Lenmar Lenmar® 3.6V/600mAh Ni-Cd Cordless Phone Battery
#79
4.3
based on 15 reviews
Ratings Distribution
5 star
13
4 star
3
3 star
2
2 star
1
1 star
1
Category Average
3.9
Low Price:
$8.95 at Adorama
 Trusted:
$8.99 at RadioShack
Find it at Amazon
$8.95 - $15.99
from 4 stores
More Images
Pros
  • Easy setup (5)
  • Reliable (5)
  • Charges quickly (4)
  • Long lasting (3)
  • Easy to use (2)
  • Powerful (2)
  • It is just a battery (1)
  • Nothing applies (1)
  • Perfect fit (1)
  • Quality construction (1)
See less See more
Cons
  • Did not work (1)
  • Pricey (1)
  • Wait and see (1)
Best Uses
  • Everyday (8)
  • Home use (5)
  • Portable electronics (3)
  • Having around the house (2)
  • Ofcourse 247 (1)
  • Rs telephone replacement (1)
Provided by Digital4Cheap
This is a brand new, factory sealed Lenmar CBD-366, 3.6V / 600mAh Generic Cordless Phone Battery.
  • 3.6v/600mAh
  • NiCd
  • Specification Description
    Model CBB310, CBD-366, CBD366, LENCBD366
    UPC 029521555899
    Accessory Indicator Yes
    Battery Finder Indicator Yes
    Battery Type Product
    Benefits Fits many GE, Bell South, Ameriphone® and Clarity® phones and moreReplaces Audiovox BT-2400, GE GESPCF01, TL96554, Sanik 3SN-
    Benefits Fits many models of AT&T, RadioShack and VTech cordless phonesReplaces AT&T3301, 80-5071-00-00, CS-P240C, RadioShack CS90023, CS90186
    Capacity 600
    Capacity UOM mAh
    Chemistry Ni-CD
    Country Of Origin China
    Description Header Fresh juice for your phone.
    Description Header Now hear this.
    Display Catalog Number 55034213
    Display Catalog Number 55034221
    Enclosure Color White
    Equivalent to Again & Again STB-116, AT&T / Lucent Technologies D-AA650MAH, AT&T D-AA650MAH, Audiovox BT-2400, Bell South 39202, 39705, B650, B658, Dantona 3AA-W, L
    Equivalent to Again & Again STB-912, AT&T / Lucent Technologies 1040, 3301, 80-5071-00-00, CS-P240CL, AT&T / Lucent Technologies 204293, AT&T / Lucent Technologies
    Manufacturer Labor Warranty 12
    Manufacturer Part Number CBB310
    Manufacturer Part Number CBD366
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Model CBB310
    Model CBD366
    Operating Temperature UOM ° F
    Product Depth 1.89
    Product Depth 1.93
    Product Dimensions UOM inches
    Product Height 0.55
    Product Height 0.64
    Product Type 3.6V Ni-Cd
    Product Weight 4
    Product Weight UOM ounces
    Product Width 1.57
    Product Width 1.61
    Rechargeable Yes
    Recommended Use AT&T / Lucent Technologies 3300, 3301, 6100, 6200, 8220, 8241, 8243, 90556, 91076, 9210, 9230, 9257, 9301, 9304, 9311, 9312, 9320, 9357, 9301, 9304, 9
    Recommended Use Ameriphone C440, CL40, DIALOG CL40, Bell South GH9402, GH9404, GH9405, GH9408, GH9482, MH9003, MH9004, MH9005, MH9007, MH9008, MH9012, MH9017, MH9018,
    Size Pack
    Supported Languages English
    Voltage 3.6
    Voltage UOM Volts
    Lenmar Lenmar® 3.6V/600mAh Ni-Cd Cordless Phone Battery Questions
    Questions and Answers
    Where to Buy
    $8.99
    $10 Off Orders Of Orders Over $85 + Free Shipping
    $8.95
    BizRate Rating Outstanding 9.2
    $9.99
    Show all 4 stores
    Product Reviews
    Last update: Nov 11, 2009
    Lenmar Lenmar® 3.6V/600mAh Ni-Cd Cordless Phone Battery Reviews
    Most helpful positive review
    [4 of 4 customers found this review helpful]
    Most helpful negative review
    5.0
    Great battery
    "[...]. It seems to me that these last longer than the original batteries that come with the phones...." Read Full Review »
    Jul 05, 2008 by Bonnie
    See more positive Lenmar Lenmar® 3.6V/600mAh Ni-Cd Cordless Phone Battery reviews
    1.0
    The Lenmar Battery did not work!!!
    "Radio Shack ordered the replacement battery. After charging for 12 hours the phone would not produce a dial tone. The store took the returned and called why the sent Battery did not list it as a suitable replacement. The store said there was not available a suitable replacement and the phone was useless. There was nothing RS could do to make the phone usable. I was promised a refund which has never come. RS has ..." Read Full Review »
    Oct 17, 2009 by James
    See more negative Lenmar Lenmar® 3.6V/600mAh Ni-Cd Cordless Phone Battery reviews
    Displaying 1 - 5 of 15 Reviews
    Show
    Sort by
    New Batteries fixed $ Cell Phones
    4.0
      Pros
    • Charges Quickly
    • Long Lasting
    • Powerful
    • Reliable Performance
      Cons
    • None yet
      Best Uses
    • Portable Electronics
    "Rather than buy new cell phones, I bought new batteries. So far, AOK. "
    Was this Battery review on the Lenmar Lenmar® 3.6V/600mAh Ni-Cd Cordless Phone Battery helpful to you?
    Nov 10 2009
    TomH
    Shawnee, OK
    I am:
    • Value Oriented
    Reviewed at:
    Price: $8.99
    1.0
      Pros
    • None
      Cons
    • Did not work
      Best Uses
    • RS Telephone replacement
    "Radio Shack ordered the replacement battery. After charging for 12 hours the phone would not produce a dial tone. The store took the returned and called why the sent Battery did not list it as a suitable replacement. The store said there was not available a suitable replacement and the phone was use …"  Read Full Review »
    Oct 17 2009
    James
    I am:
    • Quality Oriented
    Reviewed at:
    Price: $8.99
    Battery plug did not fit phone
    3.0
      Pros
    • None
      Cons
    • None
      Best Uses
    • Having Around The House
    "This battery was the correct replacement battery for my Radio Shack phone, but the plug did not fit the phone. Fortunately, I figured out how to remove the new plug and attach the old plug, but the battery was still very hard to stuff into the phone. It may be slightly bigger than the old battery. …"  Read Full Review »
    Oct 22 2009
    Riddikulus
    Chicago
    I am:
    • Quality Oriented
    Reviewed at:
    Price: $8.99
    Phone Battery-Could not find in stores
    4.0
      Pros
    • Charges Quickly
    • Long Lasting
      Cons
    • None
      Best Uses
    "Needed for my portable AT&T phone. [...] "
    Nov 10 2009
    Happy Online Shopper
    Boston, MA
    I am:
    • Value Oriented
    Reviewed at:
    Price: $8.99
    [1 of 1 customers found this review helpful]
    wires flip flopped
    2.0
      Pros
    • None
      Cons
    • None
      Best Uses
    • Everyday Use
    "both quality and value oriented. The product was for a radioshack phone. The new battery did not work then I noticed the wires were the opposite so I swiched them around.(would 0f had a big 5) [...] In a socialist world we all need that special something. "
     Report Abuse  (1)  (0)  0 comments
    Oct 3 2009
    love freedom without a victim
    Yelm WA.
    I am:
    • Quality Oriented
    Reviewed at:
    Price: $8.99
    pages: 1 2 3 4 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
