Keyspan Tripplite PR-PRO3 Presentation Remote Pro
#38
4.5
based on 2 reviews
from $55.99 - $89.00
Ratings Distribution
5 star
1
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.2
Low Price:
$55.99 at ClubMac
 Trusted:
$59.96 at B&H Photo Video
$55.99 at OnSale
see all stores
More Images
Pros
  • Easy setup (2)
  • Ergonomic design (2)
  • Nice button configuration (2)
  • Nice features (2)
  • Easy to program (1)
  • Strong signal (1)
See less See more
Best Uses
Provided by MacMall
100 ft+ Presentation Remote Pro The Presentation Remote Pro frees you from your keyboard during a presentation or lecture. HighlightsThe Presentation Remote Pro frees you from your keyboard during a presentation or lecture. With RF, laser, mouse and audio controls in one sleek remote, it is an ideal tool for presenters and lecturers. Offering a range of more than 100 feet the Presentation Remote Pro covers large meeting rooms and lecture halls far outdistancing other remotes in its price range.Features:• RF Connectivity: Works up to 100 ft. even through walls and furniture.• Mouse Control: Provides complete two-button mouse capabilities.• Laser Pointer: Highlight details of your presentation with ease!• Audio Controls: Adjust system volume on the PC or Mac.• Advanced Functions: Start and End presentations, or hide the slide (darken the screen) with a push of a button.• Plug and Play: No software to install, just plug the receiver into the USB port and the remote begins to work within seconds.• Pop In/Out Receiver: The RF receiver stores in the base of the remote when not in use.• On/Off Switch: Prevents the battery from accidentally draining when the remote is being carried in your pocket or laptop bag.• AAA Batteries: Easy to buy when you need to replace the batteries.• Mac and Windows: Designed for use on Mac or Windows. Control PowerPoint and Keynote. Specifications:• Receiver plugs into USB port on PC or Mac• Remote transmits 2.4 Ghz RF signal 100 ft or more - even through walls and furniture• Laser Pointer - (Class 2; Maximum output 1mW; Wave length 650 nm)• RoHS CompliantCompatibility:Presentation Software:This remote control is designed for use with PowerPoint and Keynote. It will also work with other presentation programs that use the same keystrokes as PowerPoint. The remote supports both Slide Show view and Presenter view within PowerPoint.Volume Control:Volume control buttons adjust system volume on a PC or Mac.Projectors:This remote is compatible with all brands of projectors.Requirements:• Windows:- An available USB port- Windows 98SE/Me/2000/XP/Vista• Macintosh:- An available USB port- Mac OS 9.1 or later- Mac OS X (10.1.5 or later)- Requires Mac OS X (10.3 or later) for volume control
Specification Description
Model PR-PRO3, PRPRO3
UPC 672603045025
Connection Type Wireless
Keyspan Tripplite PR-PRO3 Presentation Remote Pro Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 8, 2009
Keyspan Tripplite PR-PRO3 Presentation Remote Pro Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Cool little device
5.0
    Pros
  • Easy To Program
  • Easy To Set Up
  • Ergonomic Design
  • Nice Button Configuration
  • Nice Features
    Cons
  • None
    Best Uses
  • None
"Used it for guest speakers for a conference. We definitely put the 100' range to the test. Worked great! Even worked when the guest speaker kept pointing it at the projector and not the computer. :)
Also loved how you could control the volume of the computer with this device. "
Was this Remote Control review on the Keyspan Tripplite PR-PRO3 Presentation Remote Pro helpful to you?
Sep 8 2009
jasonb
San Antonio, TX
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Price: $59.96
[1 of 1 customers found this review helpful]
Great product
4.0
    Pros
  • Easy To Set Up
  • Ergonomic Design
  • Nice Features
  • Strong Signal
    Cons
  • None
    Best Uses
  • None
"This product works well, but only after I figured out that you need to get the presentation all set up and projecting before turning it on. When I turned it on first the presentation started jumping forward slides on its own (very amusing for my students). "
 Report Abuse  (1)  (0)  0 comments
Oct 11 2008
teacherO
Dallas, TX
I am:
  • Tech Savvy
Reviewed at:
Price: $59.96
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
