LG 26LG30 26" 720p LCD HDTV
#412
4.4
based on 36 reviews
Ratings Distribution
5 star
22
4 star
9
3 star
3
2 star
1
1 star
1
Category Average
4.4
$437.00 - $569.00
from 4 stores
More Images
Pros
  • Attractive design (5)
  • Good connection options (5)
  • High resolution (5)
  • Fast setup (4)
  • Great picture quality (4)
  • Simple controls (3)
  • Wide viewing angle (3)
  • Best store comparisons (1)
See less See more
Cons
  • Difficult to set up (1)
  • Poor sound quality (1)
Best Uses
  • Bedroom (2)
  • Home (2)
  • In a college dorm room (1)
  • Movies (1)
Provided by OneCall
HD RESOLUTION
High definition television is the highest performance segment of the DTV system used in the US. It`s a wide screen, high-resolution video image, coupled with multi-channel, compact-disc quality sound.
AV MODE
LG HDTVs include 3 AV Modes, preset to optimize picture and sound settings based on “Cinema", “Sports" or "Game" content. AV Modes can be easily set with a convenient button on the remote control.
CLEAR VOICE TECHNOLOGY
Automatically enhances and amplifies the sound of human voice frequency range to provide high-quality dialogue when background noise swells.
INVISIBLE SPEAKER SYSTEM
LG`s 2008 line of TVs include a unique invisible speaker system, tuned by renowned audio expert, Mr. Mark Levinson. Speakers are embedded in strategic spots behind the front cabinet and use minute vibrations to turn the entire front bezel into the speaker system. The result is a clean, polished look, and enhanced audio by increasing the "sweet spot", giving a wider and richer sound field.
LG SIMPLINK
Allows for convenient control of other LG SimpLink products using the existing HDMI connection.
Specification Description
Model 26LG30
UPC 719192173064
Analog Audio Rear Input
Analog Audio Rear Output
Analog Audio / Video Rear Input
Aspect Ratio 16:9
Brightness 500 cd/m2
Component Video (2) Rear Input
Contrast Ratio 5,000:1
Contrast Ratio 700:1
DB15 (PC Video) Rear Input
Depth (Inches) 9
Energy Star Compliant Yes
HDMI (2) Rear Input
Height (Inches) 20
Optical Rear Output
PC Audio Rear Input
Ports 1 x 15-pin HD-15 VGA In Rear
Refresh Frequency 60 Hz
Remote Control Included
Resolution 1366 x 768
Response Time 6.5ms
RF Rear Input
S-Video Rear Input
Screen Size 21" to 29"
Screen Size 26"
Screen Size (inches) 26
Select LCD Units
Speakers Built-in
Stand Included
Stand Swivel
Standard Warranty 1 Year Limited
Technology HDTV
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port Rear Input
Viewing Angle 178 degrees Horizontal
Viewing Angle 178 degrees Vertical
Wall Mountable VESA Compliant
Wall Mountable Yes
Weight (Pounds) 22.3
Width (Inches) 26.1
LG 26LG30 26" 720p LCD HDTV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 22, 2009
LG 26LG30 26" 720p LCD HDTV Reviews
Most helpful positive review
Most helpful negative review
[2 of 2 customers found this review helpful]
5.0
Nice little HDTV
"This LG was the best unit I could find in this size to fit in a cabinet in my home office. The Sony was a close 2nd and a bit cheaper, but nobody has them in stock. I like the swivel stand of the LG that the Sony lacks. The piano gloss finish is a bit annoying: now my screen doesn't have a glare like my old CRT, the frame around the screen does. It does look sharp, however, and I'll get used to it. As with many ..." Read Full Review »
Jun 14, 2008 by jkdallas
See more positive LG 26LG30 26" 720p LCD HDTV reviews
1.0
Poor Picture
"THE PROS: (1) Connectivity LG, in this 26LG30 model, as in so many of its other models, offers the best connectivity in the HDTV industry. In addition to the usual video inputs, and a multiplicity of them, LG provides these more unusual, but highly useful, features: (a) An RS-232C port for direct connection to, and control by, a PC. [Unfortunately, LG does not yet provide PC software that would make using of thi..." Read Full Review »
Jun 11, 2008 by TechAppreciator
See more negative LG 26LG30 26" 720p LCD HDTV reviews
Displaying 1 - 5 of 36 Reviews
Show
Sort by
Poor Picture
1.0
"THE PROS:
(1) Connectivity
LG, in this 26LG30 model, as in so many of its other models, offers the best connectivity in the HDTV industry. In addition to the usual video inputs, and a multiplicity of them, LG provides these more unusual, but highly useful, features: (a) An RS-232C port for direct co …"  Read Full Review »
Was this LCD TV review on the LG 26LG30 26" 720p LCD HDTV helpful to you?
 Report Abuse  (2)  (0)  0 comments
Jun 11 2008
TechAppreciator
Undisclosed
Reviewed at:
Good, Just Not Great....yet
3.0
"Was tired of reviewing and viewing LCD tv's, so went out and purchased this on a 'just gonna do it' spree. Had to get my feet wet on an LCD HD tv sometime and the original brand I wanted wasn't in stock. This was also on sale at a great price and wouldn't be my first LG product. I also own an LG fro …"  Read Full Review »
Jul 4 2008
SimplyTired
Wisconsin
Reviewed at:
Nice little HDTV
5.0
"This LG was the best unit I could find in this size to fit in a cabinet in my home office. The Sony was a close 2nd and a bit cheaper, but nobody has them in stock. I like the swivel stand of the LG that the Sony lacks. The piano gloss finish is a bit annoying: now my screen doesn't have a glare lik …"  Read Full Review »
Jun 14 2008
jkdallas
Dallas, Texas
Reviewed at:
Great!
5.0
"This is a great tv! I got it right after they came out and couldn't be happier. I was comparing it to the new Samsung 26" and this tv had slightly better brightness and sound.
THIS TV ONLY HAS A 5000:1 CONTRAST RATION, NOT 12000:1 AS THE SPECS ON BESTBUY.COM SAY. See LG's website for accurate specs
Apr 6 2008
mustangz5
Cleveland, OH
Reviewed at:
Solid performance at the price level
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
"Good side to side viewing angle; up and down viewing angle somewhat narrow. Don't care for glossy black surround; personally prefer matt (non-reflective) frame. Base assembles and works well, but can be unstable unless you screw down the base with provided screw. Be sure to do your own color balance …"  Read Full Review »
 Report Abuse  (0)  (0)  1 comment
Sep 28 2008
Runnin' Rob
Alamo, CA
I am:
  • Enthusiast
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
