La Crosse Technology Dual Wireless Temperature Stations
#44
3.9
based on 18 reviews
Ratings Distribution
5 star
5
4 star
9
3 star
2
2 star
1
1 star
1
Category Average
3.9
$37.95 at Sierra Trading Post
Find it at Amazon
Find it at Ebay
$37.95
from 1 store
Pros
  • Attractive design (11)
  • Simple / intuitive controls (9)
  • Lightweight (7)
  • Compact (4)
  • Durable (4)
  • Easy assembly (4)
  • Accurate (1)
  • Delivers info we desire (1)
  • Good price (1)
  • Looks good enough (1)
See less See more
Cons
  • Flimsy (2)
  • Did not work well (1)
  • Difficult start up (1)
  • Heavy / bulky (1)
  • Instructions a bit wordy (1)
  • Lacks readings i desired (1)
  • Must read inst first (1)
Best Uses
  • Home (13)
  • Bedroom (3)
  • Kitchen (3)
  • Office (2)
  • Outdoors (2)
  • Upstairs and downstairs (1)
Provided by Sierra Trading Post
Closeouts . Monitor temperature and humidity data in two separate locations using La Crosse Technology's dual Wireless Temperature Station. Each base unit displays indoor temperature, outdoor temperature and humidity from the remote sensor. Each unit requires two AA batteries (not included) Weather stations (LxWxD): 8x3x2-¾” Transmitter (LxWxD): 4-7/8x2-¼x2-¾” Display screen: 2-3/8x1-¼” Material: Composite Closeouts . China.
La Crosse Technology Dual Wireless Temperature Stations Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 31, 2009
La Crosse Technology Dual Wireless Temperature Stations Reviews
Most helpful positive review
Most helpful negative review
5.0
Set up was a piece of cake.
"Set up was a breeze - I gave the directions to our son with a pack of batteries. He followed the directions and said wait a while before setting the time. So I did. I made sure all the readings were the same and then I put the remote sensor outside. Worked perfectly the first time. I'm surprised how high our humidity is! Our climate is high mountain desert, sagebrush. See? You need this outfit...." Read Full Review »
Jun 17, 2009 by Rockbopp
See more positive La Crosse Technology Dual Wireless Temperature Stations reviews
3.0
Dual Temp Stations
"I bought this weather station for the fact that it read the temperature inside and out and the fact that read seperate room temperatures indoors. I was a little disappointed that the item description did not specify all of the readings that the product has because I wanted a barometer reading as well which this product does not have. Overall it is easy to use and display is easy to read. I would recommend thi..." Read Full Review »
Feb 09, 2009 by springyj
See more negative La Crosse Technology Dual Wireless Temperature Stations reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
Dual Temp Stations
3.0
    Pros
  • Attractive Design
  • Compact
  • Easy Controls
  • Good price
    Cons
  • Lacks readings I desired
    Best Uses
  • Home
  • Office
"I bought this weather station for the fact that it read the temperature inside and out and the fact that read seperate room temperatures indoors. I was a little disappointed that the item description did not specify all of the readings that the product has because I wanted a barometer reading as we …"  Read Full Review »
Was this Home Electronics & Gadget review on the La Crosse Technology Dual Wireless Temperature Stations helpful to you?
Feb 9 2009
springyj
Billings, MT
I am:
  • Casual User
5.0
    Pros
  • Compact
  • Looks good enough
  • Sits perfectly on a shelf
    Cons
  • None
    Best Uses
  • Home
"Set up was a breeze - I gave the directions to our son with a pack of batteries. He followed the directions and said wait a while before setting the time. So I did. I made sure all the readings were the same and then I put the remote sensor outside. Worked perfectly the first time. I'm surprised how …"  Read Full Review »
Jun 17 2009
Rockbopp
Blaine County, Idaho
I am:
  • Enthusiast
Easy to set up, but reception is sketchy
3.0
    Pros
  • Attractive Design
  • Easy To Assemble
    Cons
  • Flimsy
    Best Uses
  • Bedroom
  • Kitchen
  • Outdoors
"I bought this for my parents.
The set-up is easy (no syncing steps), just plug and go. My main difficulty was that the two units constantly read a different outdoor temperature (as transmitted from the single outdoor weather station). The signal would also go in and out on the nearest receiver.
Dec 3 2008
New England Duck Hunter
New England
Reliably delivers data
4.0
    Pros
  • Easy to put together
  • Takes up little space
    Cons
  • MUST read inst first
    Best Uses
  • Home
"I use the product several times throughout the day to not only track conditions and trends but to plan outdoor activities. I can see the display from bed without the aid of my glasses before I even arise. I have had no difficulties with the device and am pleased with its performance. "
Jan 19 2009
Flatwater Kayaker
St. Charles, MO
I am:
  • Enthusiast
Some start up issues
4.0
    Pros
  • Accurate
  • Compact
    Cons
    Best Uses
  • Home
"Product worked well once all of the inherent limitations were overcome. i.e. line of sight and proximity to outdoor probe. Triangulation with two indoor units wasn't as easy as it sounds.
Unit was more sensitive to proximity than unit it replaced. Once locations were worked out unit has been gre …"  Read Full Review »
Mar 17 2009
Handy Dad
Munster Ind
I am:
  • Casual User
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
