Lenmar CLM5696, 710mAh Li-ion Cellular Phone Battery for Motorola
#856
3.5
based on 55 reviews
Ratings Distribution
5 star
31
4 star
4
3 star
5
2 star
1
1 star
17
Category Average
3.9
Low Price:
$16.99 at RadioShack
 Trusted:
$16.99 at Adorama
$16.99 at Best Buy
see all stores
$16.99 - $39.00
from 9 stores
More Images
Pros
  • Charges quickly (21)
  • Long lasting (21)
  • Reliable (21)
  • Powerful (9)
  • Affordable (4)
  • Lightweight (2)
  • Clear sound (1)
  • Correct fit (1)
  • Durable (1)
  • Extends life of razr (1)
See less See more
Cons
  • Short life (9)
  • Inconsistent performance (4)
  • Underpowered (4)
  • Battery currently not cha (1)
  • Charges slowly (1)
  • Doesn't hold a charge (1)
  • Fit (1)
  • Hard to find (1)
  • Holds less than 24 hrs (1)
  • Lasted less than 2 weeks (1)
Best Uses
  • Portable electronics (12)
  • Long talks (8)
  • Cell phone (3)
  • Emergency equipment (2)
  • Good for commuting (2)
  • Having around the house (2)
  • Travel (2)
  • Motorola razr v3 (1)
  • Return it (1)
  • Work (1)
Provided by WolfCamera.com
This Lenmar Lithium-ion Wireless Phone Battery provides reliable power for your Motorola Cellular Phone. NoMEM technology ensures that you can recharge from any capacity level without diminishing performance.
Main Features
  • Manufacturer: Lenmar Enterprises, Inc.
  • Manufacturer Part Number: CLM5696
  • Manufacturer Website Address: http://www.lenmar.com
  • Battery Finder Address: http://www.ritzcamera.com/battery-locator.htm
  • Product Type: Cellular Phone
  • Battery Chemistry: Lithium-Ion
  • Battery Capacity: 710 mAh
  • Battery Voltage: 3.6 V
  • Compatibility
    • Fits: Motorola RAZR V3 and PEBL
    • Replaces: SNN5696A, SNN5777A
  • Warranty: 2 Years
Specification Description
Model CLM-5696, CLM5696
UPC 029521836684
Accessory Indicator Yes
Battery Finder Indicator Yes
Benefits Designed to fit the Motorola Razr V3 and V3c modelsReplaces the SNN5696B batteryUses lithium-ion technology for extended tal
Capacity 710
Capacity UOM mAh
Chemistry Lithium Ion
Country Of Origin China
Description Header Mostly for your Moto.
Display Catalog Number 55019511
Manufacturer Labor Warranty 2
Manufacturer Part Number CLM-5696
Manufacturer Parts Warranty 2
MAP Price 0.0
Model CLM-5696
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Type Motorola
Product Weight UOM pounds
Supported Languages English
Voltage 3.6
Voltage UOM Volts
Lenmar CLM5696, 710mAh Li-ion Cellular Phone Battery for Motorola Questions
Questions and Answers
Where to Buy
$16.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$16.99
$16.99
Shop RitzCamera with FREE Shipping & No Sales Tax! ends 12/31/09
Show all 9 stores
Product Reviews
Last update: Nov 2, 2009
Lenmar CLM5696, 710mAh Li-ion Cellular Phone Battery for Motorola Reviews
Most helpful positive review
[0 of 1 customers found this review helpful]
Most helpful negative review
[7 of 7 customers found this review helpful]
5.0
Value for your dollars in this economy
"Great Battery for the price, simple yet effective. I needed a new battery and did not want to pay 30-40 dollars for a new battery. For those prices I could have boughten a new phone. The battery was affordable at half the cost of a name brand battery, the only set back was that I had to order it and wait for it to arrive [...] as other local stores only stocked the more expensive brands. [...]..." Read Full Review »
Oct 29, 2009 by Greg
See more positive Lenmar CLM5696, 710mAh Li-ion Cellular Phone Battery for Motorola reviews
1.0
Two and Both Bad
"These batteries must be a bad batch. When the first one failed, I thought my phone had failed, then one week later the 2nd battery which was in my wife's phone also failed. In the mean time I'd purchased a new used phone on e-bay which came with a Motorola brand battery. With the Motorola Battery my phone came back to life and I now have a spare phone...." Read Full Review »
Dec 26, 2007 by George
See more negative Lenmar CLM5696, 710mAh Li-ion Cellular Phone Battery for Motorola reviews
Displaying 1 - 5 of 55 Reviews
Show
Sort by
5.0
    Pros
  • Affordable
  • Charges Quickly
  • Reliable Performance
    Cons
  • Not stocked in stores
    Best Uses
  • Cell Phone
"Great Battery for the price, simple yet effective. I needed a new battery and did not want to pay 30-40 dollars for a new battery. For those prices I could have boughten a new phone. The battery was affordable at half the cost of a name brand battery, the only set back was that I had to order it and …"  Read Full Review »
Was this Battery review on the Lenmar CLM5696, 710mAh Li-ion Cellular Phone Battery for Motorola helpful to you?
 Report Abuse  (0)  (1)  0 comments
Oct 29 2009
Greg
Pasadena, Tx
I am:
  • Value Oriented
Reviewed at:
Price: $16.99
[1 of 1 customers found this review helpful]
Does Not Fit Properly
1.0
    Pros
  • Price
    Cons
  • Fit
    Best Uses
  • None
"The battery does not fit properly in my V3, if you notice the OEM battery has a plastic cover that makes the battery unit slightly larger. This replacement does not have that plastic cover/sleeve so it tends to wiggle in my phone. Had to use simple pieces of tape to increase the "size" to make the …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jul 19 2008
Go Cal Bears!
San Francisco, CA
I am:
  • Gearhead
Reviewed at:
Price: $16.99
Works perfectly!
5.0
    Pros
  • Extends life of RAZR
  • Long life battery
  • Works well
    Cons
  • Must connect with phone
  • Needed to return one
    Best Uses
  • Commuting
  • Long Talks
  • Travel
"Works great. Extends the life of my RAZR, that's still in good shape, till I decide on a new phone. Works like a new phone, with a few scratches. Definite recommend. Only drawback is that first battery to arrive did not communicate with my phone. Had to ship back and wait for a second to arrive. "
Mar 4 2009
rabbit
Miami,FL
I am:
  • Business Professional
  • Practical
  • Student
Reviewed at:
Price: $16.99
Buy it somewhere else
1.0
    Pros
  • None
    Cons
  • Lacks Power
    Best Uses
  • None
"I ordered a new battery for my razr cell phone and what I got was a piece of junk. It would not hold a charge for more than two or three hours. That was just slightly better than the one it was replacing. It is very difficult to believe that this was a new battery. [...] When Tandy was a leader in e …"  Read Full Review »
Sep 20 2009
none
St Louis
I am:
  • Quality Oriented
Reviewed at:
Price: $16.99
Better Than The Rest!
5.0
    Pros
  • Charges Quickly
  • Long Lasting
    Cons
  • None
    Best Uses
  • None
"I had bought some cheaper imitation batteries for my Razor V3 phone and they did not last 2 weeks,This battery has out lasted the cheap ones [...] This has a better price than the original Motorola BR50 but seems to last as long as the original. I use my phone all day with a blue tooth headset and g …"  Read Full Review »
Sep 7 2009
OddBall
Houston Tx
I am:
  • Quality Oriented
Reviewed at:
Price: $16.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
