KLH Audio Systems Audio Systems B-PRO6 Titan Series 2-Way Speaker
#985
3.8
based on 18 reviews
from $49.99
Ratings Distribution
5 star
4
4 star
10
3 star
2
2 star
1
1 star
1
Category Average
4.4
$49.99 at RadioShack
Find it at Amazon
Find it at Ebay
Pros
  • Great sound quality (16)
  • Easy to connect (12)
  • Attractive design (10)
  • Powerful (7)
  • Compact (4)
  • Powerful bass (2)
  • Capable of high volumes (1)
  • Cheap acceptable sound (1)
  • Decent freq range (1)
  • Good value (1)
See less See more
Cons
  • Poor sound quality (3)
  • Heavy / bulky (2)
  • "boxy" sound (1)
  • Dont expect much (1)
  • For the price not bad (1)
  • Not much on the con side (1)
Best Uses
  • Basic systems (15)
  • Smaller rooms / apartments (10)
  • Outdoors (2)
  • Home theater (1)
  • Television (1)
Provided by RadioShack
This speaker from KLH is designed to provide excellent performance at a great value.
Specification Description
Model B-PRO6
Additional features 6.5" polymer coated woofer, 5/8" polycarbonate tweeter
Benefits 100-watt speakers deliver great sound for your home, office, dorm and more6.5" polymer-coated woofer; 5/8" polycarbonate tweeter
Capacity UOM mAh
Connectivity technology Wired
Country Of Origin China
Description Header Designed to look and sound beautiful.
Detachable grille Yes
Display Catalog Number 40-147
Enclosure Color Black
End Product Indicator Yes
Impedance 8 ohms
Inputs 1 x Push Terminal
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
Model B-PRO6
New Date Tue Nov 27 00:00:00 CST 2007
Operating Temperature UOM ° F
Power range 100W watts
Product Depth 15.25
Product Dimensions UOM inches
Product Height 13
Product Length 15.25
Product Type Home speakers
Product Weight 12
Product Weight UOM pounds
Product Width 8.5
RMS (continuous) power 100 watts
Speaker type Shelf
Speakers included 2
Supported Languages English
KLH Audio Systems Audio Systems B-PRO6 Titan Series 2-Way Speaker Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 15, 2009
KLH Audio Systems Audio Systems B-PRO6 Titan Series 2-Way Speaker Reviews
Most helpful positive review
Most helpful negative review
[1 of 1 customers found this review helpful]
4.0
Can't be beat for the size and price
"It had been a while so I was surprsed when I went to look for a 6.5" bookshelf speaker that these were all that was available anywhere for under $100 list price each. I used to work in the Auto Sound industry and know that to get ANY bass you need at least a 6.5" speaker. I got these with- out hearing them but I don't think it would have mattered since they probably would have had them hooked to a stereo playi..." Read Full Review »
Nov 15, 2009 by CB
See more positive KLH Audio Systems Audio Systems B-PRO6 Titan Series 2-Way Speaker reviews
3.0
for the price ...... not bad
"I had to replace a rather nice pair of 6 1/2" book shelf speakers and needed something quick and cheap. If I was still in NYC instead of rural nowhere, a replacement driver would have been a much better chice. The KLH are inexpensive, and thats how they sound. I use a decent sub-woofer so bottom is not a issue. They function and thats about it. Freq. Response has huge holes. EQ wont really fix it. However, they ..." Read Full Review »
Jan 07, 2009 by Ray Drake
See more negative KLH Audio Systems Audio Systems B-PRO6 Titan Series 2-Way Speaker reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
4.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Powerful
    Cons
  • Distorted Sound
    Best Uses
  • Basic Systems
  • Outdoors
"It had been a while so I was surprsed when I went to look for a 6.5" bookshelf speaker that these were all that was available anywhere for under $100 list price each. I used to work in the Auto Sound industry and know that to get ANY bass you need at least a 6.5" speaker. I got these with- out hea …"  Read Full Review »
Was this Speaker & Subwoofer review on the KLH Audio Systems Audio Systems B-PRO6 Titan Series 2-Way Speaker helpful to you?
Nov 15 2009
CB
Thousand Oaks, CA
I am:
  • Practical
  • Tech Savvy
A Great Speaker
4.0
    Pros
  • Capable of High Volumes
  • Clear Sound
  • Decent Freq Range
  • Well defined bass
    Cons
  • None
    Best Uses
  • Basic Systems
  • Smaller Rooms
"I bought these for several reasons one, to replace my smaller speakers for a fuller bass sound and higher volume, and two too eventually add the to a 5.1 system as the front L-R channels which from the sound i have heard from them they would do fine. when used with music they do not need a subwoofer …"  Read Full Review »
Oct 10 2009
DOOOOOOOOOOOOOOOOOOM
The Moon
I am:
  • Audiophile
  • Crazy
Not bad
4.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Smaller Rooms
"Today (6/22/09) I purchased these for [$]. Over the weekend I bought a used Lafayette LR-3030A receiver for another room. I ended up using the KLH in the living room and the RCA 4" sized woofer speakers that were connected to the Onkyo in the LR are now connected to the Lafayette. Are they perfect? …"  Read Full Review »
Jun 22 2009
camogreen
Central New Jersey
I am:
  • Tech Savvy
3.0
    Pros
  • PRICE
    Cons
  • Dont expect much
    Best Uses
  • Basic Systems
"I had to replace a rather nice pair of 6 1/2" book shelf speakers and needed something quick and cheap. If I was still in NYC instead of rural nowhere, a replacement driver would have been a much better chice. The KLH are inexpensive, and thats how they sound. I use a decent sub-woofer so bottom is …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jan 7 2009
Ray Drake
Wellsville, NY.
I am:
  • Audiophile
  • Musically Inclined
  • Tech Savvy
[2 of 2 customers found this review helpful]
Bigger isn't always better!
4.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Home Theater
  • Outdoors
  • Smaller Rooms
"I was worried about the sound quality since the size is much smaller that what I was using but these are AMAZING! The sound quality shocked me! KLH are awesome sound in a small unit! "
 Report Abuse  (2)  (0)  0 comments
Jul 6 2009
B
Vermont
I am:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
