LaCie 500GB Little Disk USB 2.0 Portable Hard Drive
#444
4.2
based on 40 reviews
Ratings Distribution
5 star
19
4 star
14
3 star
4
2 star
0
1 star
3
Category Average
4.1
$99.99 - $129.99
from 9 stores
More Images
Pros
  • Easy setup (9)
  • Large capacity / good size (9)
  • Quiet (9)
  • Compact (8)
  • Easy to use (8)
  • Attractive design (6)
  • Portable (4)
  • Reliable (3)
  • Durable (2)
  • Fast (2)
See less See more
Cons
  • Delicate (1)
  • Inflexible software (1)
  • May require power adaptor (1)
  • Slow connection (1)
  • Unreliable (1)
Best Uses
  • Back-up (10)
  • Additional storage (6)
  • Photo storage (5)
  • File transfer (3)
  • Laptop (3)
  • Laptops (2)
  • Large projects (2)
  • Multimedia (2)
  • Pc & mac (2)
  • High-end multimedia (1)
Provided by PC Mall
Little Disk 500GB Portable Hi-Speed USB 2.0 Hard Drive Design by Sam Hecht Get stylish, compact, portable storage, back up, synchronize and secure your files & settings with the Little Disk. Exclusive, elegant, glossy design by Sam Hecht. Stylish, Compact ans Portable StorageGet stylish, compact, portable storage with the Little Disk, Design by Sam Hecht. Easily carry your photos, music, videos and files on this petite mobile solution. Designed exclusively for LaCie by Sam Hecht, it has a high-gloss, black elegance with clean, simple lines and comes with a removable protective cap. The integrated, extractable USB cable pulls out and retracts so it can never be lost or forgotten. The LaCieSync software allows you to bring your important data with you safely. Just plug the Little Disk into any PC to access and modify your files, emails (Microsoft Outlook) or personal settings and it will sync updated data back to your computer with AES 128-bit encryption (Windows only).Key Features:
  • Back up, synchronize and secure your files & settings
  • Extractable integrated USB cable & protective cap
  • Portable: compact, thin, lightweight, bus-powered
  • Exclusive, elegant, glossy design by Sam Hecht
System Requirements:
  • PC or Mac with USB 2.0 interface
  • Windows 2000, Windows XP, Windows Vista / Mac OS X 10.3 or higher
  • 32MB RAM minimum
  • Internet connection for software & documentation updates
Specification Description
Model 301841, 301841-
UPC 093053760168
Buffer 8MB
Computer Compatibility PC and Macintosh
Connection External
Data Transfer Rate 480Mbps Maximum External
Drive Capacity 500GB
Interface USB 2.0 USB
Port Compatibility USB
Power USB
Rotational Speed 5400 rpm
Select Pocket Hard Drives
Select Capacity 500 GB
Storage Capacity 500GB
Type of Drive Hard Drive
LaCie 500GB Little Disk USB 2.0 Portable Hard Drive Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 4, 2009
LaCie 500GB Little Disk USB 2.0 Portable Hard Drive Reviews
Most helpful positive review
[24 of 24 customers found this review helpful]
Most helpful negative review
[35 of 41 customers found this review helpful]
4.0
LaCie Little Disk 500 GB USB
"This HD drive works very well. The only problem I have that it requires more power than normal USB port can supply. So I have to use two of my USB ports on my MacBookPro. One port is used to supply power other to connect to USB. I tried to use only one USB port, but drive would mount and then dismount. It was unworkable. After LaCie tech support explained power problem everything works fine...." Read Full Review »
Sep 21, 2008 by Richard Basecki
See more positive LaCie 500GB Little Disk USB 2.0 Portable Hard Drive reviews
1.0
Flawed drive---died after two days
"I had high hopes for this portable drive. The form factor is great, and the pull-out USB cable is a nice touch. It mounted easily on my MacBook Pro and did not need the included power cable. Backup speeds were great and the drive was totally silent. Guess they don't have a fan built in. Which is why I suspect this drive is a bust. It was reliably backing up my MBP using Time Machine every hour yesterday morning..." Read Full Review »
May 23, 2008 by David Toub
See more negative LaCie 500GB Little Disk USB 2.0 Portable Hard Drive reviews
Displaying 1 - 5 of 40 Reviews
Show
Sort by
1.0
Which is wh …"  Read Full Review »
Was this External Computer Hard Drive review on the LaCie 500GB Little Disk USB 2.0 Portable Hard Drive helpful to you?
 Report Abuse  (35)  (6)  0 comments
May 23 2008
David Toub
Wyncote, PA United States
Reviewed at:
Price: $122.99
4.0
"This HD drive works very well. The only problem I have that it requires more power than normal USB port can supply. So I have to use two of my USB ports on my MacBookPro. One port is used to supply power other to connect to USB. I tried to use only one USB port, but drive would mount and then dismou …"  Read Full Review »
 Report Abuse  (24)  (0)  0 comments
Sep 21 2008
Richard Basecki
San Jose, CA
Reviewed at:
Price: $122.99
[6 of 6 customers found this review helpful]
Cost impacts performance
3.0
"Often times I need to offload my media shoots in the field. Whether video, voice/music recordings, or RAW camera image, this 500GB drive is an excellent companion to my laptop. It's small footprint makes it easy to transport, and it's low price makes it much more affordable than carrying around spar …"  Read Full Review »
 Report Abuse  (6)  (0)  0 comments
Jan 1 2009
PeterP
Spectacular California, USA
Reviewed at:
Price: $122.99
[10 of 10 customers found this review helpful]
Great portable storage!
5.0
"This drive, with a few caveats, is one of the best external storage purchases I have ever made. It is lightweight, fast, and imminently portable. Since it is bus powered, there is one fewer adaptor to carry around - however - this does not always work. On older computers, it is often necessary to …"  Read Full Review »
 Report Abuse  (10)  (0)  0 comments
Nov 1 2008
A. C. Kraus
Amazon
Reviewed at:
Price: $122.99
[1 of 2 customers found this review helpful]
A somewhat delicate drive
3.0
    Pros
  • Cables included
  • Cost-effective
  • Easy To Setup
  • High Capacity
  • Portable
    Cons
  • Delicate
    Best Uses
  • Laptop
  • Media Backup
  • PC & Mac
"Often times I need to offload my media shoots in the field. This 500GB drive makes for an excellent companion to my laptop. It's small footprint makes it easy to transport, and it's low price makes it much more affordable than carrying around spare flash media. A clever design includes a built-in US …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Jan 6 2009
PeterP
Los Angeles
I am:
  • Power user
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
