Lenmar 850mAh Li-ion Battery for Motorola KRZR, K1, Q, V325
#547
3.6
based on 129 reviews
from $6.64 - $39.00
Ratings Distribution
5 star
59
4 star
24
3 star
14
2 star
2
1 star
33
Category Average
3.6
More Images
Pros
  • Durable (22)
  • Lightweight (16)
  • Good price / value (4)
  • Great sound quality (4)
  • Long lasting (3)
  • Versatile (3)
  • Charges quickly (2)
  • Powerful (2)
  • Pricey (2)
  • Reliable (2)
See less See more
Cons
  • Poor design (8)
  • Flimsy (4)
  • 2nd didn't hold charge (1)
  • A little less talk time (1)
  • Battery won't charge (1)
  • Can't hold a charge (1)
  • Charge duration (1)
  • Did not charge (1)
  • Did not fit properly (1)
Best Uses
  • Long talks (46)
  • Good for commuting (14)
  • Travel (12)
  • Cell phone (2)
  • Back-up (1)
  • Battery replacment (1)
  • Didn't fit didn't use (1)
  • Moderate conversation (1)
  • Power a cell phone (1)
  • Random (1)
Provided by Staples
Ratings 850mAh 3.7V Li-Ion Is this the right for you? 2-year warranty Lenmar batteries are engineered and tested to meet or exceed original equipment manufacturers specifications.
Specification Description
Model CLM5766, LENCLM5766
UPC 029521557534
Accessory Indicator Yes
Battery Finder Indicator Yes
Benefits Delivers 3.7 volts with a capacity of 850mAhCompatible with Motorola KRZR, K1, Q and V325Replaces SNN5766, SNN5783
Capacity 850
Capacity UOM mAh
Chemistry Lithium Ion
Country Of Origin China
Description Header Keep the conversation alive.
Display Catalog Number 55025465
Equivalent to Motorola SNN5762A, SNN5765A, SNN5766, SNN5783
Manufacturer Labor Warranty 2
Manufacturer Part Number CLM5766
Manufacturer Parts Warranty 2
MAP Price 0.0
Model CLM5766
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Type Motorola
Product Weight UOM pounds
Rechargeable Yes
Recommended Use Fits Motorola KRZR K1, Q, V325
Size Pack
Supported Languages English
Voltage 3.7
Voltage UOM Volts
Lenmar 850mAh Li-ion Battery for Motorola KRZR, K1, Q, V325 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 19, 2009
Lenmar 850mAh Li-ion Battery for Motorola KRZR, K1, Q, V325 Reviews
Most helpful positive review
Most helpful negative review
4.0
Cell Phone Lives
"I was able to extend the life of a cellphone I like at 1/3 the cost of a replacement battery at the cell phone store. The battery was ever so slightly larger than the OEM battery. The old battery comes in and out easily. I needed a putty knife to shoehorn the new one in to place. The 850 mAh rating is slightly less than the 880 mAh rating of the OEM battery but I have not noticed any difference in performance..." Read Full Review »
Nov 17, 2009 by Jon
See more positive Lenmar 850mAh Li-ion Battery for Motorola KRZR, K1, Q, V325 reviews
1.0
Really Disapointed
"I bought this battery because mine had started dying after about two to three days of stand by time where it used to last for about a week and a half without charging it. Partially because I don't talk on it as much as most do. The battery/Cell Phone is now one year old. The battery I purchased from you a couple of weeks ago only last for three days of stand by time and it's new. I am very unhappy about this. I'..." Read Full Review »
Aug 04, 2009 by Georgia
See more negative Lenmar 850mAh Li-ion Battery for Motorola KRZR, K1, Q, V325 reviews
Displaying 1 - 5 of 129 Reviews
Show
Sort by
Replacement battery not quite up to par
3.0
    Pros
  • New not refurbished
  • Physically compatible
    Cons
  • Light on power
    Best Uses
  • None
"I used this battery as a replacement in Motorola ROKR which normally uses a 910MAH battery. For the price I believe it was worth slightly less capacity which translates into the need for more frequent charges (once every four days versus about six day for the original battery when it was new) Of cou …"  Read Full Review »
Was this Cell Phone Accessory review on the Lenmar 850mAh Li-ion Battery for Motorola KRZR, K1, Q, V325 helpful to you?
Nov 22 2009
Joe
NE Ohio
I am:
  • Gearhead
  • Practical
Reviewed at:
Price: $15.99
Cell Phone Lives
4.0
    Pros
  • Less costly than Verizon
    Cons
  • Very tight fit
    Best Uses
  • None
"I was able to extend the life of a cellphone I like at 1/3 the cost of a replacement battery at the cell phone store. The battery was ever so slightly larger than the OEM battery. The old battery comes in and out easily. I needed a putty knife to shoehorn the new one in to place. The 850 mAh rating …"  Read Full Review »
Nov 17 2009
Jon
Piney Point, MD
I am:
  • Business Professional
Reviewed at:
Price: $15.99
Great Company
5.0
    Pros
  • Good battery life
    Cons
  • None
    Best Uses
  • Long Talks
"The product description provided by Beach Audio is what lead me to purchase with their company. I was able to feel confident that I was purchasing the correct battery. Plus their prices are very good. "
Nov 10 2009
TK
Denver CO
I am:
  • Practical
Reviewed at:
I WOULD BUY THIS PRODUCT AGAIN
5.0
    Pros
  • Great price
    Cons
  • None
    Best Uses
  • None
"I PRICED THIS CELL-PHONE BATTERY AT my cell phone carrier & they wanted a lot more for the same battery. My original battery that came with the phone was only guaranteed for 1 year. This battery is guaranteed for 2 years & so far is holding a charge longer than my original battery[...] "
Nov 18 2009
CASS
STREET MD.
I am:
  • Parent
Reviewed at:
Price: $15.99
Horrible battery
1.0
    Pros
  • None
    Cons
  • Did not charge
    Best Uses
  • None
"I got this as a replacement battery for my Motorola Razor TracFone. It seemed to fit too snugly. The charge light flickered the whole time. Then I tried to remove the paper-like wrapping on the battery and it fell apart. Total waste of money. "
Nov 14 2009
MedTech
Natchez, MS
I am:
  • Practical
Reviewed at:
Price: $15.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
