LaCie d2 Blu-ray Drive FireWire and Hi-Speed USB 2.0
#5
4.7
based on 7 reviews
Ratings Distribution
5 star
5
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.2
$359.95 - $371.99
from 5 stores
More Images
Pros
  • Easy setup (5)
  • Great picture quality (5)
  • Good connections (4)
  • Backwards compatible (2)
  • Dvd upconversion (1)
  • Easy to use (1)
  • Good soundtrack support (1)
  • Quality construction (1)
  • Transparent with software (1)
See less See more
Cons
  • Bulky (1)
  • Difficult set-up (1)
  • Slow load time (1)
Best Uses
  • Home (2)
  • Lcd tv (2)
  • Office (2)
  • Home editing output (1)
  • Home theater (1)
  • Plasma tv (1)
  • Replacement (1)
  • Upgrade (1)
Provided by ClubMac
d2 Blu-ray Drive FireWire and Hi-Speed USB 2.0 Engineered for professional video authoring houses, the LaCie d2 Blu-ray Drive records, rewrites, and plays back high-definition (HD) video. Professional HD Video RecordingEngineered for professional video authoring houses, the LaCie d2 Blu-ray Drive records, rewrites, and plays back high-definition (HD) video. Store up to four hours of HD video on a 50GB disc - about 10 times as much as a DVD. Shoot HD videos from your camcorder, author the videos, and burn them without any quality loss using multiple video codecs (MPEG2, AVC, VC-1). Then, share them with customers or give them to a replication facility for distribution.Cost-Effective, Long-Term ArchivesNow you can store large amounts of valuable administrative documents, audio asset libraries, raw video shoots and multiple image files on a single disc with complete peace of mind. The LaCie d2 Blu-ray Drive’s writing process ensures record authenticity and longevity on sturdy write-once discs with an enhanced scratch-resistant hard coating surface. It also offers a packet writing option. By choosing Blu-ray technology, you get low cost per gigabyte in safe storage.A Compelling Multimedia ExperienceBD-ROM doesn’t mean only high-definition video. With the LaCie d2 Blu-ray Drive, enjoy an HD movie with vibrant sound. Blu-ray offers up to eight channels at 192kHz/32 streams of audio quality. Get a stunning experience with multiple simultaneous videos, updatable content, full interactive challenges, and activities.Quick and Easy Backup SolutionThis state-of-the-art drive comes bundled with easy-to-use burning software, which includes a backup application. It is a genuine timesaving solution for regularly backing up important files or emails at an impressive data transfer rate. In addition, LaCie’s exclusive, trusted d2 drive design is unsurpassed for durability and offers near-silent operation.Features:• Hi-Speed USB 2.0 and FireWire interfaces• Backward compatible with DVDs and CDs• View BD-ROM, DVD-Video, and Video-CD• Play back high-definition Blu-ray movies (on Windows only)• Easy Media Creator 10 and Toast 9 TitaniumSystem Requirements:Mastering/Burning:• Windows XP with the latest service pack; Windows Vista / Mac OS X 10.4.8 or higher• Pentium 4 3GHz processor / Power PC G4 or higher, Mac Intel processor• Minimum 512MB RAMHD Video Playback:• Windows OS• NVIDIA GeForce 6600GT, ATI X1600 GPU with latest driver• Minimum 1280x1024 monitor resolution• To play a protected BD movie in HD through a digital DVI or HDMI interface: HDCP GPU + HDCP ready display
Specification Description
Model 301856U, LAC301856U
UPC 093053772062
Computer Compatibility PC and Macintosh
Connection External
Drive Capacity Limited to Capacity of Disc
Interface USB 2.0 - USB
Port Compatibility USB / Firewire
Power AC - 110-Volt AC House Current
Product Type BD-Writer
Type of Drive Blu-Ray Drive
LaCie d2 Blu-ray Drive FireWire and Hi-Speed USB 2.0 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 22, 2009
LaCie d2 Blu-ray Drive FireWire and Hi-Speed USB 2.0 Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
[12 of 13 customers found this review helpful]
Exactly what we needed.
4.0
    Pros
  • Easy To Set Up
  • Easy To Use
  • Quality Construction
    Cons
  • A little bulky
    Best Uses
  • Replacement
  • Upgrade
"Worked great right out of the box.
Was an extremely easy setup on a Mac.
No problems so far. "
Was this Blu-Ray Player review on the LaCie d2 Blu-ray Drive FireWire and Hi-Speed USB 2.0 helpful to you?
 Report Abuse  (12)  (1)  0 comments
Mar 11 2009
Ken at dMworks
Valley Stream, NY
I am:
  • Power User
Reviewed at:
Price: $359.95
[2 of 3 customers found this review helpful]
It was so easy..........
5.0
    Pros
  • Backwards Compatible
  • DVD Upconversion
  • Easy Set-Up
  • Excellent Image Quality
  • Good Connections
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Home Theater
  • LCD TV
  • Office
  • Plasma TV
"I am a dolphin researcher and not the most technology oriented person. This blu ray burner was so easy that literally I plugged it in and 5 minutes later I had my first blu ray. It was amazing because the results were astounding in terms of broadcast quality.
A++++++++++++++++++++++++++++product. …"  Read Full Review »
 Report Abuse  (2)  (1)  0 comments
Aug 11 2009
SpeakDolphin
Miami, Florida
I am:
  • Power User
Reviewed at:
Price: $359.95
Couldn't be happier with this drive!
5.0
    Pros
  • Easy Set-Up
  • Good Connections
    Cons
  • None
    Best Uses
  • Home Editing Output
"I had talked with others who had purchased this product, and they were raving... It's my first foray into Blu-Ray Creation, and was expecting teething pains while I learned the ins & outs of this format...
I was amazed... Installation was smooth and un-eventful. Operation was as advertised... Minim …"  Read Full Review »
Sep 7 2009
JJJ
Skokie, Illinois
I am:
  • Enthusiast
Reviewed at:
Price: $369.99
[3 of 3 customers found this review helpful]
Good Product
4.0
    Pros
  • Good Connections
    Cons
  • Difficult Set-Up
    Best Uses
  • None
"Good LaCie product.
Unclear instructions.To use it for HD video you have to buy extra software which is not indicated. "
 Report Abuse  (3)  (0)  0 comments
Oct 22 2009
Jack
Montreal,Canada
I am:
  • Power User
Reviewed at:
Price: $359.95
[2 of 2 customers found this review helpful]
Excellent hardware; great price!
5.0
    Pros
  • Easy Set-Up
  • Good Connections
    Cons
  • None
    Best Uses
  • None
"This is seriously some great equipment, especially if you're burning a lot of HD footage. It was shipped on time, no kinks, would purchase again in a heartbeat! "
 Report Abuse  (2)  (0)  0 comments
Aug 10 2009
Lil Yessi
Austin, Texas
I am:
  • Casual User
Reviewed at:
Price: $359.95
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
