Lenmar CBC446 3.6V 750mAh NI-MH Replacement Battery for UNIDEN CORDLESS PHONES
#257
3.9
based on 31 reviews
Ratings Distribution
5 star
19
4 star
6
3 star
2
2 star
1
1 star
6
Category Average
3.8
Low Price:
$5.99 at Adorama
$7.99 at Best Buy
Find it at Amazon
$5.99 - $52.59
from 9 stores
More Images
Pros
  • Easy setup (8)
  • Strong signal (4)
  • Compact design (3)
  • Wide range (3)
  • Nice features (2)
  • Nice sound (2)
  • Comfortable handset (1)
  • Direct replacement (1)
  • Durable (1)
  • Easy to install (1)
See less See more
Cons
  • Battery did not fit phone (1)
  • Hard to find (1)
  • Lacks features (1)
  • Need to return (1)
  • Poor battery life (1)
  • Poor sound quality (1)
  • See remarks (1)
  • Uncomfortable handset (1)
Best Uses
  • Everyday (15)
  • Home use (12)
  • Office (2)
  • Outdoors (1)
  • Portable electronics (1)
Provided by Staples
Ratings 750mAh 3.6V NiMH Is this the right for you? 1-year warranty Lenmar batteries are engineered and tested to meet or exceed original equipment manufacturers specifications.
Specification Description
Model CBC446, cbc-446
UPC 029521837131
Accessory Indicator Yes
Battery Finder Indicator Yes
Battery Type Product
Benefits Delivers 3.6 volts with a capacity of 750mAhReplaces Uniden BT446, works in many Uniden and RadioShack cordlesas phone models
Capacity 750
Capacity UOM mAh
Chemistry Ni-MH
Country Of Origin China
Description Header Give your cordless phone a jolt.
Display Catalog Number 55026596
Equivalent to DANTONA BATT-446, GE (GENERAL ELECTRIC) GE-TL26402, GEJ-TL26402, Gold Peak 80AAALH3BMX, Uniden BBTY0457001, BBTY0512001, BT-446, BT951, BATT-466, Lenm
Manufacturer Labor Warranty 12
Manufacturer Part Number CBC446
Manufacturer Parts Warranty 12
MAP Price 0.0
Model CBC446
Operating Temperature UOM ° F
Product Depth 1.97
Product Dimensions UOM inches
Product Height 0.4
Product Type 3.6V Ni-MH
Product Weight 0.04
Product Weight UOM pounds
Product Width 1.09
Rechargeable Yes
Recommended Use RadioShack 43-113, 43-3529, 43-3538, 43-3570, 43-3571, 43-3580, 43-3581, 43-3597, 43-3598, 43-3703, 43-3704, 43-3705, 43-3815, 43-3871, 43-3872, 43-38
Size Pack
Supported Languages English
Voltage 3.6
Voltage UOM Volts
Lenmar CBC446 3.6V 750mAh NI-MH Replacement Battery for UNIDEN CORDLESS PHONES Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 11, 2009
Lenmar CBC446 3.6V 750mAh NI-MH Replacement Battery for UNIDEN CORDLESS PHONES Reviews
Most helpful positive review
Most helpful negative review
5.0
Consumer Support Beets the Holiday Blues
"Radio Shack saved the day! Long a staple of consumer electronics Radio Shack maintains the parts needed for cordless phone battery replacement putting the original manufacturers to shame. They HAVE the product knowledge, support and logistics in keeping an active family or individual on the go; going!..." Read Full Review »
Nov 04, 2009 by Bryan 'BC'
See more positive Lenmar CBC446 3.6V 750mAh NI-MH Replacement Battery for UNIDEN CORDLESS PHONES reviews
1.0
It's a little early to rate this battery
"As stated above, it's a little early to rate this battery. I bought one just like it in July 2009 and it only lasted until I had to purchase this one. It seems the replacement rechargeable batteries for Radio Shack phones are not supposed to last more than a few months. The original batteries in the four (4) Radio Shack phones I own lasted three (3) and four (4) years.This one lasted about a week past the ninety..." Read Full Review »
Oct 29, 2009 by Ron
See more negative Lenmar CBC446 3.6V 750mAh NI-MH Replacement Battery for UNIDEN CORDLESS PHONES reviews
Displaying 1 - 5 of 31 Reviews
Show
Sort by
Excellent product
5.0
    Pros
  • Easy To Set Up
  • Very good battery life
    Cons
  • Na
    Best Uses
  • Everyday Use
"Bought these to replace the original handset batteries. They work great and are equal to the original battery in its performance. It's too soon to say but I anticipate that the batteries will last as long as the originals and hold their charge. "
Was this Cordless Telephone review on the Lenmar CBC446 3.6V 750mAh NI-MH Replacement Battery for UNIDEN CORDLESS PHONES helpful to you?
Nov 10 2009
Battery
Cedar Park, Texas
I am:
  • Quality Oriented
Reviewed at:
Price: $8.99
battery for uniden bt446 by lemar
5.0
    Pros
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Everyday Use
"I had brought this as a replacement for the battery that came with the phone. I like this phone so much, I wanted to get a replacement insted of getting a new phone. I went to a local radio stack [...]. Done a good job. "
Nov 11 2009
vic
boaz
I am:
  • Quality Oriented
Reviewed at:
Price: $8.99
5.0
    Pros
    Cons
  • None
    Best Uses
  • Everyday Use
  • Home Use
  • Office Use
  • Outdoors
"Radio Shack saved the day! Long a staple of consumer electronics Radio Shack maintains the parts needed for cordless phone battery replacement putting the original manufacturers to shame. They HAVE the product knowledge, support and logistics in keeping an active family or individual on the go; go …"  Read Full Review »
Nov 4 2009
Bryan 'BC'
Cape Ann Massachusetts
I am:
  • Quality Oriented
Reviewed at:
Price: $8.99
1.0
"As stated above, it's a little early to rate this battery. I bought one just like it in July 2009 and it only lasted until I had to purchase this one. It seems the replacement rechargeable batteries for Radio Shack phones are not supposed to last more than a few months. The original batteries in the …"  Read Full Review »
Oct 29 2009
Ron
Berea, Ohio
I am:
  • Quality Oriented
Reviewed at:
Price: $8.99
Nothing but problems
1.0
    Pros
  • None
    Cons
  • Poor Battery Life
    Best Uses
  • None
"I purchased this battery in February, 2008 for replacement of a 800m-Ah battery in a Uniden phone. This battery was smaller than the original however the rep. said it was correct. Within three months it began to loose memory and needs replacement. Would not buy from Radio Shack again [...]. Found a …"  Read Full Review »
Jan 2 2009
David
Miami, Florida
I am:
  • Quality Oriented
Reviewed at:
Price: $8.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
