La Crosse Technology Wireless Weather Icons Station
#109
3.8
based on 25 reviews
from $31.95
Ratings Distribution
5 star
8
4 star
11
3 star
2
2 star
0
1 star
4
Category Average
3.7
$31.95 at Sierra Trading Post
Find it at Amazon
Find it at Ebay
Pros
  • Easy to configure (16)
  • Consistent performance (15)
  • Easy to use (8)
  • Durable (5)
  • Attractive design (2)
  • Versatile (2)
  • Easy assembly (1)
  • It was a gift (1)
See less See more
Cons
  • Unreliable (3)
  • I have not found any yet (1)
  • Monitor flawed (1)
  • Secure the sending unit (1)
  • Winds will toss send unit (1)
Best Uses
  • Home (9)
  • Portable devices (2)
  • Travel (2)
  • Bedroom (1)
  • Great for upstairs bedrm (1)
  • Home use (1)
  • In our home (1)
  • Kitchen (1)
  • Living room (1)
  • Outdoors (1)
Provided by Sierra Trading Post
Closeouts . Monitor the weather outdoors and your comfort level indoors with this La Crosse wireless forecast weather icons station. Gives forecast information based on changing air pressure Current conditions and time help plan your day Indoor - outdoor temperature Indoor humidity Accurate digital timekeeping Records minimum and maximum temps Base and sensor each require two AA batteries (not included) Weather station (LxWxD): 10x3x2-¾" Weather sensor (LxWxD): 5-¼x1-½x1" Display screen: 5x1" Material: Composite Closeouts . China.
La Crosse Technology Wireless Weather Icons Station Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 31, 2009
La Crosse Technology Wireless Weather Icons Station Reviews
Most helpful positive review
Most helpful negative review
4.0
As described and works well
"It was easy to configure the remote unit by following the instructions. It would be nice to know the accuracy - I think it is within 2 to 4 degrees F. I listed travel as I plan on using with my RV to have a reading under the awning. The trend forecast has been very accurate for showing fronts coming through. I would recommend this unit for average use...." Read Full Review »
Mar 05, 2009 by On the Road Again
See more positive La Crosse Technology Wireless Weather Icons Station reviews
1.0
Outdoor temperature not accurate
"Out of the box I set up the weather station. I put the "inside thermometer" 5 feet from the "outside thermometer." The indoor reading was accurate when compared to the thermostat on the furnace, but the outdoor read 5 to 8 degrees warmer...." Read Full Review »
Jul 12, 2009 by Guy in Rapid
See more negative La Crosse Technology Wireless Weather Icons Station reviews
Displaying 1 - 5 of 25 Reviews
Show
Sort by
4.0
    Pros
  • Consistent Performance
  • Easy To Configure
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home
  • Travel
"It was easy to configure the remote unit by following the instructions. It would be nice to know the accuracy - I think it is within 2 to 4 degrees F. I listed travel as I plan on using with my RV to have a reading under the awning. The trend forecast has been very accurate for showing fronts comi …"  Read Full Review »
Was this Weather Station review on the La Crosse Technology Wireless Weather Icons Station helpful to you?
Mar 5 2009
On the Road Again
Falls Church, VA
I am:
  • Enthusiast
I am very happy with my weather station
5.0
    Pros
  • Easy To Configure
    Cons
    Best Uses
"I have been wanting a place to see the outside temperature in the bedroom. I am so happy with this unit. It measures so many things besides the outside temp. It is tall and thin so it fits anywhere. So far it has measured the temp both inside and outside accurately for the short time I have had …"  Read Full Review »
Jan 18 2009
Babette
Southbury, CT
I am:
  • Casual User
Just purchased my 3rd station
5.0
    Pros
  • Durable
  • Easy To Configure
  • Versatile
    Cons
    Best Uses
  • None
"Always tells me inside/outside temp & inside relative humidity, which is useful in our timber frame home, since moisture has effect on timbers, if extra dry.
Visual readout tells which direction the weather is going (sun/rain) & if in a high or low pressure zone. "
Jan 21 2009
Leanne Smith
Sisters, OR
I am:
  • Enthusiast
performs as advertised
4.0
    Pros
  • Easy To Configure
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home
"My only disappointment is that the remote sensor has to be put out of the rain. I had wanted something that I could place away from the house to get a truer temperature reading. It seems to be accurate and reliable. "
Sep 14 2009
Laser Lass
Cabot Vermont
I am:
  • Casual User
1.0
    Pros
  • Easy To Use
    Cons
  • Unreliable
    Best Uses
  • Home
"Out of the box I set up the weather station. I put the "inside thermometer" 5 feet from the "outside thermometer." The indoor reading was accurate when compared to the thermostat on the furnace, but the outdoor read 5 to 8 degrees warmer. "
Jul 12 2009
Guy in Rapid
Rapid City, SD
I am:
  • Casual User
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
