Lenmar PAN88 Replacement for Panasonic, 12V 2300mAh SLA
#122
4.0
based on 4 reviews
from $24.95 - $49.00
Ratings Distribution
5 star
3
4 star
0
3 star
0
2 star
0
1 star
1
Category Average
4.3
Low Price:
$24.95 at Adorama
$26.88 at Overstock.com
Find it at Amazon
More Images
Pros
  • Good interface with camcorder (2)
  • Easy to use (1)
  • Fast recharge (1)
  • Quality construction (1)
See less See more
Cons
  • Heavy / bulky (1)
  • Poor fit (1)
Best Uses
  • Home movies (2)
  • Replacement (1)
Provided by CameraWorld.com
Don?t miss a shot due to a dead battery. Lenmar?s high-performance rechargeable Camcorder batteries meet or exceed the original manufacturer?s specifications to give you the maximum shots per charge.
Main Features
  • Manufacturer: Lenmar Enterprises, Inc.
  • Manufacturer Part Number: PAN88
  • Manufacturer Website Address: http://www.lenmar.com
  • Battery Finder Address: http://www.ritzcamera.com/battery-locator.htm
  • Product Type: Camcorder Battery
  • Battery Chemistry: Sealed Lead Acid
  • Battery Capacity: 2300 mAh
  • Battery Voltage: 12 V
  • Compatibility
    • Fits: Panasonic AG-160 Series
    • Replaces: AGBP212, LC-S2312, PV-BP88
  • Warranty: 1 Year
Specification Description
Model PAN-88, PAN88
UPC 029521987652
Accessory Indicator Yes
Battery Average Run Time 2
Battery Average Run Time UOM HOURS
Battery Finder Indicator Yes
Battery Type Product
Benefits Weighs only 1.75 pounds, so it won't bog you down12V 2300mAh battery gives you 2 hours of power, depending on useReplaces Pa
Capacity 2300
Capacity UOM mAh
Chemistry Sealed Lead Acid
Country Of Origin Taiwan
Description Header Power to go.
Display Catalog Number 55019740
Enclosure Color Black
Equivalent to AC Delco ACD401, Aiwa CV800, Audiovox ADX, CTR1900, Canon BP-100, BP-10A, BP-2312, BP-30, BP-30A, BP-31, BP-32, BP-40A, Canon BP-50A, BP-E22, BP-E30A
Manufacturer Labor Warranty 12
Manufacturer Part Number PAN-88
Manufacturer Parts Warranty 12
MAP Price 0.0
Model PAN88
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 2.38
Product Length 0.94
Product Type 12V
Product Weight 1.48
Product Weight UOM pounds
Product Width 7.19
Rechargeable Yes
Size Specialty
Supported Languages English
Voltage 12
Voltage UOM Volts
Lenmar PAN88 Replacement for Panasonic, 12V 2300mAh SLA Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 28, 2009
Lenmar PAN88 Replacement for Panasonic, 12V 2300mAh SLA Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
Excellent Replacement
5.0
    Pros
  • Easy To Use
  • Good Interface With Camcorder
  • Quality Construction
    Cons
  • Heavy
    Best Uses
  • Home Movies
  • Replacement
"Perfect fit for an obsolete 23 year old Montgomery Ward VHS cassette video recorder I inherited. "
Was this Camcorder Battery review on the Lenmar PAN88 Replacement for Panasonic, 12V 2300mAh SLA helpful to you?
May 3 2009
Roadkill439342
Grand Rapids, MI
I am:
  • Aspiring Film Maker
  • Tech Savvy
Reviewed at:
Price: $32.99
[0 of 1 customers found this review helpful]
1.0
    Pros
  • Fast Recharge
    Cons
  • Poor Fit
    Best Uses
  • Home Movies
"the battery went in my panasonic pv-720 camera, but it was to long and would not lock in place. I have to tape it in place to use. "
 Report Abuse  (0)  (1)  0 comments
Aug 8 2008
bob
washington
I am:
  • Parent
Reviewed at:
Price: $24.95
To previous reviewer
5.0
    Pros
    Cons
  • None
    Best Uses
  • None
"To the previous reviewer. Why would you make a poor rating when you bought the WRONG battery for your camcorder model? You should have bought the PV-BP50 battery. "
Jun 28 2009
REal guy
Minnesota
Reviewed at:
Price: $24.95
Panasonic PV-BP88 Camcorder Battery
5.0
"So far this battery is doing fine. I haven't fully depleted it yet but it took the initial charge fine and is powering the camcorder. "
Dec 24 2007
KLM
Amazon
Reviewed at:
Price: $34.95
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
