#515
based on 12 reviews
Ratings Distribution
| 5 star |
4 |
| 4 star |
7 |
| 3 star |
0 |
| 2 star |
0 |
| 1 star |
1 |
Category Average
$59.99
from 2 storesWhere to Buy
BizRate Rating
Good 7.9
$59.99 |
at
Home Depot
$59.99 |
Code KMART5OFF50 : Save $5 off $50 with coupon |
at
Kmart
Product Reviews
[3 of 3 customers found this review helpful]
[1 of 1 customers found this review helpful]
"The Level Mount is easy to install and comes with the accessories to fit any 26" to 50" flat panel TV. I installed a 50" plasma TV in less than 30 minutes. The only negative aspect of the Level mount is that the level is slightly off. I went strictly by the level on the unit and the mount was about an inch higher on one side. I checked the mount with another level that I had and it was indeed off. I removed the ..." Read Full Review »
Feb 22, 2009 by BigMike2009
See more positive Level Mount Fixed/Tilt Mount For 26 In.-50 In. TV's reviews
"Does NOT fit all 50" TVs. Did not fit our Panasonic and we had to spend $20 in shipping to send it back...." Read Full Review »
Feb 25, 2009 by FJB1
See more negative Level Mount Fixed/Tilt Mount For 26 In.-50 In. TV's reviews
Displaying 1 - 5 of 12 Reviews
Level Mount Fixed/Tilt Mount For 26 In.-50 In. TV's Review
"The Level Mount is easy to install and comes with the accessories to fit any 26" to 50" flat panel TV. I installed a 50" plasma TV in less than 30 minutes. The only negative aspect of the Level mount is that the level is slightly off. I went strictly by the level on the unit and the mount was about …" Read Full Review »
"Overall a good tv mount. The included stud finder is basically useless. Also the level mounted on the wall plate may not be quite on the mark. I had a level line from another level and it didn't match the built in level. Easy to intall once I found the studs. The wall bolt install method is a little …" Read Full Review »
"My son and I were able to successfuly complete the mounting of our new 22" set on a Masonary Wall, but not without some dfficulty.
Our problem centered around the size of the provided mounting bolts. We finally determined those provided are for mounting on studs not for masonary mounting using the p
Read Full Review »
[2 of 2 customers found this review helpful]
"I don't know what the higher price mounts have but this one had all the components needed to mount. The adjustment for tilting was a little hard to get at after mounting, but tee handle allen wrench works the best. I would recommend this product to anyone that is mounting a 26" to 50" LCD tv. "
"dbaker speaks the truth, the level is totaly useless. Had I gone off of the level provided, the mount would have been off by 23 degrees! Overall, it is a fine mount, you will need a "real" 24" level and it can be mounted to the sheetrock without using the studs by simply buying "HILTI MOUNTING BOLTS …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 7.9
$59.99 |
at
Home Depot
$59.99 |
at
Kmart
Out Of Stock |
BizRate Rating
Good 8.3
$59.99 |
at
Target
BizRate Rating
Good 7.9
$59.99 |
Code SEARS5OFF50 : $5 Off Orders Over $50! |
at
Sears
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
