Lenmar Lenmar® 3.6V/600mAh Ni-MH Cordless Phone Battery for GE
#48
4.3
based on 32 reviews
Ratings Distribution
5 star
19
4 star
13
3 star
4
2 star
1
1 star
1
Category Average
3.9
Low Price:
$5.99 at Adorama
$7.99 at Best Buy
Find it at Amazon
$5.99 - $29.00
from 7 stores
More Images
Pros
  • Easy setup (10)
  • Strong signal (5)
  • Reliable (3)
  • Charges quickly (2)
  • Easy to install (2)
  • Wide range (2)
  • 100 more mah (1)
  • 24 hour to charge (1)
  • Average (1)
  • Compatible (1)
See less See more
Cons
  • Poor battery life (2)
  • Average (1)
  • Limited range (1)
  • Not durable (1)
  • Pricey (1)
Best Uses
  • Everyday (26)
  • Home use (18)
  • Office (3)
  • Portable electronics (2)
  • Cordless phone (1)
  • Outdoors (1)
Provided by Beach Audio
Lenmar's GE cordless phone battery meets or exceeds the original manufacturer's specifications, provide improved battery life and seamless compatibility. Our wide selection of memory free NoMEM NiMH battery for GE cordless phones can be charged from any level without any performance reduction to maximize your talk time.
Specification Description
Model CBD958, LENCBD958
UPC 029521835908
Accessory Indicator Yes
Battery Finder Indicator Yes
Benefits Fits many GE model phones sold by GE, ATT and othersReplaces AT&T/Lucent 8058480000,8900990000, 2-6980GE1, 27910 and LX0603 batteries
Capacity 700
Capacity UOM mAh
Chemistry Ni-MH
Country Of Origin China
Description Header Give your phone a jolt.
Display Catalog Number 55028506
Equivalent to Again & Again STB-958, AT&T / Lucent 80-5848-00-00, 8058480000, 89-0099-00-00, 8900990000, Casio PM1-39BAT, PM139BAT, Dantona BATT-27910, Empire CPH-4
Manufacturer Labor Warranty 12
Manufacturer Part Number CBD958
Manufacturer Parts Warranty 12
MAP Price 0.0
Model CBD958
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 4.69
Product Type 3.6V
Product Weight 4
Product Weight UOM ounces
Product Width 2.5
Rechargeable Yes
Recommended Use AT&T/Lucent E597-1, E597-2, E1937, E5640, E5643, E5644, E5654, E5655, E5749B, E5917, E5921, E5926, E5927, E5937, E5938, E5939, E5947, Bell South BS582
Supported Languages English
Voltage 3.6
Voltage UOM Volts
Lenmar Lenmar® 3.6V/600mAh Ni-MH Cordless Phone Battery for GE Questions
Questions and Answers
Where to Buy
$8.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$5.99
BizRate Rating Outstanding 9.1
$7.99
Show all 7 stores
Product Reviews
Last update: Nov 1, 2009
Lenmar Lenmar® 3.6V/600mAh Ni-MH Cordless Phone Battery for GE Reviews
Most helpful positive review
Most helpful negative review
4.0
"Generic" Battery Works Perfectly
"I was able to obtain a replacement battery for my cordless phone via the Radio Shack website for a lower price than the phone manufacturer's own website. Plus, by having the item shipped to my local Radio Shack store, there was no shipping charge! The battery works fine and is perfectly compatible...." Read Full Review »
Oct 12, 2009 by Trish
See more positive Lenmar Lenmar® 3.6V/600mAh Ni-MH Cordless Phone Battery for GE reviews
3.0
phone renew
"[...] It was annoying to install and someone had to help me. But now that it's in, I'm enjoying the phone...." Read Full Review »
Sep 04, 2009 by lang arts 192
See more negative Lenmar Lenmar® 3.6V/600mAh Ni-MH Cordless Phone Battery for GE reviews
Displaying 1 - 5 of 32 Reviews
Show
Sort by
4.0
    Pros
  • Compatible
  • Lower Cost
    Cons
  • None
    Best Uses
  • None
"I was able to obtain a replacement battery for my cordless phone via the Radio Shack website for a lower price than the phone manufacturer's own website. Plus, by having the item shipped to my local Radio Shack store, there was no shipping charge! The battery works fine and is perfectly compatible. "
Was this Battery review on the Lenmar Lenmar® 3.6V/600mAh Ni-MH Cordless Phone Battery for GE helpful to you?
Oct 12 2009
Trish
Princeton, NJ
I am:
  • Value Oriented
Reviewed at:
Price: $8.99
Just what I needed!
5.0
    Pros
  • Cordless Phone Battery
    Cons
  • None
    Best Uses
  • Home Use
"Just what I needed for the first time to replace the original battery in my cordless phone. Numbers on the original battery matched with the number for a replacement. Not the same brand of battery but this one did the trick...phone is just like new....THANKS "
Oct 14 2009
Theresa the Cabin Lady
Blue Ridge, GA
I am:
  • Quality Oriented
Reviewed at:
Price: $8.99
I was worried, but not anymore.
5.0
    Pros
  • 24 hour to charge
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Everyday Use
  • Home Use
"I was happy with the description of the batteries. Battery match works well. I was worreid that the adapter would not match but it matched perfect. I have 3 cordless phones and they all hold a charge and work like new. "
Aug 18 2009
roofinbroad
Joliet, IL
I am:
  • Quality Oriented
Reviewed at:
Price: $8.99
Replacement Battery Success
5.0
    Pros
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Everyday Use
  • Home Use
"After charging a hard to find replacement battery, it has been only a few weeks but the battery has worked clearly and beautifully. So far, so good! "
Sep 16 2009
Only the best!
New York, NY
I am:
  • Quality Oriented
Reviewed at:
Price: $8.99
Correct replacement battery
5.0
    Pros
  • Correct battery
  • Strong Signal
    Cons
  • None
    Best Uses
  • Everyday Use
"It was impossible to find the correct battery in the retail stores I visited. I was very pleased with the delivery time to receive the merchandise from when I purchased it on line. "
Feb 11 2009
Goldentail
Lake Hiawatha, NJ
I am:
  • Value Oriented
Reviewed at:
Price: $8.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
