Kustom KSE10MLI Two Way 10 Floor Monitor
4.0
based on 1 review
Ratings Distribution
5 star
0
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.4
More Images
Pros
  • Attractive design (1)
  • Compact (1)
  • Easy to connect (1)
  • Flexible (1)
  • Great sound quality (1)
See less See more
Best Uses
  • Basic systems (1)
  • Build a system (1)
  • Large rooms (1)
  • Smaller rooms / apartments (1)
Provided by PSSL.com - ProSound and Stage Lighting
KUSTOM KSE10MLI TWO WAY 10" FLOOR MONITORThe Kustom KSE 10MLI monitor speaker is a full-featured unit that is perfect for use on any stage. Handling 75 watts (150 Peak), the 10MLI utilizes a heavy-duty 10-inch Kustom P.A. speaker with a High Frequency Driver for the high-end. It's built using time-tested construction methods and is covered in a durable vinyl material with protective corners.But that's just part of the story. Kustom monitors also have totally unique features that can make your life a lot easier! For example, Kustom monitors have a built-in volume attenuator. A simple feature, but perfect for those on-the-fly stage adjustments needed to satisfy everyone on stage. Plus, they also have a built-in Impedance switch. Now you can use additional monitors without the need for additional power amps. A simple but effective solution to an age-old problem!Features:10" woofer2" x 6" hornInternal crossover1/4" Parallel ConnectorsRubber strap handle1-3/8" polemount30/60/90? positioning
Kustom KSE10MLI Two Way 10 Floor Monitor Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: KSE10MLI Two Way 10 Floor Monitor
See all eBay results
  at eBay.com
Product Reviews
Last update: Mar 25, 2008
Kustom KSE10MLI Two Way 10 Floor Monitor Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
Forward thinking, great concept!
4.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Connect
  • Flexible
  • Great Sound Quality
    Cons
  • None
    Best Uses
  • Basic Systems
  • Build a system
  • Larger Rooms
  • Smaller Rooms
"With the attenuation (volume) control and the switchable impedance button, you can provide monitored stage sound to any situation without having to add more power amps. "
Was this Speaker & Subwoofer review on the Kustom KSE10MLI Two Way 10 Floor Monitor helpful to you?
Mar 25 2008
Mango Mike
Tampa Bay, Florida
I am:
  • Musically Inclined
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
