Lenmar 3.7V/1200mAh Li-ion Cellular Phone Battery (Model# CLKBLC2X)
#611
4.1
based on 11 reviews
Ratings Distribution
5 star
7
4 star
2
3 star
0
2 star
0
1 star
2
Category Average
3.9
 Trusted:
$49.00 at Rainbow Appliance
$18.99 at RadioShack
Find it at Amazon
$18.99 - $49.00
from 4 stores
More Images
Pros
  • Durable (4)
  • Great sound quality (2)
  • Charges quickly (1)
  • It's a battery it works (1)
  • Powerful (1)
  • Reliable (1)
See less See more
Cons
  • Would not hold charge (1)
Best Uses
  • Long talks (6)
  • Travel (3)
  • Good for commuting (1)
  • Portable electronics (1)
Provided by RitzCamera.com
Get Lenmar's 3.7V/1200mAh Li-ion battery for your Nokia wireless phone. Don't be cut off by a weak or worn out battery.
Main Features
  • Manufacturer: Lenmar Enterprises, Inc.
  • Manufacturer Part Number: CLKBLC2X
  • Manufacturer Website Address: http://www.lenmar.com
  • Battery Finder Address: http://www.ritzcamera.com/battery-locator.htm
  • Product Type: Cellular Phone
  • Battery Chemistry: Lithium-Ion
  • Battery Capacity: 1200 mAh
  • Battery Voltage: 3.7 V
  • Compatibility
    • Fits: Nokia 2260, 3320, 3360, 3361
    • Replaces: BMC-3
  • Warranty: 2 Years
Specification Description
Model CLK-BLC2X, CLKBLC2X
UPC 029521832051
Accessory Indicator Yes
Battery Finder Indicator Yes
Benefits Designed with extended battery apacityUse with Nokia 1221, 1260, 1261, 2260, 3320, 3360 and 3361 wireless phone modelsProvid
Capacity UOM mAh
Chemistry Lithium Ion
Country Of Origin China
Description Header Maximize your talk time.
Display Catalog Number 55019507
Manufacturer Labor Warranty 2
Manufacturer Part Number CLK-BLC2X
Manufacturer Parts Warranty 2
MAP Price 0.0
Model CLKBLC2X
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Type Nokia
Product Weight UOM pounds
Supported Languages English
Lenmar 3.7V/1200mAh Li-ion Cellular Phone Battery (Model# CLKBLC2X) Questions
Questions and Answers
Where to Buy
$18.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$49.00
$18.99
Show all 4 stores
Product Reviews
Last update: Aug 15, 2009
Lenmar 3.7V/1200mAh Li-ion Cellular Phone Battery (Model# CLKBLC2X) Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Great Cell Phone Battery
"This battery is much better than the original battery ever was. The old battery was 900 mAh and this one is 1200 mAh. It gives longer talk and standby time. The sound is clearer. The signal is stronger. If you like your older cell phone as much as I do, then this battery is for you...." Read Full Review »
Feb 13, 2009 by TNT Tom
See more positive Lenmar 3.7V/1200mAh Li-ion Cellular Phone Battery (Model# CLKBLC2X) reviews
1.0
Unsatisfactory service
"I stopped into the store to pick up the battery after an associate called to invite me in. I went in without my receipt. They would not give me the battery. They asked for my credit card that I had used to make the purchase. Unfortunately, I did not bring my credit cards with me because the item was paid in full at the time of the order. I asked what were the last 4 digits of the card that was used so I could c..." Read Full Review »
Feb 13, 2009 by Chris Chicoine
See more negative Lenmar 3.7V/1200mAh Li-ion Cellular Phone Battery (Model# CLKBLC2X) reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
1.0
"I stopped into the store to pick up the battery after an associate called to invite me in. I went in without my receipt. They would not give me the battery. They asked for my credit card that I had used to make the purchase. Unfortunately, I did not bring my credit cards with me because the item wa …"  Read Full Review »
Was this Battery review on the Lenmar 3.7V/1200mAh Li-ion Cellular Phone Battery (Model# CLKBLC2X) helpful to you?
 Report Abuse  (1)  (0)  0 comments
Feb 13 2009
Chris Chicoine
Lake Forest Il
Reviewed at:
Price: $18.99
5.0
    Pros
  • Clear Sound
  • Durable
    Cons
  • None
    Best Uses
  • Long Talks
  • Travel
"This battery is much better than the original battery ever was. The old battery was 900 mAh and this one is 1200 mAh. It gives longer talk and standby time. The sound is clearer. The signal is stronger. If you like your older cell phone as much as I do, then this battery is for you. "
Feb 13 2009
TNT Tom
Schwenksville,PA
I am:
  • Gearhead
  • Practical
Reviewed at:
Price: $18.99
Just what my phone needed. I'll be back
5.0
    Pros
  • Charges Quickly
  • Powerful
  • Reliable Performance
    Cons
  • None
    Best Uses
  • Portable Electronics
"This battery was hard to find until I contacted you folks at Radio Shack. You sent me a fine battery for my older Nokia cell phone, and it works perfect. Very powerful and reliable.[...] "
Aug 15 2009
Bill
Easathampton, Massachusetts
I am:
  • Quality Oriented
Reviewed at:
Price: $18.99
I would buy this product again
5.0
    Pros
  • Durable
    Cons
  • None
    Best Uses
  • Long Talks
"I could not find a battery for my old cell phone. It still works and I didn't want to change phones. I was pleased to find out that [...] carried replacement batteries! [...] "
Jul 5 2009
lbordas
Plymouth, MI
I am:
  • Practical
Reviewed at:
Price: $18.99
Good, reliable product
4.0
    Pros
  • Durable
    Cons
  • None
    Best Uses
  • Long Talks
"The product I purchased is reliable that I can count on to conduct lengthy business discussions without losing power to my cell phone. "
Jun 9 2009
Lone Star
Dallas, Texas
I am:
  • Practical
Reviewed at:
Price: $18.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
