Klipsch Audio Dual 5.25" Two-Way Center Channel Speaker - Black Finish
#21
4.8
based on 13 reviews
from $329.00 - $329.99
Ratings Distribution
5 star
10
4 star
3
3 star
0
2 star
0
1 star
0
Category Average
4.4
More Images
Pros
  • Great sound quality (19)
  • Attractive design (12)
  • Easy to connect (11)
  • Powerful (10)
See less See more
Cons
  • Heavy / bulky (1)
Best Uses
  • Home theater (7)
  • Audiophiles (4)
  • Large rooms (4)
  • Smaller rooms / apartments (4)
  • Basic systems (3)
  • Enhance your home theater (1)
Provided by OneCall
Because the center channel speaker reproduces more than 60 percent of a movie soundtrack, Klipsch spared no expense when developing the Reference Series RC-52. With its ideal combination of technology, performance and design, this speaker delivers a seamless, engaging soundstage that puts listeners inside the action.
Exclusive Tractrix(R) Horns have always been the key component of this critically acclaimed series. In the RC-52, this technology has been refined to include improved throat geometry for a more genuine, lifelike sound. Behind the horn lies a 1-inch titanium tweeter with a powerful neodymium magnet motor structure to provide a unique combination of precision, clarity and effortless dynamics.
The RC-52 employs dual 5.25-inch woofers for a solid bass foundation. These Cerametallic(TM) woofers with inverted copper dust caps exhibit a very high stiffness-to-mass ratio and superb damping characteristics.
Klipsch Tapered Array(TM) technology operates both woofers at the lowest frequencies - maintaining the high output capability necessary for good center channel performance - but only one operates all the way through the midrange to where the tweeter takes over. This eliminates acoustic interference between the woofer outputs, a flaw in conventional speaker designs that can severely impair sound quality at the sides of the listening area.
The RC-52's rigid cabinet offers improved internal cross-bracing to minimize panel vibrations that can color sound. Twin front-firing ports eliminate turbulence noise, while increased baffle ribbing around the horn mouth dramatically improves acoustics across the sonic range. For signal purity and perfect driver integration, the crossover on the RC-52 features the finest components and Klipsch custom internal wiring.
Available in a black woodgrain vinyl finish, the fully video-shielded RC-52 comes with a low-diffraction, magnetically attached grille to further accentuate the elegance of this speaker.
Specification Description
Model RC-52, RC-52 BLACK, RC52
UPC 743878016369
Color Black
Crossover Frequency 1400Hz
Crossover Frequency 1600Hz
Depth (Inches) 10.5
Frequency Response 67Hz - 23kHz
Height (Inches) 6.75
Impedance 8 ohms
Magnetic Shielding Yes
Power Handling (Watts) 125 Watts
Power Handling (Watts) 500 Watts Peak
Sensitivity 96dB
Speaker Terminals 5-Way Binding Post
Speaker Type 2-Way
Speaker Type Center Channel
Tweeter Size (Inches) 1
Weight (Pounds) 22
Width (Inches) 20.5
Woofer Size (Inches) (2) 5.25
Klipsch Audio Dual 5.25" Two-Way Center Channel Speaker - Black Finish Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 15, 2009
Klipsch Audio Dual 5.25" Two-Way Center Channel Speaker - Black Finish Reviews
Displaying 1 - 5 of 13 Reviews
Show
Sort by
Hearing Klipsch is Believing!!!
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
    Cons
  • None
    Best Uses
  • Home Theater
"I replaced another well known brand center channel speaker with this Klipsch speaker. It makes a tremendous difference in being able to better understand the dialogue on DVDs and is a joy to listen to when playing CDs. "
Was this Speaker & Subwoofer review on the Klipsch Audio Dual 5.25" Two-Way Center Channel Speaker - Black Finish helpful to you?
Jan 29 2009
Lakeman
Eatonton, GA
I am:
  • Audiophile
  • Musically Inclined
  • Practical
  • Tech Savvy
Reviewed at:
Price: $329.00
Powerful Center Channel
5.0
    Pros
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Home Theater
"I replaced a Yamaha Center Channel with this Klipsch Center Channel because I was not able to hear voices clearly while watching movies. Women’s voices were especially difficult to understand, but with the Klipsch Center Channel, voices are now absolutely clear. Music with violins sounds heavenly …"  Read Full Review »
Mar 4 2009
Debra
Rhode Island
I am:
Reviewed at:
Price: $329.00
Amazing sound!! A Surround Sound must!!
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
    Cons
  • None
    Best Uses
  • Audiophiles
  • Enhance your Home Theater
  • Home Theater
"This center channel is the complete package. Looks and sounds awesome. Produces rich highs, the perfect sounding midrange and really makes the entire surround sound much better. Klipsch is high quality audio, this item comes nicely packaged, great looks and easy functionality. I looked at ot …"  Read Full Review »
Jan 20 2009
Harsha
Jacksonville, Fl.
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $329.00
Impressive
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Smaller Rooms
"I'm very pleased with my RC-52 CCS. I live in an apartment that has a living room of about 15'x20' in measurement, and the RC-52 offers plenty of power. I was super impressed with the amount of bass it produces. I don't even need a sub at this point. "
Aug 29 2008
Nick
Fayetteville, AR
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Price: $329.00
Unreal
5.0
    Pros
  • Attractive Design
    Cons
  • None
    Best Uses
  • Larger Rooms
"Replaced an older ADS Center Channel with this one-unbelievable. The first Blu Ray I watched-X3, I actually ducked when something exploded. The high end is so crisp-blew me away. This is the ONLY speaker I replaced in my entire system, based on my experience, the two front channels are next. "
Oct 20 2008
Rob
Newtown, CT
I am:
  • Audiophile
Reviewed at:
Price: $329.00
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
