIMPLINK
Allows for convenient control of other LG SimpLink products using the existing HDMI connection.
Specification Description
Model 42LG70
UPC 719192172975
Analog Audio (1) Rear Output
Analog Audio (1) Side Input
Analog Audio (3) Rear Input
Analog Audio / Video Rear Input
Analog Audio / Video Side Input
Aspect Ratio 16:9
Brightness 500 cd/m2
Compatible Formats 1080i
Compatible Formats 1080p
Compatible Formats 480i
Compatible Formats 480p
Compatible Formats 720p
Component Video (2) Rear Input
Contrast Ratio 40,000:1
DB15 (PC Video) Rear Input
Depth (Inches) 13.5
Energy Star Compliant Yes
HDMI (1) Side Input
HDMI (3) Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 1080p
Height (Inches) 32.4
Optical Rear Output
PC Audio Rear Input
Refresh Frequency 120 Hz
Remote Control Included
Resolution 1920 x 1080
Response Time 4ms
RF Rear Input
RS-232C Rear Input
S-Video Rear Input
Screen Size (inches) 42
Speakers 10 Watts x 2
Speakers Built-in
Stand Included
Stand Swivel
Surround Modes Dolby Digital
Surround Modes SRS TruSurround XT
Tuner ATSC
Tuner NTSC
Tuner QAM
Viewing Angle 178 degrees Horizontal
Viewing Angle 178 degrees Vertical
Wall Mountable VESA Compliant
Wall Mountable Yes
Weight (Pounds) 79.4
Width (Inches) 44.9
LG 42LG70 42-Inch 1080p 120Hz LCD HDTV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 10, 2009
LG 42LG70 42-Inch 1080p 120Hz LCD HDTV Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
[1 of 2 customers found this review helpful]
5.0
Great Choice
"I have had this TV for a week. (After spending months researching the market.) It was a great choice. The picture is excellent, it is jammed packed with great features for the price, and it is very easy to setup and access menus and settings. The outstanding set of features for the price and excellent picture makes it an ideal purchase. If you are looking for a high end flat panel HDTV at a reasonable price, thi..." Read Full Review »
Sep 15, 2008 by AIM2
See more positive LG 42LG70 42-Inch 1080p 120Hz LCD HDTV reviews
1.0
Not a High End tv
"I bought this TV because its a good deal for a high end tv with 120 hz and good contrast. Hooked it up to my ps3 via HDMI and watched Transformers on blu ray. The first thing I notice is the Motion flow (120 hz refresh rate) WoW it looks amazing but then I notice when there is a fast movement on the screen the picture starts to chop up making transformers look more like Twisted Metal it makes the Tv that you jus..." Read Full Review »
Dec 01, 2008 by Anonymous
See more negative LG 42LG70 42-Inch 1080p 120Hz LCD HDTV reviews
Displaying 1 - 5 of 52 Reviews
Show
Sort by
Great Choice
5.0
"I have had this TV for a week. (After spending months researching the market.) It was a great choice. The picture is excellent, it is jammed packed with great features for the price, and it is very easy to setup and access menus and settings. The outstanding set of features for the price and excelle …"  Read Full Review »
Was this LCD TV review on the LG 42LG70 42-Inch 1080p 120Hz LCD HDTV helpful to you?
 Report Abuse  (5)  (0)  0 comments
Sep 15 2008
AIM2
Washinton, DC Metro Area
Reviewed at:
[2 of 2 customers found this review helpful]
best HD tv around
5.0
"After spending weeks researching HD tvs, narrowing it down to several different brands and models, I bought this LG ( the 42LG70 ). I didn't find much information at all about this tv, but I really liked what I saw, so I went with this one. I literally could not be any happier with it. The picture b …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Sep 16 2008
Googs
United States
Reviewed at:
LG 42" 1080p 120hz HDTV is a good one.
4.0
"This LG42 120hz HDTV is a good one. The picture quality is great and the price was good at Best Buy. When you select surround sound with it's internal speakers, it causes vibration noises. Running it through an external amp takes that problem away but the manufacturer needs to improve the internal s …"  Read Full Review »
Feb 28 2009
Lynchburg, VA
Reviewed at:
[1 of 1 customers found this review helpful]
Great TV, but...
4.0
"I'm going to start this review with the negative points. I had to give the overall rating a 4 because of the mechanical issues I had. There are 4 total HDMI inputs on this TV and 3 of them DIDN'T WORK!!!! After making all the connections and getting my PS3 hooked up and selecting the appropriate HDM …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Dec 4 2008
thePalmetto
Abilene, TX
Reviewed at:
LG vs. Samsung
5.0
"I did a lot of research between the Samsung 40" A650 & the 42" LG70 & decided on the Samsung because of the reviews and advice from CC & BB. Brought the Samsung home and spent hours trying to calibrate the tv with advice and info from others on line. Noticed that from about a 45 degree angle the pic …"  Read Full Review »
Feb 12 2009
TWH77
New Orleans, LA
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
