LG 32LG40 32" Flat LCD HDTV with Built In DVD Player
#237
4.7
based on 15 reviews
from $548.99 - $589.99
Ratings Distribution
5 star
11
4 star
3
3 star
1
2 star
0
1 star
0
Category Average
4.4
Low Price:
$548.99 at All American Direct
 Trusted:
$579.00 at Rainbow Appliance
Find it at Amazon
More Images
Pros
  • Attractive design (9)
  • High resolution (9)
  • Great picture quality (8)
  • Fast setup (7)
  • Good connection options (7)
  • Simple controls (6)
  • Wide viewing angle (6)
See less See more
Cons
  • Difficult to use (1)
  • Going from dvd back to tv (1)
Best Uses
  • Bedroom (5)
  • Home (5)
  • Wall mounting (5)
  • Movies (3)
  • Home theater (1)
Provided by HSN
For after sale service, click here. Enjoy maximum entertainment packed into a slim, sleek design. This versatile LG 32" 720p LCD HDTV with Built-In DVD Player features 4 HDMI and 2 component HD inputs for unprecedented connectivity to the latest digital devices, such as Blu-ray and high-end home theater systems. And the built-in side-loading progressive scan DVD player makes the LG 32LG40 an ideal choice for a bedroom, kitchen or any room where space is limited. LG 32" 720p LCD HDTV with Built-In DVD Player Features: Model #: LG 32LG40 Screen Type: LCD HDTV Screen Size: 32" Aspect Ratio: 16:9 widescreen (1366 x 768) Built-in ATSC/NTSC/QAM Clear tuner - receives over-the-air digital signals and unscrambled digital cable channels XD Engine for vivid detail Clear Voice technology - automatically enhances and amplifies human voices above background sounds Additional Features and Specifications: Progressive scan Response Time: 8ms Dynamic Contrast Ratio: 12,000:1 Brightness: 500 cd/m Viewing Angles: 178 horizontal /178 vertical 3D digital comb filter with enhanced noise reduction 3:2 pull-down correction 3 AV modes - optimizes picture and audio in Cinema, Sports or Game mode based on video/audio content 6 aspect ratio modes 7 picture selection modes 4 color temperature control modes "Invisible" speaker system: 2 x 10 watts per channel Dolby Digital Decoder SRS TruSurroundXT 4 EZ sound modes Parental control with V-Chip Closed caption Languages: English, French and Spanish LG SimpLink allows for control through other compatible devices using HDMI Measures approx. 31.8"W x 24.8"H x 11.8" Deep with stand Weighs approx. 36.4 lbs. (with stand) Swivel stand (some assembly required) VESA-compatible (mounting hardware not included) Cabinet Color: Gloss Black Energy Star compliant Made in Mexico Inputs/Outputs: Side: HDMI input, A/V composite input and USB 2.0 (service only) Rear: 3 HDMI/HDCP inputs, 2 component video inputs, S-Video input, RF input (antenna/cable), 3 stereo RCA audio inputs, RCA stereo audio output, 2 digital audio outputs (coaxial and optical), PC input (RGB and audio) and RS-232c interface Accessories Included: 4-in-1 Universal remote control with 2 AAA batteries Cable management clip Hardware for stand assembly Instruction manual (printed and CD)
Specification Description
Model 32LG40, LG 32LG40
UPC 719192172944
Analog Audio Rear Input
Analog Audio Rear Output
Analog Audio Side Input
Aspect Ratio 16:9
Brightness 500 cd/m2
Combo Unit Built-in DVD Player
Component Video Rear Input
Component Video Side Input
Computer Display Capable Yes
Computer Interface VGA
Contrast Ratio 12,000:1
DB15 (PC Video) Rear Input
Depth (Inches) 11.8
Dynamic Contrast Ratio 12000:1
HDMI (2) Rear Input
HDMI 4
HDMI Side Input
HDTV HDTV Tuner Built In
HDTV Capable HD Tuner is included
HDTV Native Resolution 720p
Height (Inches) 24.8
Optical Rear Output
PC Audio Rear Input
Refresh Frequency 60 Hz
Remote Control Included
Resolution 1366 x 768
Response Time 8 ms
RF Rear Input
RS-232C Rear Input
S-Video Rear Input
Screen Format 16:9 Widescreen TV Imaging
Screen Resolution 1366x768
Screen Size 32" Diagonal
Screen Size (inches) 32
Screen Size (Inches/Diagonal) 32
Speakers 10 Watts x 2
Speakers Built-in
Tuner ATSC
Tuner NTSC
Tuner QAM
TV Manufacturer’s Warranty (Labor) 1 Year
TV Manufacturer’s Warranty (Parts) 1 Year
USB Connection Yes
Viewing Angle 178 degrees Horizontal
Viewing Angle 178 degrees Vertical
Wall Mountable Yes
Weight (Pounds) 36.4
Width (Inches) 31.8
LG 32LG40 32" Flat LCD HDTV with Built In DVD Player Questions
Questions and Answers
Where to Buy
$579.00
$589.99
Code SEARS5OFF50 : $5 Off Orders Over $50!
$548.99
Product Reviews
Last update: Sep 15, 2009
LG 32LG40 32" Flat LCD HDTV with Built In DVD Player Reviews
Most helpful positive review
Most helpful negative review
[3 of 3 customers found this review helpful]
5.0
Good price, works well
"Does the job at a good price. Works simply and well. Some idiot designed the remote control and for older people -- me -- it can be a little hard to see the small blue letters against the black, but you quickly learn to remember where they're positioned...." Read Full Review »
Jun 29, 2009 by John
See more positive LG 32LG40 32" Flat LCD HDTV with Built In DVD Player reviews
3.0
Nice picture, lousy base
"Picture looks great and built-in DVD works fine. But the base is not stable, it's hard to switch back from DVD mode to live TV, and at [$] you're paying a big premium for the DVD feature...." Read Full Review »
Aug 15, 2008 by Richie Rios
See more negative LG 32LG40 32" Flat LCD HDTV with Built In DVD Player reviews
Displaying 1 - 5 of 15 Reviews
Show
Sort by
3.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • Difficult to Use
    Best Uses
  • Home
  • Movies
[$] you're paying a big premium for the DVD feature. "
Was this LCD TV review on the LG 32LG40 32" Flat LCD HDTV with Built In DVD Player helpful to you?
 Report Abuse  (3)  (0)  0 comments
Aug 15 2008
Richie Rios
New York City
I am:
  • Tech Savvy
Reviewed at:
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Wall Mounting
"Does the job at a good price. Works simply and well. Some idiot designed the remote control and for older people -- me -- it can be a little hard to see the small blue letters against the black, but you quickly learn to remember where they're positioned. "
Jun 29 2009
John
Pittsburgh
I am:
  • Casual User
Reviewed at:
Teenagers dream TV/DVD
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Wall Mounting
"Definately a television your teenager will be happy with and I wouldn't mind one of my own. One of the most attractive flat screens I've seen yet. Having the DVD built right in just keeps things even simpler.[...] "
Jan 2 2009
Brandy At Hello
Tustin, CA
I am:
  • Enthusiast
Reviewed at:
GREAT TV
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Good Resolution
  • Reduced Glare
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
  • Wall Mounting
"GREAT TV, CLEAR PICTURE AND SOUND, THE ONLY PROBLEM IS DIFFICULT TO SWITCH BACK FROM DVD PLAYER TO TV MODE. "
Sep 15 2009
TV LOVER
BROOKLYN, NY
I am:
  • Casual User
Reviewed at:
[1 of 1 customers found this review helpful]
Everything we were looking for.
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
"Wanted a mid-sized flat screen in bedroom. Built-in DVD a plus. Works fine for us. Would do it again. No regrets. LG puts out a good product! "
 Report Abuse  (1)  (0)  0 comments
Oct 31 2008
CnC
MD Eastern Shore
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
