Klipsch Audio RC-10 Dual 4-inch Tracktrix Center Channel
#190
4.7
based on 10 reviews
from $219.00 - $219.94
Ratings Distribution
5 star
7
4 star
3
3 star
0
2 star
0
1 star
0
Category Average
4.4
More Images
Pros
  • Great sound quality (19)
  • Easy to connect (10)
  • Attractive design (9)
  • Powerful (9)
See less See more
Cons
  • Difficult to level speake (1)
  • Heavy / bulky (1)
Best Uses
  • Home theater (9)
  • Smaller rooms / apartments (5)
  • Basic systems (3)
  • Audiophiles (1)
  • Outdoors (1)
Provided by OneCall
The RC-10 employs dual 4-inch woofers and a 1-inch titanium-dome compression driver loaded with a 4-inch square Tractrix(R) Horn for maximum clarity and efficiency.
This center channel also utilizes Klipsch's Tapered-Array(TM) Technology, a 2.5-way design that minimizes the acoustical interference between drivers that plagues most horizontal center-channel speakers. This technology allows both woofers to create intense bass, while only one works with the tweeter to produce the midrange. The result is a smooth, clear sound not just directly in front of the speaker, but off to the sides as well, where conventional center speakers often exaggerate or mask sounds.
The woofers on the RC-10 still feature Klipsch's distinctive, copper-colored Cerametallic(TM) material. Made with an anodized aluminum, these cones are strong and dent resistant. The anodizing process converts their inner and outer surfaces to ceramic. The outcome is a rigid cone with superb damping characteristics that will not flex or resonate at frequencies within the woofer's operating range.
As in all Reference Series speakers, the RC-10 crossover network is constructed using extremely high-quality components including top-of-the-line internal wiring, polyester film-type capacitors and an air-core inductor to ensure signal purity and proper driver integration.
Available in a black vinyl finish, the RC-10 features a low-diffraction sculpted baffle and a magnetically attached grille for an elegant fit and finish.
Because the design requirements of a center channel are quite challenging, it is difficult to make a modestly sized, horizontally oriented loudspeaker that performs exceptionally. Despite its compact enclosure, the RC-10 easily carries on the Reference Series' high-performance legacy.
Klipsch Audio RC-10 Dual 4-inch Tracktrix Center Channel Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 14, 2009
Klipsch Audio RC-10 Dual 4-inch Tracktrix Center Channel Reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
[4 of 4 customers found this review helpful]
small speaker,big sound!
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None at this price
    Best Uses
  • Home Theater
"I own a substantial home theatre system but am limited in space for the center channel speaker(only have 6"h x 17w"available). I had the rare opportunity to audition 4 speakers in my own living room. The Boston Accoustics (a discontinued model) couldn't handle the power. The Definitive Technology pr …"  Read Full Review »
Was this Speaker & Subwoofer review on the Klipsch Audio RC-10 Dual 4-inch Tracktrix Center Channel helpful to you?
 Report Abuse  (4)  (0)  0 comments
Feb 5 2009
Speedracer
Treasure Island, Florida
I am:
  • Audiophile
  • Musically Inclined
  • Tech Savvy
Reviewed at:
[1 of 1 customers found this review helpful]
A GREAT HELP
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Home Theater
"This Klipsch RC-10 takes the place of an old center speaker. The difference is astounding. My wife & I are hearing impaired & are dependent on CCs. We are both able to turn off the CCs during news programs and it is a pleasure to hear again. This is not a make believe observation. Also, I playe …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Feb 26 2009
Grandpa Billy
Oceanside, CA
I am:
  • Practical
Reviewed at:
Pretty amazing speaker and deal!
5.0
    Pros
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • Large in Size
    Best Uses
  • Home Theater
"I was in search of a stronger center speaker to replace my small old yamaha. I read many review on JR regarding RC-10. It seemed to be the best bang for your buck.[...]hooked it up to my Onky TX-SR606 and was amazed at the sound quality. I no longer have to turn up the volume to hear dialog and then …"  Read Full Review »
Aug 12 2009
Bobbie B.
Los Angeles
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
KLIPSCH RC-10 CENTER CHANNEL SPEAKER
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Home Theater
"Perfect center channel speaker for
Home Theatre System
Incredible depth and dispersion of vocals
Blends with the front channels
Especially with Klipsch Reference Speakers
With Klipsch Surrounds
Very open, clean and crisp.
I was amazed by the sound.
This replaced an INFINITY center chan …"  Read Full Review »
May 2 2009
VAMPIRE44
BIRMINGHAM .AL
I am:
  • Audiophile
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Great sound in a small package
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
    Cons
  • None
    Best Uses
  • Home Theater
  • Smaller Rooms
"My home theater is in a smaller room, so I was looking for a high-quality center channel speaker that would both fit on my TV cabinet and not overwhelm a fairly enclosed space. This speaker fits the bill perfectly. "
Jul 6 2009
JD
Omaha, NE
I am:
  • Practical
  • Tech Savvy
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
