Kodak 8" EasyShare M820 Digital Photo Frame with Home Decor Kit
#33
4.5
based on 15 reviews
Ratings Distribution
5 star
11
4 star
2
3 star
1
2 star
1
1 star
0
Category Average
3.7
Low Price:
$92.50 at B&H Photo Video
 Trusted:
$99.95 at Adorama
$99.22 at pcRUSH
see all stores
$92.50 - $119.99
from 7 stores
Pros
  • Easy to use (2)
  • Easy setup (1)
  • Fast (1)
  • Good size (1)
  • Great image clarity (1)
  • Quality construction (1)
  • Quick set up (1)
  • Stylish (1)
  • Touchscreen (1)
See less See more
Cons
  • Complicated controls (1)
Best Uses
  • Desk (2)
  • Collage (1)
  • Digital photos (1)
  • Gift (1)
  • Home (1)
  • Office (1)
  • Photography display (1)
  • Special occasion (1)
  • Table top (1)
  • Wall (1)
Provided by Beach Audio
Device TypeDigital photo frame
Key FeaturesDigital audio player, digital photo viewer, memory card reader, digital video player
Width10.2 in
Depth1.3 in
Height7.1 in
PC InterfacesUSB
Display
Display TypeTFT 8" - color
Display Form FactorBuilt-in
Image Aspect Ratio16:9
Image Contrast Ratio300:1
Image Brightness250 ANSI lumens
Display Format800 x 480
Memory / Storage
Flash Memory Cards SupportedMemory Stick, MultiMediaCard, SD Memory Card, xD-Picture Card, CompactFlash Card, SDHC Memory Card
Integrated Flash Memory128 MB
Still Images
Supported Still Images FormatsJPEG, EXIF
Photo Playback ModesAuto slide show
Digital Audio
Supported Audio FormatsMP3
Audio OutputBuilt-in stereo speakers
Video
Video Playback FormatsMPEG-4, MPEG-1
Connectivity
ConnectionsUSB Audio line-out
Power Adapter
TypePower adapter
Power AdapterAC 110/230 V
Frequency Required50/60Hz
System Requirements
Operating SystemMS Windows XP
Peripheral(s)CD-ROM
System Requirements Details- 600 MHz - RAM 128 MB - HD 200 MB
Miscellaneous
Included Accessories2 x interchangeable frame, faceplate
Environmental Parameters
Min Operating Temperature32 F
Specification Description
Model 1222009, W820
UPC 041771222000
Built-In Devices Card Reader
Resolution 800 x 480
Screen Size 8"
Select Size 8" Diagonal
Kodak 8" EasyShare M820 Digital Photo Frame with Home Decor Kit Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 19, 2009
Kodak 8" EasyShare M820 Digital Photo Frame with Home Decor Kit Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
5.0
Easy! Great Gift.
"I "won" this item at holiday party and just got it up and running in about 30 minutes. This frame was so easy to program and set up, I didn't even look at the directions. I just used my Picasa software, exported a bunch of photos to a thumb drive and plugged it in. I has some nice zoom and pan slideshow effects that are not cheesy. The contrast and black level is very surprising for being an lcd screen. This wa..." Read Full Review »
Dec 07, 2008 by Brian234
See more positive Kodak 8" EasyShare M820 Digital Photo Frame with Home Decor Kit reviews
3.0
Good Picture, Average Functionality.
"This is a good low-end frame if you need one. It plays music and has good picture quality. The controls are semi-complicated, but tolerable once you learn them and have some nice features. Overall it's a fine product...." Read Full Review »
Jan 07, 2009 by swank
See more negative Kodak 8" EasyShare M820 Digital Photo Frame with Home Decor Kit reviews
Displaying 1 - 5 of 15 Reviews
Show
Sort by
Easy! Great Gift.
5.0
"I "won" this item at holiday party and just got it up and running in about 30 minutes. This frame was so easy to program and set up, I didn't even look at the directions. I just used my Picasa software, exported a bunch of photos to a thumb drive and plugged it in. I has some nice zoom and pan slide …"  Read Full Review »
Was this Digital Picture Frame review on the Kodak 8" EasyShare M820 Digital Photo Frame with Home Decor Kit helpful to you?
 Report Abuse  (4)  (0)  0 comments
Dec 7 2008
Brian234
Minneapolis
Reviewed at:
Nice frame, great price
5.0
    Pros
  • Good size
  • Stylish
  • Touchscreen
    Cons
  • None
    Best Uses
  • Collage
  • Home
  • Office
  • Special Occasion
  • Table Top
  • More »
"This frame looks spectacular, even without the frame. If you do use the frame, you can choose between the standard color (white) and two other color bands that are included, which would go over the back color.The touch screen functionality is great, and the picture and video quality is amazing.The o …"  Read Full Review »
Mar 5 2009
Caliche
New York, NY
I am:
  • Photo Enthusiast
Reviewed at:
Price: $99.88
Easy to use, decent product
4.0
    Pros
  • Easy To Use
  • Quick set up
    Cons
  • None
    Best Uses
  • Desk
  • Photography Display
"Seems to be a pretty sturdy well made frame. It was easy to get started up and get using it. I wish they offered more in the "decor" package. Two border colors (red and silver) leave a little to be desired. Also it would be nice if the frame stand was adjustable for angle. "
May 19 2009
fstjb2
Knoxville, TN
I am:
  • Value Oriented
Reviewed at:
3.0
    Pros
  • Great Image Clarity
  • Quality Construction
    Cons
  • Complicated Controls
    Best Uses
  • Desk
  • Digital Photos
  • Gift
"This is a good low-end frame if you need one. It plays music and has good picture quality. The controls are semi-complicated, but tolerable once you learn them and have some nice features. Overall it's a fine product. "
Jan 7 2009
swank
Bozeman, MT
I am:
  • Value Oriented
Reviewed at:
Price: $92.50
A must have
5.0
    Pros
  • Easy To Set Up
  • Easy To Use
  • Fast
    Cons
  • None
    Best Uses
  • None
"The picture quality is excellent and it is quick and easy to set up. The screen is large enough so that you can really enjoy the images. An excellent product that I would recommend to anyone, in fact, I plan to buy another. "
Mar 30 2009
global photographer
West Palm Beach
I am:
  • Quality Oriented
Reviewed at:
Price: $99.95
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
