Klipsch Audio ProMedia 2.1
#337
4.8
based on 50 reviews
Ratings Distribution
5 star
39
4 star
10
3 star
1
2 star
0
1 star
0
Category Average
4.4
Low Price:
$123.56 at Computer All Services
 Trusted:
$149.00 at Your Electronic Warehouse
Find it at Amazon
$123.56 - $2,399.99
from 5 stores
More Images
Pros
  • Great sound quality (34)
  • Powerful (24)
  • Easy to use (14)
  • Easy to connect (11)
  • Attractive design (7)
  • Compact (7)
  • Compact design (6)
  • Durable (6)
  • Reliable (6)
  • Fast (2)
See less See more
Cons
  • Heavy / bulky (3)
  • Cant adjust speaker angle (1)
  • Could use more bass (1)
  • Excellent speakers (1)
  • I want a remote control (1)
  • Needs clear punchy bass (1)
  • No mute button (1)
  • Poor sound quality (1)
  • Power control (1)
Best Uses
  • Home (15)
  • Dorm room (6)
  • Large rooms (6)
  • Smaller rooms / apartments (6)
  • Basic systems (5)
  • Audiophiles (4)
  • Office (4)
  • Indoor (3)
  • Work (2)
  • A laptop and cd player (1)
Provided by B&H Photo Video
The ProMedia 2.1 THX Computer Speaker System from Klipsch offers crisp and clear 2.1 channel audio output. The speakers have passed the stringent THX certification requirements so you will be sure you will be getting good sound. The speakers are ideally suited for use with a computer or MP3 player but are versatile enough to be driven by DVD players, televisions and game consoles. Each satellite speaker delivers a 55 watt output and the subwoofer delivers 50 watts. These speakers are perfect for the demanding listener.
Specification Description
Model 090506081211, 1007765, 20059014, PRO MEDIA2.1
UPC 743878011586
Audio Amplifier Integrated
Audio System Max Output Power 200 Watt
Color Black
Connectivity Technology Wired
Manufacturer Warranty 1 year warranty
Output Power 55W (PMPO) < 10% THD Satellite
Product Description Klipsch ProMedia 2.1 - PC multimedia speaker system
Product Type PC multimedia speaker system
Response Bandwidth 31 - 20000 Hz
Speaker System Details 2 x satellite speaker - 4 Ohm 1 x subwoofer
Speaker Type Active
Surround Sound Type 2.1
System Components 2 speakers, subwoofer
Klipsch Audio ProMedia 2.1 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 9, 2008
Klipsch Audio ProMedia 2.1 Reviews
Most helpful positive review
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
Pure quality sound reproduction !
"These are the speakers you want if quality sound reproduction is what you're after. With inputs from a computer, MP3 device or any other line level device and these 2.1 speakers stand at the head of the line. I put a pair in the office and a week later put a pair in the studio after listening to the first. I use a Sound Blaster X-Fi from the notebook as the input and this is killer sound at it's best. Make this ..." Read Full Review »
Jun 06, 2008 by Stitch
See more positive Klipsch Audio ProMedia 2.1 reviews
3.0
Not that Great
"Honestly, I don't think these are all that they are cracked up to be. First of all, they lack in the design element. They are very basic and blah looking. Second, the Bass is way to over powering. Even when you turn the bass down, it is still off balance. You do not hear the full range you would hope for in these speakers. Also, they do sound a bit shallow...." Read Full Review »
Oct 03, 2008 by ChicagoGuy
See more negative Klipsch Audio ProMedia 2.1 reviews
Displaying 1 - 5 of 50 Reviews
Show
Sort by
5.0
    Pros
  • Compact Design
  • Easy To Use
  • Great Sound Quality
  • Pure quality construction
    Cons
  • None
    Best Uses
  • A laptop and CD player
  • Quality sound enjoyment
"These are the speakers you want if quality sound reproduction is what you're after. With inputs from a computer, MP3 device or any other line level device and these 2.1 speakers stand at the head of the line. I put a pair in the office and a week later put a pair in the studio after listening to the …"  Read Full Review »
Was this Speaker & Subwoofer review on the Klipsch Audio ProMedia 2.1 helpful to you?
Jun 6 2008
Stitch
Chula Vista, CA
I am:
  • Quality Oriented
Reviewed at:
Impressive speakers
5.0
    Pros
  • Good Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • At Home
  • Work
"These are great speakers, it is hard to believe they are a 2.1 setup. [...]I have owned Altec Lansing (5.1) previously and the Klipsch are in another league all together. One day after setting them up they mysteriously quit working. I emailed Klipsch directly, they diagnosed the problem and sent …"  Read Full Review »
Nov 6 2006
melsantacruz
santa cruz, ca
Reviewed at:
Buy this!!
5.0
    Pros
  • Accurate mids and highs
  • Bang for buck is high
  • Compact
  • Durable
  • More »
    Cons
  • Thin speaker wires
    Best Uses
  • Home
"Even though the speaker wires are thin, the sound is great. May even be improved with specialty Monster cables which I could not find in stock anywhere. The subwoofer defines bass notes well and is quite powerful, yet not very large. Satellites sound tremendously better than the usual speakers inclu …"  Read Full Review »
Jun 4 2008
The Computer Guy
Palatine, IL
I am:
  • Appreciate quality sound
  • Practical
  • Student
Reviewed at:
Fabulous Speakers
5.0
    Pros
  • Look Great
  • Sound Great
    Cons
  • None
    Best Uses
  • None
"I replaced a pair of old Polk Audio computer speakers with the Klipsch ProMedia 2.1 THX 3-piece computer speakers. In my opinion the Klipsch are the best computer speakers on the market at any price. The sound is true to life, and the speakers provide excellent separation. I use them to crank out …"  Read Full Review »
Mar 3 2008
kele772
Westchester County, NY
Reviewed at:
Outstanding performance!
5.0
    Pros
  • Comfortable
  • Compact Design
  • Easy To Use
    Cons
  • Too long in-speaker knobs
    Best Uses
  • Desktop in room Speakers
"These speakers are what they are meant to be; an outstanding set of computer speakers. Right out of the box the quality stands out from the packing materials to the overall performance.
The sound is really great for detailed listening close to the computer. Briliant treeble, clear mids and powe …"  Read Full Review »
May 14 2008
Audio Enthusiast
Charlotte NC
I am:
  • Quality Oriented
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
