LG 22" White Class LCD Flat Panel HDTV
#571
4.2
based on 11 reviews
from $299.98
Ratings Distribution
5 star
3
4 star
7
3 star
1
2 star
0
1 star
0
Category Average
4.4
$299.98 at OneCall
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Attractive design (11)
  • Fast setup (8)
  • Great picture quality (7)
  • High resolution (7)
  • Good connection options (6)
  • Simple controls (5)
  • Wide viewing angle (4)
See less See more
Cons
  • Poor sound quality (2)
  • Buttons on top (1)
  • Poor image quality (1)
Best Uses
  • Bedroom (9)
  • Kitchen (2)
  • Wall mounting (2)
  • Medical office (1)
Provided by OneCall
HD RESOLUTION
High definition television is the highest performance segment of the DTV system used in the US. It`s a wide screen, high-resolution video image, coupled with multi-channel, compact-disc quality sound.
AV MODE
LG HDTVs include 3 AV Modes, preset to optimize picture and sound settings based on Cinema, Sports or Game content. AV Modes can be easily set with a convenient button on the remote control.
CLEAR VOICE TECHNOLOGY
Automatically enhances and amplifies the sound of human voice frequency range to provide high-quality dialogue when background noise swells.
INVISIBLE SPEAKER SYSTEM
LG`s 2008 line of TVs include a unique invisible speaker system, tuned by renowned audio expert, Mr. Mark Levinson. Speakers are embedded in strategic spots behind the front cabinet and use minute vibrations to turn the entire front bezel into the speaker system. The result is a clean, polished look, and enhanced audio by increasing the “sweet spot", giving a wider and richer sound field.
EXPERT MODE
Sophisticated and detailed calibrations can be made through the easily accessible Expert Mode. (Up to 25 more fine adjustment points than typical TVs) This allows the user to optimize the picture quality, based on the viewing environment, lighting conditions or type of content.
Specification Description
Model 22LG31
UPC 719192173910
Analog Audio (2) Rear Input
Analog Audio / Video Rear Input
Aspect Ratio 16:9
Brightness 300 cd/m2
Component Video Rear Input
Contrast Ratio 5,000:1
DB15 (PC Video) Rear Input
Depth (Inches) 7.4
Energy Star Compliant Yes
HDMI Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 720p
Height (Inches) 17.0
PC Audio Rear Input
Refresh Frequency 60 Hz
Remote Control Included
Resolution 1680x1050
RF Rear Input
S-Video Rear Input
Screen Size 21" to 29"
Screen Size (inches) 22
Select LCD Units
Speakers 3W x 2
Speakers Built-in
Stand Included
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port Rear Input
Viewing Angle 160 degrees Horizontal
Viewing Angle 160 degrees Vertical
Wall Mountable VESA Compliant
Wall Mountable Yes
Weight (Pounds) 12.4
Width (Inches) 20.6
LG 22" White Class LCD Flat Panel HDTV Questions
Questions and Answers
Where to Buy
$299.98
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Oct 14, 2009
LG 22" White Class LCD Flat Panel HDTV Reviews
Most helpful positive review
Most helpful negative review
4.0
Nice White LCD TV
"Nice LCD with good picture for both TV and PC. Easy to install and configure. I like the hidden speakers which sound good given they are built-ins. The only thing I found frustrating is the control buttons located on the top of the TV. This makes it harder to use when wall mounted...." Read Full Review »
Oct 14, 2009 by Big Al
See more positive LG 22" White Class LCD Flat Panel HDTV reviews
3.0
Good picture - NsoG sound
"Bring the sound out the front...." Read Full Review »
Sep 21, 2009 by geo
See more negative LG 22" White Class LCD Flat Panel HDTV reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
Nice White LCD TV
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Good Connection Options
  • Simple Controls
    Cons
  • Buttons on top
    Best Uses
  • Bedroom
  • Kitchen
  • Medical Office
  • Wall Mounting
"Nice LCD with good picture for both TV and PC. Easy to install and configure. I like the hidden speakers which sound good given they are built-ins. The only thing I found frustrating is the control buttons located on the top of the TV. This makes it harder to use when wall mounted. "
Was this LCD TV review on the LG 22" White Class LCD Flat Panel HDTV helpful to you?
Oct 14 2009
Big Al
Nyack, NY
I am:
  • Power User
Reviewed at:
Price: $299.98
Does the trick
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Kitchen
"T.V. sits nicely on a white wall shelf in the kitchen. Perfect for morning news and weather. Looks great. The picture is most clear from the island and sink area, right where I need to be.
Very happy to find a white flat screen and the size is just right for a kitchen. Good Job. "
Nov 14 2008
starrstuff
NJ
I am:
  • Casual User
Reviewed at:
Price: $299.98
Awesome product
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
    Cons
  • None
    Best Uses
  • Bedroom
"I bought this TV to be used in my extra small bedroom and its a perfect size. The picture is brighter and sharper than my 32" Sony and it cost much less than a comparable Sony. Other than not being able to swivel, its got everything I was looking for. "
Aug 17 2009
Big Bob
Long Island
I am:
  • Enthusiast
Reviewed at:
Price: $299.98
Super little TV
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
"Used mainly by guests but also in conjunction with dvd recorder. Very user friendly. The elegant white frame fits right into the bedroom setting. "
Oct 5 2009
Linda
Venice, Florida
I am:
  • Casual User
Reviewed at:
Price: $299.98
All about the white box
4.0
    Pros
  • Attractive Design
    Cons
  • Dull Image
    Best Uses
  • Bedroom
"bought this for my mom as it seemed the closest to my same size samsung. I think the samsung offers a much better color picture but mom is pleased with her white tv "
Sep 14 2009
glinda
boston
I am:
  • Casual User
Reviewed at:
Price: $299.98
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
