KRK Systems RP5 Rockit 5 Inch Powered Monitor (Each)
4.5
based on 2 reviews
from
Ratings Distribution
5 star
1
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.4
More Images
Pros
  • Great sound quality (3)
  • Attractive design (2)
  • Compact (2)
  • Durable (1)
  • Easy setup (1)
  • Easy to connect (1)
  • Powerful (1)
  • Priced right (1)
See less See more
Cons
  • Wish i had a subwoofer (1)
Best Uses
  • Basic systems (2)
  • Smaller rooms / apartments (2)
  • Audiophiles (1)
  • Entertainment (1)
  • Great starter system (1)
  • Pro audio / dj / mixing (1)
  • Production quality (1)
  • Small home studio's (1)
Provided by PSSL.com - ProSound and Stage Lighting
KRK ROKIT POWERED RP-5 MONITORS: Powered Studio Reference MonitorsThe KRK ROKIT Powered RP-5 studio monitors feature several of the key design elements found in KRK's premium models, many of which have become the ?studio standard? for the world's finest engineers, producers and musicians. Now, you can have that same KRK sound, attention to detail and commitment at a price that makes Rokit Powered a truly uncommon value.The KRK Rokit Powered RP-5 monitors feature a proprietary yellow woofer made of a woven glass aramid composite that delivers a tight low-end response and a soft dome tweeter for natural sounding highs. The drivers are electronically crossed over and are bi-amped for increased efficiency. All of this is housed in an attractive cabinet with radiused corners that reduce edge diffraction resulting in better audio imaging. The rear input panel features phone plug and XLR connectors to accommodate any application.Features:Great sounding powered monitors75 watt biamped dynamic power5" glass aramid composite woofer1" neodymium soft dome tweeter with ferro fluidInputs: XLR (3-pin), RCA & 1/4" TRS - 10k ohm; balanced/unbalancedFrequency response: 53Hz - 20kHzVideo shieldedSize: 10-7/8"h x 7-1/4"w x 8-7/8"d. Wt. 16 lbs.
KRK Systems RP5 Rockit 5 Inch Powered Monitor (Each) Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: RP5 Rockit 5 Inch Powered Monitor (Each)
See all eBay results
  at eBay.com
Product Reviews
Last update: Jun 4, 2008
KRK Systems RP5 Rockit 5 Inch Powered Monitor (Each) Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Good for Small Home Studio's
5.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Mixing
  • Small Home Studio's
  • Smaller Rooms
"These are nice Monitors for small home studios. Good Bass response. I use them primarily with my Boss BR-1600 for Turntablism, Hip Hop & Hard Rock/Metal Projects.
I also have Auralex MO-PAD Studio Monitor Isolation Pads under them to help isolation from the computer desk there on. I find them quite …"  Read Full Review »
At home
At home
  • Picture of Product
Take em to work with My BR1600
  • Portable
  • Using Product
Was this Speaker & Subwoofer review on the KRK Systems RP5 Rockit 5 Inch Powered Monitor (Each) helpful to you?
Jun 4 2008
DJ Scratch Eklektik
Nor-Cal
I am:
  • Musically Inclined
  • Musician very critical
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
A nice way to start out.
4.0
    Pros
  • Attractive Design
  • Clear sound
  • Compact
  • Durable
  • Easy To Set Up
  • More »
    Cons
    Best Uses
  • Audiophiles
  • Basic Systems
  • Entertainment
  • Great Starter System
  • More »
"If your just starting out, these will be perfect for you. And you'll be surprised how nice they sound. "
May 29 2007
Dj Jerm
Everett, WA
I am:
  • Audiophile
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
