Lenmar ® 2.4V/750mAh Ni-MH Cordless Phone Battery for VTech®
#865
3.5
based on 70 reviews
from $9.99 - $15.99
Ratings Distribution
5 star
24
4 star
20
3 star
8
2 star
0
1 star
18
Category Average
3.9
Low Price:
$9.99 at Adorama
$15.99 at RadioShack
Find it at Amazon
More Images
Pros
  • Easy setup (12)
  • Strong signal (12)
  • Nice sound (8)
  • Comfortable handset (7)
  • Charges quickly (6)
  • Lightweight (6)
  • Nice features (6)
  • Long lasting (5)
  • Powerful (4)
  • Reliable (4)
See less See more
Cons
  • Short battery life (9)
  • Lacks features (2)
  • Limited range (2)
  • Not durable (2)
  • Poor sound quality (2)
  • Battery doesnt keep charg (1)
  • Connection cables long (1)
  • Must not charg until dead (1)
  • Nothing negative (1)
Best Uses
  • Everyday (37)
  • Home use (19)
  • Portable electronics (5)
  • Outdoors (3)
  • Having around the house (2)
  • Cordless phone (1)
  • Dect 60 tech great (1)
  • Office (1)
  • Replacement battery (1)
Provided by Staples
This Lenmar replacement battery is the ideal replacement for AT&T 3111, BT18433, GE 2192218 and V Tech 2SNAAA60HSJ1, 8300, 89-1300-01, BT-1011 Cordless Phones. Fits:AT&T / Lucent SL82218, SL82408, SL82558, RadioShack 43-206, R6042, V-Tech 6010, 6031, 6032, 6041, 6042, 6043, 6053, 8300, DECT- 6030, DECT-6032 Replaces: AT&T / Lucent BT18433, BT184342, BT28433, BT284342, BT8001, General Electric 5-2734, Gold Peak GP70AAAH2BMJZR, Sanik 2SN-AAA70H-S-J1, 2SNAAA70HSX2F, V-Tech 2SNAAA65HS 2.4V / 750mAh, Nickle-Metal Hydride Is this the right for you? 1-year warranty Lenmar batteries are engineered and tested to meet or exceed original equipment manufacturers specifications.
Specification Description
Model CBD8003
Accessory Indicator Yes
Battery Finder Indicator Yes
Battery Type Product
Benefits Fits VTech DECT 6043, ip831, ip8300, 6010, 6032, 6053, 6052 and moreReplaces VTech® 8300 and 89-1326-00-00 cordless phone batteri
Capacity 750
Capacity UOM mAh
Chemistry Ni-MH
Country Of Origin China
Description Header Stay in touch.
Display Catalog Number 55028525
Equivalent to V Tech 8300, VT8300, 89-1300-01, 89-1326-00-00, 8913260000, AT&T Lucent 3101, 3111, BT18433, BT184342, BT28433, BT284342, BT8001, Dantona BATT-6010,
Included in the Box Lenmar CBD8003 cordless phone battery
Manufacturer Labor Warranty 12
Manufacturer Part Number CBD8003
Manufacturer Parts Warranty 12
MAP Price 0.0
Model CBD8003
Operating Temperature UOM ° F
Product Depth 0.9
Product Dimensions UOM inches
Product Height 0.45
Product Type 2.4V Ni-MH
Product Weight 2.5
Product Weight UOM ounces
Product Width 1.8
Rechargeable Yes
Recommended Use AT&T Lucent SL82118, SL82208, SL82218, SL82308, SL82318, SL82408, SL82418, SL82518, SL82558, SL82658, GE 2-7902, 2-7903FE1, 2-7909, 2-7911, Vtech 6010
Size Specialty
Supported Languages English
Voltage 2.4
Voltage UOM Volts
Lenmar ® 2.4V/750mAh Ni-MH Cordless Phone Battery for VTech® Questions
Questions and Answers
Where to Buy
$15.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$9.99
BizRate Rating Outstanding 9.2
$15.99
Product Reviews
Last update: Oct 30, 2009
Lenmar ® 2.4V/750mAh Ni-MH Cordless Phone Battery for VTech® Reviews
Most helpful positive review
Most helpful negative review
5.0
Excellent Replacement Battery for VTech
"My experience with Radio Shack has been wonderful. I had difficulty in finding a replacement battery for my VTech 6042 and Radio Shack offered two different replacement batteries. Price and quality meet the original specifications [...]. Thanks Radio Shack!The new Batteries (yes I got two!) provide long talk time and long life off the charging cradle.New Life to my VTech phones which I enjoy - they are lightwe..." Read Full Review »
Apr 18, 2009 by DrGGar
See more positive Lenmar ® 2.4V/750mAh Ni-MH Cordless Phone Battery for VTech® reviews
1.0
Good phone, terrible battery
"phone is very nice, however I have to keep replacing battery and none of them keep charge. If you use your phone more than ten minutes, it will run out of battery. Forget using the speaker phone, while it shows it has all bars and full strength,it will cut the phone off with no warning after 2 or 3 minutes of speaker use. Batteries are very expensive too. I don't recommend this phone!..." Read Full Review »
Nov 30, 2008 by Yousef
See more negative Lenmar ® 2.4V/750mAh Ni-MH Cordless Phone Battery for VTech® reviews
Displaying 1 - 5 of 70 Reviews
Show
Sort by
5.0
    Pros
  • Charge Last for days
  • Comfortable Handset
  • Compact design
  • Easy To Set Up
  • Good Sound
  • More »
    Cons
  • Nothing Negative
    Best Uses
  • Dect 60 Tech Great
  • Everyday Use
  • Home Use
"My experience with Radio Shack has been wonderful. I had difficulty in finding a replacement battery for my VTech 6042 and Radio Shack offered two different replacement batteries. Price and quality meet the original specifications [...]. Thanks Radio Shack!The new Batteries (yes I got two!) provid …"  Read Full Review »
Was this Battery review on the Lenmar ® 2.4V/750mAh Ni-MH Cordless Phone Battery for VTech® helpful to you?
Apr 18 2009
DrGGar
Muskogee, OK
I am:
  • Quality Oriented
Reviewed at:
Price: $15.99
Excellent value!
5.0
    Pros
  • Charges Quickly
  • Long Lasting
  • Powerful
  • Reliable Performance
    Cons
  • NONE
    Best Uses
  • cordless phone
  • Portable Electronics
"This was a replacement for the original battery in my cordless phone. I have been very impressed with the battery so far. I have not needed to charge my cordless phone for as long as 6 days, when previously we needed to charge the battery every night. This product provides excellent service for a go …"  Read Full Review »
Oct 30 2009
lgialouris
Corpus Christi, TX
I am:
  • Value Oriented
Reviewed at:
Price: $15.99
1.0
    Pros
  • Compact design
  • Good Sound
  • Strong Signal
    Cons
  • TERRIBLE BATTERY LIFE
    Best Uses
  • Everyday Use
"phone is very nice, however I have to keep replacing battery and none of them keep charge. If you use your phone more than ten minutes, it will run out of battery. Forget using the speaker phone, while it shows it has all bars and full strength,it will cut the phone off with no warning after 2 or 3 …"  Read Full Review »
Nov 30 2008
Yousef
Seattle
I am:
  • Quality Oriented
Reviewed at:
Price: $15.99
GET A DIFFERENT PHONE
1.0
    Pros
  • None
    Cons
  • Limited Range
  • Not Durable
  • Poor Sound Quality
  • Uncomfortable Handset
    Best Uses
  • Home Use
"This phone looks nice but they suck you in with [$]. each year in batteries. The handset is not comfortable and the speakerphone is terrible. There are many other phones out there that are a better quality. I would take this back if I could. You have to push 3 buttons just to get to your list of cal …"  Read Full Review »
Jan 10 2009
TpStBo
Palm Springs, ca
I am:
  • Quality Oriented
Reviewed at:
Price: $15.99
must have replacment
5.0
    Pros
  • None
    Cons
  • None
    Best Uses
  • Everyday Use
"The batteries for the vtech phone only last about 1.5 years and this is the only compatible battery replacement. Obviously a must have! Although quite an investment to replace batteries in 3 handsets every year or so. The 3 handsets were less than $100 originally. "
Sep 19 2009
JB
Havertown, PA
I am:
  • Value Oriented
Reviewed at:
Price: $15.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
