Kinamax 2-Port USB 2.0 & VGA/SVGA KVM Switch Box with 2 Sets of Cables
#324
3.6
based on 14 reviews
from $19.99 - $28.99
Ratings Distribution
5 star
3
4 star
7
3 star
0
2 star
3
1 star
1
Category Average
4.1
Low Price:
$19.99 at CompUSA
 Trusted:
$19.99 at TigerDirect
Find it at Amazon
Provided by ClubMac
Kinamax 2-Port USB 2.0 & VGA/SVGA KVM Switch Box with 2 Sets of Cables This compact 2-port USB KVM switch lets you manage 2 Computers with just one monitor and one set of keyboard and mouse. This compact 2-port USB KVM switch lets you manage 2 Computers with just one monitor and one set of keyboard and mouse. Three different USB devices can be shared by all computers. Two sets of KVM cables are included for your convenience. Save your precious desk space by having only one set of keyboard, monitor and mouse while working on 2 separate PCs. No need to waste table space, money on 2 keyboards, 2 monitors, and 2 mice and time re-cabling in order to use your KVM on other system. This is one of the handiest tools you can own. This high quality data transfer switch box allows users to use one set of peripherals on multiple systems and provides an economical solution to costly peripheral devices. Sturdy, reliable construction and easy to use, this switch will save you space, money, time. Plus, it is a big help when it comes to troubleshooting systems.Features:• Use one keyboard, monitor, and mouse to control Two computers • Two computers can share 3 different USB peripherals. • No software required • Push Button for easy computer selection • Support SVGA, VGA, and Multi-sync Monitors • Supports keyboard and mouse plug and play • Auto-Scan & LED display for easy status monitoring • High VGA resolution up to 1920 * 1220 • Hot swappable. No Powering down the KVM Switch or PC • Keyboard and mouse emulation for simultaneous PC boot-up • LED displays monitor status • KVM cables are included • USB self-power operation • No external power needed (draws power from USB) • Shares USB device such as USB Printer, USB Scanner, USB Flash Drive, USB Card Reader and etcSpecifications:• High quality cable support Max. Resolution: 1920 X 1440 • Computer Ports: 2 • Console Port: 1 • USB Ports: 5 (2 to connect to computers + 3 console ports for keyboard, mouse, printer, etc...) • Computers Supported: 2 • Keyboard Emulation: USB • Mouse Emulation: USB • Mouse Input / Output: USB • VGA Input / Output: High Density D-Sub 15 pin • LED indicators: 2Compatible with:• Microsoft Windows 3.x/95/98/NT/2000/ME/XP/Vista • Linux • DOS • Novell NetWare 4.x/5.x • Unix
Kinamax 2-Port USB 2.0 & VGA/SVGA KVM Switch Box with 2 Sets of Cables Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 17, 2009
Kinamax 2-Port USB 2.0 & VGA/SVGA KVM Switch Box with 2 Sets of Cables Reviews
Most helpful positive review
Most helpful negative review
4.0
Generally, not a bad ...
"Generally, not a bad choice for this price. Works good with one my LCD monitors (19'', 1280x1080), but poorly for another with resolution 1440x900. Also, it looks like it supports legacy USB, NOT 2.0! So, for keyboard and mouse will be OK, but for sharing drives/CD not so good. At least, that's what both my PCs complain about when I press switch button - ''This device can work faster with USB 2.0''...." Read Full Review »
Oct 18, 2008 by Anonymous
See more positive Kinamax 2-Port USB 2.0 & VGA/SVGA KVM Switch Box with 2 Sets of Cables reviews
2.0
Mouse and Keyboard on ...
"Mouse and Keyboard on active channel would freeze intermittently and you have to switch to B channel then back to A again to get it to redetect the keyboard and mouse. Sometimes it would not work at all had to shut down and reboot. It was costing me to much down time so I removed it and trashed it...." Read Full Review »
Sep 18, 2009 by Me
See more negative Kinamax 2-Port USB 2.0 & VGA/SVGA KVM Switch Box with 2 Sets of Cables reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
2.0
"Mouse and Keyboard on active channel would freeze intermittently and you have to switch to B channel then back to A again to get it to redetect the keyboard and mouse. Sometimes it would not work at all had to shut down and reboot. It was costing me to much down time so I removed it and trashed it. "
Was this Networking Hub & Switch review on the Kinamax 2-Port USB 2.0 & VGA/SVGA KVM Switch Box with 2 Sets of Cables helpful to you?
Sep 18 2009
Me
Undisclosed
4.0
"Generally, not a bad choice for this price. Works good with one my LCD monitors (19'', 1280x1080), but poorly for another with resolution 1440x900. Also, it looks like it supports legacy USB, NOT 2.0! So, for keyboard and mouse will be OK, but for sharing drives/CD not so good. At least, that's what …"  Read Full Review »
Oct 18 2008
Undisclosed
Very satisfied with this ...
4.0
"Very satisfied with this switch. I needed a basic USB switch, and that's what I have tested for (my monitor have multiple video inputs).
No software needed (for Win XP Pro), simple, no extra power needed, small footprint, works with all regular USB cables. It installs as a USB hub.
Solid product for …"  Read Full Review »
Jul 29 2009
Rumba
Undisclosed
Had this KVM about a ...
4.0
"Had this KVM about a year. No problems running between Dell8250 XP machine and Gateway Vista machine. Just no Audio. I like the button switching instead of the keyboard commands. I bought this because a previous KVM I had only was Hot key switchable from the keyboard and would always lock up. No …"  Read Full Review »
Jan 1 2009
Paul
Undisclosed
ok so bought this and ...
2.0
"ok so bought this and found that it is fiddily and badly designed. However it does what it says on the tin. Had some intermittent problems with the screen colour on one side of the switch but other than that it is ok..... shared a USB printer using it as well, plus point... "
May 7 2009
Simmo
Undisclosed
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
