LaCie 107435 USB 2.0 PCI Card
4.0
based on 3 reviews
Ratings Distribution
5 star
1
4 star
1
3 star
1
2 star
0
1 star
0
Category Average
3.9
More Images
Pros
  • Easy to install (3)
  • High quality (2)
  • Highly compatible (2)
  • Powerful (1)
See less See more
Cons
  • Bad for usb audio (1)
Best Uses
  • Upgrade (2)
  • Standard peripherals (1)
Provided by Beach Audio
USB 2.0 opens up a whole new realm of possibilities for connecting high-speed devices. Attach an external USB 2.0 hard drive and achieve transfer rates of up to 20MB/sec; burn a full CD in less than 3 minutes by utilizing a 52x USB 2.0 CD-RW; or stream large video files to an external DVD burner.
By upgrading your USB interface, utilizing high performance LaCie USB 2.0 devices has never been easier. The LaCie USB 2.0 PCI Card allows users with Microsoft Windows 98 SE, Windows Me, 2000 and XP to take full advantage of the new enhanced speeds that USB 2.0 offers with a simple connection.
With four external ports and one internal, the LaCie USB 2.0 PCI Card gives you the flexibility to attach up to 127 different peripherals and the ability to add or remove devices without shutting down the computer. The card automatically recognizes and optimizes the bandwidth for the devices connected, running at either Hi-speed USB 2.0 (480Mb/s), full-speed USB 1.1 (12Mb/s) or low-speed (1.5Mb/s).
Specification Description
Model 107435, LAC107435
UPC 093053274351
Accessory Indicator Yes
Benefits Supplies data transfer speeds up to 480MbpsOffers innovative plug-and-play technologyCompatible with USB 1.1 and USB 2.0 por
Capacity UOM mAh
Country Of Origin United Arab Emirates
Description Header Blazingly fast data transfer.
Display Catalog Number 55010011
Manufacturer Labor Warranty 12
Manufacturer Part Number 107435
Manufacturer Parts Warranty 12
MAP Price 0.0
Model 107435
Operating Temperature UOM ° F
Product Disclaimer PCI card is not compatible with PCI-E slots.
Product Type USB
Required to function Windows® 98SE, Windows 2000, Windows ME, Windows XP
Supported Languages English
LaCie 107435 USB 2.0 PCI Card Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 107435 USB 2.0 PCI Card
See all eBay results
  at eBay.com
Product Reviews
Last update: Aug 15, 2008
LaCie 107435 USB 2.0 PCI Card Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
Installs easy. Works as promised.
4.0
    Pros
  • Easy To Install
  • High Quality
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Upgrade
"The LaCie USB-2 PCI Card [...] was well-protected as packed by B&H and by the manufacturer (solid PET clamshell). It slid easily into the PCI slot, was immediately recognized upon power up, and functioned as promised. The one internal USB connector allows hooking a USB drive or peripheral internal …"  Read Full Review »
Was this Computer Expansion Card review on the LaCie 107435 USB 2.0 PCI Card helpful to you?
Aug 15 2008
Jim
Pueblo West, CO
I am:
  • Value Oriented
Reviewed at:
Rebranded USB Hub
3.0
    Pros
  • Easy To Install
    Cons
  • Bad for USB Audio
    Best Uses
"This is not a Universal Host Controller, and not quite up to par for demanding USB Audio devices. "
Sep 20 2007
J the Sound Guy
Santa Barbara, CA
I am:
  • Power User
  • Quality Oriented
Reviewed at:
FAST FAST FAST
5.0
    Pros
  • Easy To Install
  • High Quality
  • Highly Compatible
  • Powerful
    Cons
  • None
    Best Uses
  • Upgrade
"bOY IS THIS FAST COMPARED TO THE OLD 1.1 USB! "
Apr 1 2008
Big John
Big Bear City, CA
I am:
  • Quality Oriented
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
