Klipsch Audio R-5502-W (Ea.) In-wall LCR Speaker
#527
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
$399.00 at OneCall
Find it at Amazon
Find it at Ebay
$399.00
from 1 store
More Images
Pros
  • Attractive design (1)
  • Easy to connect (1)
  • Great sound quality (1)
See less See more
Best Uses
  • Basic systems (1)
Provided by OneCall
The R-5502-W employs dual 5.25-inch Cerametallic woofer cones for fast, accurate sound with dynamic detail, while a titanium tweeter mated to a pivoting Tractrix® Horn generates flat in-room frequency response with high efficiency and low distortion. The speaker`s precision-voiced crossover networks further ensure that the high and low frequencies are faithfully reproduced.
This in-wall speaker also consistently delivers thrilling, realistic sound, whether it`s installed horizontally or vertically. It features all-new sure-grip mounting dogs that provide even pressure against drywall for long-term installation reliability, and includes a paintable grille that blends in perfectly with any décor.
Bass and treble switches with custom EQ settings allow the speaker to be tailored to its environment, while IR receiver knockout holes allow for infrared repeaters, bringing custom configuration to installers.
Furthermore, the R-5502-W offers unlimited flexibility. It is timbre matched to all of our 5000 series architectural products, so you can mix and match to create a high-performance, discreet stereo or home theater system that`s just right for you.
Specification Description
Model R-5502-W
UPC 743878020120
Color White
Crossover Frequency 2200Hz & 1300Hz
Frequency Response 46Hz-20kHz
Height (Inches) 17.75
Hole Cutout Dimension 16.5 x 6.5 Inches
Mounting Depth 3.5 Inch
Power Handling (Watts) 300 Watts Peak
Power Handling (Watts) 75 Watts Continuous
Sensitivity 92dB
Speaker Type In-Wall
Tweeter Size (Inches) 1
Width (Inches) 8
Woofer Size (Inches) (2) 5.25
Klipsch Audio R-5502-W (Ea.) In-wall LCR Speaker Questions
Questions and Answers
Where to Buy
$399.00
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Nov 21, 2008
Klipsch Audio R-5502-W (Ea.) In-wall LCR Speaker Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Great speaker made of quality materials
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Great Sound Quality
    Cons
  • None
    Best Uses
  • Basic Systems
"[...] The speaker itself sounds great and is constructed of the highest grade materials. The installation was simple, however, be aware that its cutout is 16.5 inches. Standard wall studs are 16.5 inches apart on center. That means this speaker will not fit between wall studs in a horizontal conf …"  Read Full Review »
Was this Speaker & Subwoofer review on the Klipsch Audio R-5502-W (Ea.) In-wall LCR Speaker helpful to you?
 Report Abuse  (1)  (0)  0 comments
Nov 21 2008
Mack
Prattville, Al
I am:
  • Tech Savvy
Reviewed at:
Price: $399.00
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
