Learning Curve The First Years Crib CD Player
#76
2.8
based on 81 reviews
Ratings Distribution
5 star
19
4 star
14
3 star
7
2 star
14
1 star
27
Category Average
4.0
Low Price:
$39.00 at Walmart
 Trusted:
$59.99 at Baby Age
$39.99 at Babies R Us
see all stores
$39.00 - $59.99
from 3 stores
More Images
Pros
  • Attractive design (30)
  • Durable (23)
  • Portable (20)
  • Easy setup (17)
  • Easy to use (17)
  • Simple / intuitive controls (12)
  • Doesn't skip (9)
  • Great sound (8)
  • High quality (7)
  • Clear sound (4)
See less See more
Cons
  • Poor quality (11)
  • Skips (8)
  • Poor sound quality (7)
  • Difficult to use (4)
  • Poor battery life (3)
  • Unappealing design (2)
  • Battery (1)
  • Boring (1)
  • Changing battery is hard (1)
  • Didn't fit crib (1)
Best Uses
  • Entertainment (15)
  • Young children (11)
  • Smaller rooms (9)
  • Learning (7)
  • Basic systems (6)
  • Travel (6)
  • Audiophiles (2)
  • Creative development (1)
  • Every night for bedtime (1)
  • For nicu babies (1)
Provided by Babies R Us
Improved product now features anti-skip protection, improved battery life. (Launch date 4/1/03.)
Specification Description
Model 4120, FE173B3F, Y4120
UPC 071463041206
Age range 0 months - 3 years
Learning Curve The First Years Crib CD Player Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 12, 2009
Learning Curve The First Years Crib CD Player Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
[2 of 2 customers found this review helpful]
5.0
BEST THING I EVER GOT!
"This player just clips on to the side of any crib and plays any cd you want your child to go to sleep with. The handy slide up guard keeps little fingers out, and has a great timer so you don't waste batteries. I have used mine every night since he was born and he is 15 months now. Great night light on the back to check on them while sleeping and not bright enough to wake them. Don't know what I would do without..." Read Full Review »
Mar 12, 2009 by Logan's Mom
See more positive Learning Curve The First Years Crib CD Player reviews
2.0
Battery Eater
"I think having a CD player attached to the crib is a great idea for developing children. Unfortunately, this CD player runs through batteries extremely fast and has a skipping problem. We usually replace the batteries every 3 days, which becomes a pain. Our player also has a skipping problem and can only be fixed by opening the player and cleaning the CD thoroughly every night. I don't think the buttons are very..." Read Full Review »
Nov 08, 2008 by julpop
See more negative Learning Curve The First Years Crib CD Player reviews
Displaying 1 - 5 of 81 Reviews
Show
Sort by
Not so good!
1.0
    Pros
  • Attractive Design
  • Easy To Set Up
    Cons
  • Poor Sound
  • Skips
    Best Uses
  • None
"I was very excited to get the CD player for my shower. I think it's a great concept that it clips onto the crib (although it didn't quite fit on my crib). I started using it several weeks ago and it worked fine until it kept shutting off halfway through the CD. I changed the batteries and it kept …"  Read Full Review »
Was this CD Player review on the Learning Curve The First Years Crib CD Player helpful to you?
Nov 12 2009
Collin's mommy
Long Island, NY
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Price: $39.99
5.0
    Pros
  • Attractive Design
  • Doesn't Skip
  • Durable
  • Easy Controls
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"This player just clips on to the side of any crib and plays any cd you want your child to go to sleep with. The handy slide up guard keeps little fingers out, and has a great timer so you don't waste batteries. I have used mine every night since he was born and he is 15 months now. Great night light …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Mar 12 2009
Logan's Mom
Stony Point,NC
I am:
  • Musically Inclined
  • Practical
Reviewed at:
Price: $39.99
Battery Eater
2.0
    Pros
  • Attractive Design
  • Easy To Set Up
    Cons
  • Skips
    Best Uses
  • None
"I think having a CD player attached to the crib is a great idea for developing children. Unfortunately, this CD player runs through batteries extremely fast and has a skipping problem. We usually replace the batteries every 3 days, which becomes a pain. Our player also has a skipping problem and can …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Nov 8 2008
julpop
bay area, ca
I am:
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Price: $39.99
Great entertainment
4.0
    Pros
  • Attractive Design
  • Durable
  • Easy to Use
  • Engaging
  • High Quality
  • More »
    Cons
  • Hard to attach
  • Speaker is blocked
    Best Uses
  • Entertainment
  • Learning
  • Newborn
  • Travel
  • Young Children
"I thought the concept was really great, having a lightweight cd player that attaches to the crib. It does work great, the only thing I dont like is that the speaker is on the back side of this and gets covered when I push it down on the crib rail. Instead, I keep it propped up a little bit, on the t …"  Read Full Review »
Nov 16 2007
Maddi's Mom
Pennsylvania
I am:
  • First Time Parent
Reviewed at:
Price: $39.99
Not worth the price when it does'nt work
1.0
    Pros
  • Easy to Use
  • Engaging
  • Portable
    Cons
  • Low Quality
    Best Uses
  • None
"This product is a great idea and my baby loved the music however it stopped working just after the warranty was up so thinking that I just got a flawed machine, I bought another one, for my second child. It didn't work very well from the start but just having a new baby i didn't return it. If I pres …"  Read Full Review »
Apr 1 2008
unhappy mom
Iuka, MS
I am:
  • Parent of Two or More Children
  • Stay At Home Parent
Reviewed at:
Price: $39.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
