LaCie 324 24" Widescreen LCD Computer Monitor
#265
4.0
based on 10 reviews
Ratings Distribution
5 star
6
4 star
1
3 star
1
2 star
1
1 star
1
Category Average
4.4
$859.95 - $945.99
from 8 stores
More Images
Pros
  • Great picture quality (9)
  • Vivid colors (9)
  • Adjustable (7)
  • Easy setup (3)
  • Accurate colors (2)
  • Lightweight (2)
  • Versatile (1)
  • Wide color gamut (1)
See less See more
Cons
  • Confusing / difficult controls (1)
  • High power consumption (1)
  • Inaccurate colors (1)
  • Input lag (1)
  • Non uniform brightness (1)
  • Non uniform color (1)
  • Pixel persistence (1)
  • Poor adjustability (1)
  • Poor instructions / manual (1)
Best Uses
  • Multimedia (3)
  • Adobe rgb workflow (1)
  • Advanced graphics (1)
  • Home computer (1)
  • Hooked to a laptop (1)
  • Photo color correction (1)
  • Photo editing (1)
  • Photography (1)
  • Pro photography (1)
  • Srgb workflow (1)
Provided by PC Mall
130778 24" 324 LCD Monitor Delivers 1000:1 contrast ratio, 0.27mm pixel pitch, 1920 x 1200 maximum resolution, wide 178 viewing angles, 6ms response time, 3-port usb 2.0 hub & audio port,VGA/DVI/HDMIx2, supports 1080p Designed for creative professionals in both fixed and motion imaging, the 24-inch widescreen LaCie 324 embeds an industry-leading wide gamut (95% Adobe RGB / 99.7% of ISO Coated) S-PVA panel and a 10-bit gamma correction mechanism, which ensure smooth and vivid colors in artwork, photography and layout. Thanks to DCDi by Faroudja video enhancement technology, its excellent for audio/video editing, 3D CAD and game development, performing flawlessly with HDMI, DVI and VGA video sources up to and including Full HD 1080p. The LaCie 324 is also available bundled with the LaCie blue eye pro our advanced single-click hardware calibration solutionPremium Image RenderingThe LaCie 324 is equipped with an industry-leading wide-gamut S-PVA panel that covers 95% of the Adobe RGB gamut and 99.7% of ISO Coated. This large range of vibrant colors, previously unattainable on LCD monitors, ensures your artwork is as colorful as you can imagine. Thanks to its embedded 10-bit gamma correction, the LaCie 324 calculates color transitions with twice as much precision as regular 8-bit monitors. The result is it offers smoother renditions of gradients and minimizes banding.Full HD Video PerformanceThe LaCie 324 also performs flawlessly with video up to and including Full HD 1080p sources. With its embedded DCDi by Faroudja** and TrueLife video technologies, you can be sure video content appears at its best. It offers not only conventional VGA and DVI inputs, but also two HDCP-compatible HDMI ports for a maximum of four simultaneously connected video sourcesand 2 simultaneously displayed sources through its Picture-in-Picture feature.State-of-The-Art Calibration SolutionThe LaCie blue eye pro software and colorimeter (available bundled or separately) perform single-click hardware calibration of your display and produce an advanced ICC profile that ensures color consistency throughout your workflow. LaCie blue eye pro is a full-featured color management tool that is simple to use, fast and precise. Its Test & Report function allows you to verify that calibration is and stays accurate. Advanced features, such as manual fine-tuning, reference profile matching and colorimetric environment switching help you achieve an even closer match between captured, displayed and printed colors.Ideal For Your Work EnvironmentDesigned to optimize your work environment, the LaCie 324s large 24" diagonal and 16:10 format enhance productivity and allow full 1:1 scale display of two letter-sized or A4 pages with extra space for toolbars. Its USB 2.0 hub and headphone port are conveniently within reach so you can easily connect your peripherals. All monitor controls are easily accessible through the monitors touch-sensitive interface. For professionals working in the brightest environments, the optional easyHood simply clips into a stable position where it blocks out ambient light.
Specification Description
Model 130778
UPC 093053741518
Select Flat Panel LCD
Viewable Size 24"
LaCie 324 24" Widescreen LCD Computer Monitor Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 15, 2009
LaCie 324 24" Widescreen LCD Computer Monitor Reviews
Most helpful positive review
[6 of 6 customers found this review helpful]
Most helpful negative review
5.0
Good Monitor; RGB controls hidden
"The monitor is clear, bright, and beautiful, and has a wide gamut for color calibration work with photos. I like the monitor. I hate the manual. It does not mention how to find the RGB controls, which are very well hidden. To find them, you have to display the onscreen menu, then select a color temperature of "Custom." Then push the "Input" button. Nowhere in the manual are the RGB controls even mentioned, let a..." Read Full Review »
Jul 28, 2008 by mewickham
See more positive LaCie 324 24" Widescreen LCD Computer Monitor reviews
2.0
LaCie Not To Be
"I had my hopes high for this monitor but I was disappointed badly for the color and brightness not being uniform across the display. My monitor was magenta on the right and greenish on the left also brighter on the left and darker on the right. Color gamut was great but not useful since uniformity was not there. Power consumption was on the high side too. Top of the monitor felt quite warm. USB hub was a nice fe..." Read Full Review »
Sep 03, 2009 by Mo007
See more negative LaCie 324 24" Widescreen LCD Computer Monitor reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
5.0
    Pros
  • Sharp Image
  • Vivid Colors
    Cons
  • Poor Manual
    Best Uses
  • Photo Color Correction
"The monitor is clear, bright, and beautiful, and has a wide gamut for color calibration work with photos. I like the monitor. I hate the manual. It does not mention how to find the RGB controls, which are very well hidden. To find them, you have to display the onscreen menu, then select a color temp …"  Read Full Review »
Was this LCD Monitor review on the LaCie 324 24" Widescreen LCD Computer Monitor helpful to you?
 Report Abuse  (6)  (0)  0 comments
Jul 28 2008
mewickham
Rogers, AR
I am:
  • Quality Oriented
Reviewed at:
Price: $859.95
[3 of 3 customers found this review helpful]
Outstanding Color, Some Lag
5.0
    Pros
  • Adjustable
  • Lightweight
  • Sharp Image
  • Vivid Colors
    Cons
  • Input Lag
  • Pixel Persistence
    Best Uses
  • Photo Editing
"Just purchased this monitor and before I even calibrated it, I could see a difference from my old Mitsubishi 2060u. After calibrating with my GMB i1 Display 2, it was amazing. The advertised color gamut is no lie, the greens look outstanding. Unfortunately, aside from photo editing, I also do gam …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Oct 5 2008
Eärendil
Denver, CO
I am:
  • Quality Oriented
Reviewed at:
Price: $859.95
Absolutely LOVE it !!!
5.0
    Pros
  • Accurate color
  • Adjustable
  • Sharp Image
  • Versatile
  • Vivid Colors
    Cons
  • None
    Best Uses
  • Multimedia
  • Pro Photography
"This monitor came highly recommended from other pros and I have to tell you, I was very pleased right from the moment I turned the monitor on. Not only is the real estate an impressive 24", after tweaking with a reputable calibrator, the accuracy of the color is right on. Can't complain about the …"  Read Full Review »
Jun 30 2008
Debbie pro photographer
Saxonburg, PA
I am:
  • Quality Oriented
Reviewed at:
Price: $859.95
LaCie Not To Be
2.0
    Pros
  • Adjustable
  • Easy Setup
  • Sharp Image
  • Vivid Colors
  • Wide Color Gamut
    Cons
  • Non uniform color
    Best Uses
  • Photography
"I had my hopes high for this monitor but I was disappointed badly for the color and brightness not being uniform across the display. My monitor was magenta on the right and greenish on the left also brighter on the left and darker on the right. Color gamut was great but not useful since uniformity w …"  Read Full Review »
Sep 3 2009
Mo007
Maryland
I am:
  • Quality Oriented
Reviewed at:
Price: $859.95
Awesome Monitor!
5.0
    Pros
  • Adjustable
  • Lightweight
  • Sharp Image
  • Vivid Colors
    Cons
  • None
    Best Uses
  • None
"I am a photographer who runs his business from his home. A color calibrated monitor is a must for me. Anyway, when my old CRT took on a greenish hue, I knew it was time to upgrade.
After reading reviews of monitors, I settled on the LaCoe 324. (I also have an Apple 20" Cinema Display hooked up …"  Read Full Review »
May 14 2009
Greg
Missouri
I am:
  • Quality Oriented
Reviewed at:
Price: $859.95
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
