Lenmar 3.7V/1150mAh Li-ion Battery for Panasonic CGA-S005
#2
4.9
based on 7 reviews
Ratings Distribution
5 star
6
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
2.4
Low Price:
$3.99 at Hoover
 Trusted:
$9.77 at Vanns.com
Find it at Amazon
$3.99 - $39.00
from 13 stores
More Images
Pros
  • 5 second change out (2)
  • Charges quickly (2)
  • Everlasting charge (2)
  • Exceptional longevity (2)
  • Fast recharge (2)
  • Good to the last volt (2)
  • There when you run dry (2)
  • Durable (1)
  • Good value (1)
  • High quality (1)
See less See more
Cons
  • Loses charge over time (2)
  • Poor battery life (1)
Best Uses
  • Travel (4)
  • Replacement (3)
  • Back-up (2)
  • Digital photography (2)
  • Mobility (2)
  • Photography (2)
  • Camera (1)
Provided by Zbattery.com
DLP005 3.7V 1150mAh Digital Camera Battery
This battery replaces the following models:
FUJIFILM NP-70, FUJIFILM FinePix F20, LEICA BP-DC4, LEICA C-LUX 1, LEICA D-LUX2, LENMAR DLP005, PANASONIC CGA-S005, PANASONIC CGA-S005E, PANASONIC CGA-S005E/1B, PANASONIC DMW-BCC12, PANASONIC Lumix DMC-FX01, PANASONIC Lumix DMC-FX07, PANASONIC Lumix DMC-FX3, PANASONIC Lumix DMC-FX50, PANASONIC Lumix DMC-FX8, PANASONIC Lumix DMC-FX8-A, PANASONIC Lumix DMC-FX8BS, PANASONIC Lumix DMC-FX8EBB, PANASONIC Lumix DMC-FX8EG-A, PANASONIC Lumix DMC-FX8EG-K, PANASONIC Lumix DMC-FX8EG-P, PANASONIC Lumix DMC-FX8EG-S, PANASONIC Lumix DMC-FX8-K, PANASONIC Lumix DMC-FX8-P, PANASONIC Lumix DMC-FX8-S, PANASONIC Lumix DMC-FX9, PANASONIC Lumix DMC-FX9K, PANASONIC Lumix DMC-FX9S, PANASONIC Lumix DMC-LX1, PANASONIC Lumix DMC-LX1BS, PANASONIC Lumix DMC-LX1EG-K, PANASONIC Lumix DMC-LX1EG-S, PANASONIC Lumix DMC-LX1-K, PANASONIC Lumix DMC-LX1-S, PANASONIC Lumix DMC-LX2, PANASONIC Lumix DMC-LX9, PANASONIC Lumix DMC-LX9BB, PANASONIC Lumix DMC-LX9BS, PANASONIC Lumix DMC-LX9EG, PANASONIC Lumix DMC-LX9EG-K, PANASONIC Lumix DMC-LX9EG-R, PANASONIC Lumix DMC-LX9EG-S, PANASONIC Lumix DMC-LX9-H, PANASONIC Lumix DMC-LX9-K, PANASONIC Lumix DMC-LX9-R, PANASONIC Lumix DMC-LX9-S, PANASONIC SGA-S005A, RICOH Caplio GR, RICOH Caplio GR Digital, RICOH Caplio R3, RICOH Caplio R30, RICOH Caplio R4, RICOH Caplio R40, RICOH Caplio R5, RICOH DB-60
3 Year Manufacturer's Warranty
Specification Description
Model DLP-005, DLP005, LENDLP005
UPC 029521835847
Accessory Indicator Yes
Battery Finder Indicator Yes
Benefits Fits Panasonic Lumix DMC-FX8/FX9 and DMC-L1 digital camerasReplaces Panasonic CGA-S005 batteryNo memory effect (NoMEM) helps
Capacity 1150
Capacity UOM mAh
Chemistry Lithium Ion
Country Of Origin China
Description Header Get the ultimate charge with NoMEM technology.
Display Catalog Number 55019570
Manufacturer Labor Warranty 3
Manufacturer Part Number DLP-005
Manufacturer Parts Warranty 3
MAP Price 0.0
Model DLP-005
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Type 3.7V
Product Weight UOM pounds
Rechargeable Yes
Supported Languages English
Voltage 3.7
Voltage UOM Volts
Lenmar 3.7V/1150mAh Li-ion Battery for Panasonic CGA-S005 Questions
Questions and Answers
Where to Buy
$17.99
Shop RitzCamera with FREE Shipping & No Sales Tax! ends 12/31/09
$17.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$3.99
Show all 13 stores
Product Reviews
Last update: Nov 3, 2009
Lenmar 3.7V/1150mAh Li-ion Battery for Panasonic CGA-S005 Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
What No A/C Adapter?
5.0
    Pros
  • 5 Second Change Out
  • Everlasting Charge
  • Exceptional Longevity
  • Fast Recharge
  • Good To The Last Volt
  • More »
    Cons
  • None
    Best Uses
  • Digital Photography
  • Mobility
  • Photography
  • Travel
"My new digital camera didn't include the optional A/C adapter. Although recommended for extended home use, it was impossible to locate so I opted for a reserve battery knowing I would just have to recharge the spent one while using the reserve. After an extensive search of the recommended choices I …"  Read Full Review »
Was this Laptop Battery review on the Lenmar 3.7V/1150mAh Li-ion Battery for Panasonic CGA-S005 helpful to you?
Aug 22 2008
Arizona, The body surfer
Puyallup, WA
I am:
  • Hobbyist/Enthusiast
What, No A/C Adapter?
5.0
    Pros
  • Fast Recharge
  • More »
    Cons
  • None
    Best Uses
  • Mobility
  • Photography
  • Travel
"My new digital camera didn't include the optional A/C adapter. Although recommended for extended home use it was impossible to locate so I opted for a reserve battery knowing I would just have to recharge the spent one while using the reserve. After an extensive search of recommended choices I happe …"  Read Full Review »
Aug 22 2008
Arizona, the body surfer
Puyallup, WA
I am:
I have never had a problem with it
4.0
    Pros
  • Charges Quickly
  • Durable
  • Lightweight
  • Versatile
    Cons
  • Loses Charge Over Time
    Best Uses
  • Backup
  • Replacement
  • Travel
"It last a little less than a day with heay use. I may take 1200-1800 pics in a day and usually have to re-charge before I am done. I spend a lot of time in the field so I have a couple of backups.
I don't have enough experience with this battery to make an effective evaluation. I will be using them …"  Read Full Review »
Jul 7 2009
Ed
Yakima, Wa
I am:
  • Multimedia Professional
Reviewed at:
Price: $17.99
ok
5.0
    Pros
  • Charges Quickly
    Cons
  • Short Battery Life
    Best Uses
  • Replacement
"just a replacement battery for my camera! [...] "
Nov 3 2009
polo gal
CA
I am:
  • Tech Savvy
Reviewed at:
Price: $17.99
Great
5.0
    Pros
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • Camera
"I have had it a month or so as a back up to the battery that came with my Panasonic camera. As good as the original but for half the price. Don't think you can wrong on this one. "
Mar 25 2007
Chris
Seattle, WA
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
