LaCie 2-Port eSATA PCI Adapter Card
#28
5.0
based on 2 reviews
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
3.9
$29.95 - $39.99
from 9 stores
More Images
Pros
  • Highly compatible (2)
  • Reliable (2)
  • Durable (1)
  • Easy to install (1)
  • Fast (1)
  • Improves performance (1)
  • Quiet (1)
  • Strong connection points (1)
See less See more
Best Uses
  • High-end equipment (1)
  • High-end multimedia (1)
Provided by MacMall
eSATA PCI Card Design by Sismo Provides two independent channels to support up to two SATA drives at once. Easily and affordably add two eSATA ports to your desktop computer. Unique, exclusive design by Sismo. Easily and affordably add two eSATA ports to your desktop computer with the LaCie eSATA PCI Card designed by Sismo, which provides two independent channels to support up to two SATA drives at once. It supports (under MacOS X and Windows OS) RAID 0 (striping) for speed and RAID 1 (mirroring) for data protection. eSATA boasts a maximum interface transfer rate of up to an incredible 1.5Gbits/s, making it the fast interface choice of demanding professionals. This versatile card has a 32-bits PCI form factor for superior compatibility with all motherboard sizes. The unique, exclusive design by Sismo comes with a dedicated gripping pad for electrostatic discharge protection. Conveniently plug & play and driver-free for Mac OS, its easy to use. Quickly connect eSATA devices, such as fast external hard drives, for impressive speed and performance on your PC or Mac.Key Features:
  • Add two eSATA ports to your computer
  • Unique, exclusive design by Sismo
  • Convenient: plug & play, hot plug/unplug support
  • Fast max interface transfer rate up to 150MB/s
  • Anti-static gripping pad
Technical Specifications:
    Interface: 2 external eSATA connectorsTransfer Rate: Up to 1.5Gbits/s (150MB/s)Compliance: PCI specification rev. 2.3; Serial ATA 1.0 specification; Serial ATA 2 Native Command Queuing (NCQ)Supported RAID levels: (Native MacOS.x utilities) RAID 0 (striping), RAID 1 (mirroring)System Requirements
    • PC or Mac with a PCI slot (32bits/33MHz) or PCI-X slot (64bits/33MHz)
    • Windows 2000, Windows Server 2003, Windows XP (32/64bit), Windows Vista (32/64bit)
    • Mac OS X 10.3 or higher
    • 128MB RAM minimum
    • Driver-free for Mac OS**
    • **This card must be set up with a jumper located directly on the PCB in order to be used with a Mac computer. By changing the jumper setting on the card, you can use it with a PC or Mac.
Specification Description
Model 130823
UPC 093053762339
Connectivity Type Serial - General
Controller Type SATA RAID Controller
Interface PCI
Select SATA/eSATA Cards
Select Platform Windows,Macintosh
LaCie 2-Port eSATA PCI Adapter Card Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 23, 2009
LaCie 2-Port eSATA PCI Adapter Card Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Everything I expected
5.0
    Pros
  • Durable construction
  • Highly Compatible
  • Improves Performance
  • Reliable
  • Strong Connection Points
    Cons
  • None
    Best Uses
  • High-End Equipment
"I do a lot of video work on this computer and needed a terabyte external hard drive with some speed, because video work takes long enough without hardware bottlenecks. The SATA card that I purchased enabled me to connect to a couple of terabyte external drives with noticeable performance boosts. Ins …"  Read Full Review »
Was this Computer Expansion Card review on the LaCie 2-Port eSATA PCI Adapter Card helpful to you?
 Report Abuse  (1)  (0)  0 comments
Mar 4 2009
Park
Manchester NH
I am:
  • Quality Oriented
Reviewed at:
Price: $34.99
Great Card!
5.0
    Pros
  • Easy To Install
  • Fast
  • Highly Compatible
  • Quiet
  • Reliable
    Cons
  • None
    Best Uses
  • High-End Multimedia
"Great card! I use it to link external drives to store video/audio files and it has fantastic transfer time. Works just as fast as an internal SATA drive. Easy to install and up in about 10 minutes total! "
Jun 23 2009
Derek
McKinney, TX
I am:
  • Heavy Duty User
Reviewed at:
Price: $29.95
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
