Lenmar PRO2025 AA Nickel-Metal Hydride Battery
#70
4.5
based on 10 reviews
Ratings Distribution
5 star
6
4 star
4
3 star
1
2 star
0
1 star
0
Category Average
4.3
$39.95 - $54.99
from 6 stores
More Images
Pros
  • Easy to use (4)
  • Reliable (4)
  • Durable (2)
  • Fast recharge (2)
  • Good value (2)
  • Lightweight (2)
  • Long lasting (2)
  • Long-lasting (2)
  • Powerful (2)
  • Charges quickly (1)
See less See more
Cons
  • A little too wide (1)
  • Charges slowly (1)
  • Don't have any cons (1)
  • Heavy / bulky (1)
Best Uses
  • Everyday (2)
  • Macro (2)
  • Portraits (2)
  • Studio (2)
  • Travel (2)
  • Anything with aas (1)
  • Emergency equipment (1)
  • Having around the house (1)
  • Home (1)
  • Landscapes (1)
Provided by Buzzillions.com
Give your digital camera the power it needs with Lenmar's rechargeable Nickel-Metal Hydride batteries. NoMEM technology allows recharging at any time without loss of capacity, so charge anytime you like.
Main Features
  • Manufacturer: Lenmar Enterprises, Inc.
  • Manufacturer Part Number: PRO2025
  • Manufacturer Website Address: http://www.lenmar.com
  • Battery Finder Address: http://www.ritzcamera.com/battery-locator.htm
  • Product Type: AA Battery
  • Battery Chemistry: Nickel-Metal Hydride
  • Battery Capacity: 2500 mAh
  • Battery Voltage: 1.2 V
  • Compatibility
    • Fits: all devices that use AA Batteries
    Specification Description
    Model LENPRO2025, PRO2025
    UPC 029521835618
    Accessory Indicator Yes
    Battery Finder Indicator Yes
    Battery Type Product
    Benefits Fits most devices that require "AA" batteriesDelivers 1.2 volts and a very robust capacity of 2500mAh so they last longer between cha
    Capacity 2500
    Capacity UOM mAh
    Chemistry Ni-MH
    Country Of Origin China
    Description Header Charge and go over and over.
    Display Catalog Number 55030802
    Enclosure Color Blue
    Equivalent to AA Rechargeable Battery, Aiptek DV5100M, Aiptek Fidelity DV3100, Aiptek iCam, Aiptek IS-DV2, Aiptek ISDV2+
    Manufacturer Labor Warranty 90
    Manufacturer Part Number PRO2025
    Manufacturer Parts Warranty 90
    MAP Price 0.0
    Model PRO2025
    Operating Temperature UOM ° F
    Product Diameter 0.5
    Product Dimensions UOM inches
    Product Height 2
    Product Type AA
    Product Weight 1.3
    Product Weight UOM ounces
    Rechargeable Yes
    Recommended Use Acer CI-8330, Agfa ePhoto 1280, Agfa ePhoto 1680, Agfa ePhoto 307, Agfa ePhoto 780, Agfa ePhoto 780C and more
    Size AA
    Supported Languages English
    Voltage 1.2
    Voltage UOM Volts
    Lenmar PRO2025 AA Nickel-Metal Hydride Battery Questions
    Questions and Answers
    Where to Buy
    $39.95
    BizRate Rating Outstanding 9.1
    $49.99
    $10 Off Orders Of Orders Over $85 + Free Shipping
    $54.99
    Shop CameraWorld with FREE Shipping/No Sales Tax! ends 12/31/99
    Show all 6 stores
    Product Reviews
    Last update: Oct 7, 2009
    Lenmar PRO2025 AA Nickel-Metal Hydride Battery Reviews
    Most helpful positive review
    Most helpful negative review
    [1 of 1 customers found this review helpful]
    4.0
    Very good batteries
    "I use these AA batteries for all applications besides in a camera. The 1.2 voltage does not seem to make a difference to the device from the 1.5 of a regular acid or alkali battery. The only annoyance is that these NiMH batteries are slightly wider than traditional batteries and fit tightly in some devices. I would think the design engineers would not have made an error like that. I hope I do not have troubl..." Read Full Review »
    Apr 20, 2009 by gridsleep
    See more positive Lenmar PRO2025 AA Nickel-Metal Hydride Battery reviews
    3.0
    Good battery, oversize diameter
    "Purchased 20 of these about a year ago. Very good value. Have worked well so far with no dead cells or capacity problems that I have noticed. They get used a fair amount and don't sit very long between charges, several weeks at most typically, so I haven't noticed a self discharge issue that affects my useage - multiple speedlights for the most part. They certainly aren't the very low self-discharge version..." Read Full Review »
    Jan 09, 2009 by Bill
    See more negative Lenmar PRO2025 AA Nickel-Metal Hydride Battery reviews
    Displaying 1 - 5 of 10 Reviews
    Show
    Sort by
    3.0
      Pros
    • Durable
    • Easy To Use
    • Lightweight
    • Reliable
      Cons
    • Bulky
      Best Uses
    • None
    "Purchased 20 of these about a year ago. Very good value. Have worked well so far with no dead cells or capacity problems that I have noticed. They get used a fair amount and don't sit very long between charges, several weeks at most typically, so I haven't noticed a self discharge issue that aff …"  Read Full Review »
    Was this Standard Camera Battery review on the Lenmar PRO2025 AA Nickel-Metal Hydride Battery helpful to you?
     Report Abuse  (1)  (0)  0 comments
    Jan 9 2009
    Bill
    Seymour, Indiana
    I am:
    • Semi-Professional
    Reviewed at:
    Price: $39.95
    Very good batteries
    4.0
      Pros
    • Easy to Install
    • Fast Recharge
    • Long-Lasting
    • Reliable
    • Widely Compatible
      Cons
    • A little too wide
      Best Uses
    • None
    "I use these AA batteries for all applications besides in a camera. The 1.2 voltage does not seem to make a difference to the device from the 1.5 of a regular acid or alkali battery. The only annoyance is that these NiMH batteries are slightly wider than traditional batteries and fit tightly in som …"  Read Full Review »
    Apr 20 2009
    gridsleep
    Walden, NY
    Reviewed at:
    Price: $49.99
    I have 80 of them.
    5.0
      Pros
    • Durable
    • Easy To Use
    • Lightweight
    • Reliable
      Cons
    • None
      Best Uses
    • Everyday use
    • Home
    • Landscape Photography
    • Macro Photography
    • Portraits
    • More »
    "Best bang for the buck. I used them in my D300, SB-600, on two SB-800 and on the SD8A battery pack. These batteries in the SB-800 with SD8A battery pack provide instant flash use. I have never had to wait for the flash to recycle during a 4 hour span. They are cheap and are great to use, that's why …"  Read Full Review »
    Feb 20 2009
    Conrad
    Chicago, IL
    I am:
    • Hobbyist/Enthusiast
    Reviewed at:
    Price: $39.95
    Incredible value. Work well.
    5.0
      Pros
    • None
      Cons
    • None
      Best Uses
    • Anything with AAs
    "Given the prices charged for the same battery in smaller packs, or other similar batteries, the price is incredible. The batteries work well. With the _really_ fast charger available elsewhere in the site, they work particularly well. I suggest marking them as sets (numbers, letters, whatever) and k …"  Read Full Review »
    Nov 10 2007
    Underwater Photographer Chocoholic
    NW Mass
    I am:
    • Semi-Professional
    Reviewed at:
    Price: $39.95
    Works as adverstised
    4.0
      Pros
    • Easy To Use
    • Improves Product Function
      Cons
    • None
      Best Uses
    • Macro Photography
    • Portraits
    • Professional
    • Studio
    • Traveling
    "These are very necessary to feed my Speedlite flashes. It is great to have a huge supply of these suckers around for traveling and extended shoots. "
    Jul 10 2007
    jomojo
    Olympia, Wa
    I am:
    • Semi-Professional
    Reviewed at:
    Price: $39.95
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
