Lenmar #CB0104 Replacement Battery For Panasonic KX-TG23XX/TG25XX Series
#35
4.1
based on 10 reviews
Ratings Distribution
5 star
6
4 star
5
3 star
2
2 star
0
1 star
1
Category Average
3.8
Low Price:
$10.95 at Adorama
$12.99 at Best Buy
Find it at Amazon
$10.95 - $39.00
from 5 stores
More Images
Pros
  • Charges quickly (7)
  • Long-lasting (4)
  • Durable (3)
  • Reliable (3)
  • Lightweight (2)
  • Versatile (2)
  • Easy setup (1)
  • It was already charged (1)
  • Long lasting (1)
  • Powerful (1)
See less See more
Cons
  • Lacks features (1)
  • Loses charge over time (1)
Best Uses
  • Replacement (5)
  • Everyday (3)
  • Home use (2)
  • Portable electronics (2)
Provided by Staples
Ratings 830mAh 3.6V NiMH Is this the right for you? 1-year mfr. limited warranty Lenmar batteries are engineered and tested to meet or exceed original equipment manufacturers specifications.
Specification Description
Model CB0104, LENCB0104
UPC 029521835861
Accessory Indicator Yes
Battery Finder Indicator Yes
Battery Type Product
Benefits Fits many models of Panasonic cordless telephonesReplaces Panasonic's HHR-P104 batteryDelivers 3.6 volts with a capacity of
Capacity 830
Capacity UOM mAh
Chemistry Ni-MH
Country Of Origin China
Description Header Talk, talk, talk.
Display Catalog Number 55030060
Equivalent to Dantona BATT-104, GE (General Electric) GE-TL26411, GEJ-TL26411, Energizer ER-P104, Lenmar CB0104, Panasonic HHR-P104, HHRP104, Type 29, RadioShack 2
Manufacturer Labor Warranty 12
Manufacturer Part Number CB0104
Manufacturer Parts Warranty 12
MAP Price 0.0
Model CB0104
Operating Temperature UOM ° F
Product Depth 2.1
Product Dimensions UOM inches
Product Height 0.45
Product Type 3.6V Ni-MH
Product Weight 4
Product Weight UOM ounces
Product Width 1.2
Rechargeable Yes
Recommended Use Panasonic KX-TG2303, KX-TG2312, KX-TG2314, KX-TG2322, KX-TG2335, KX-TG2336, KX-TG2343, KX-TG2344, KX-TG2346, KX-TG2356, KX-TG2357, KX-TG2386, KX-TG238
Size Specialty
Supported Languages English
Voltage 3.6
Voltage UOM Volts
Lenmar #CB0104 Replacement Battery For Panasonic KX-TG23XX/TG25XX Series Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 1, 2009
Lenmar #CB0104 Replacement Battery For Panasonic KX-TG23XX/TG25XX Series Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
[2 of 2 customers found this review helpful]
5.0
Replacement Battery for Panasonic Phone
"This is a replacement battery for a Panasonic Talking ID portable telephone. I was unable to get a replacement from Panasonic. This battery worked well but I have not had it long enough to determine the life of the new battery...." Read Full Review »
Jul 09, 2008 by SD
See more positive Lenmar #CB0104 Replacement Battery For Panasonic KX-TG23XX/TG25XX Series reviews
3.0
Use for replacement of old battery
"Used for replacement for Panasonic Cordless phones that needed new batteries. They have worked well for about a year and now do not keep the charge as much...." Read Full Review »
Jul 31, 2008 by Margie
See more negative Lenmar #CB0104 Replacement Battery For Panasonic KX-TG23XX/TG25XX Series reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
It seems to be a good product so far.
4.0
    Pros
  • None
    Cons
  • None
    Best Uses
  • Everyday Use
"I bought the batteries for the cordless phone. So far they are performing fine but sometimes it seems that the transmission gets weak and the person I am talking to cannot hear me although I can hear him. I then go to the corded phone and everything is fine. [...] "
Was this Cordless Telephone review on the Lenmar #CB0104 Replacement Battery For Panasonic KX-TG23XX/TG25XX Series helpful to you?
Nov 1 2009
None
Cupertino, CA
I am:
  • Quality Oriented
Reviewed at:
Price: $15.99
Hope it lasts longer than the [...]
3.0
"These batteries for older (a couple of years) wireless phones are hard to get and way over-priced. Tho this was the going rate. I hope it lasts longer than the [...] branded one that I had before. It didn't even last a year - thats beyond sad that was unacceptable. "
Aug 13 2009
PoorConsumerVictim
Burlingame, Cal
I am:
  • Quality Oriented
Reviewed at:
Price: $15.99
I will buy this product again
5.0
    Pros
    Cons
  • None
    Best Uses
  • Everyday Use
  • Home Use
"Ijust bought a replacement battery for a cordless phone. The price was the best I could find, and I have no problems with the product. "
Oct 21 2009
Irene
Cape Coral, FL
Reviewed at:
Price: $10.95
Good battery, bad phone
4.0
    Pros
  • Charges Quickly
    Cons
  • Loses Charge Over Time
    Best Uses
  • Replacement
"I am sure this a replacement battery, but after
charging it, the problem was only fixed temporarily, the display on the headset still goes out so it must be the phone itself. "
 Report Abuse  (2)  (0)  0 comments
Apr 2 2009
Havilland7
Capitol Heights, MD
I am:
  • Technically Challenged
Reviewed at:
Price: $15.99
Good Replacement
5.0
    Pros
  • Long-Lasting
    Cons
  • None so far
    Best Uses
  • Replacement
"This has been a good replacement battery for our Panasonic phone. It solved our static problem and failing battery that originally came with the phone 2 years ago. "
Apr 29 2009
Ed in CO
Colorado
I am:
  • Tech Savvy
Reviewed at:
Price: $15.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
