JVC HRXVC11B Progressive Scan DVD Player and VCR Combo
#47
4.1
based on 10 reviews
from $79.80 - $119.00
Ratings Distribution
5 star
6
4 star
2
3 star
0
2 star
1
1 star
1
Category Average
3.6
More Images
Pros
  • Consistent performance (5)
  • Easy setup (5)
  • Easy to use (5)
  • Great picture quality (3)
  • Compact (2)
  • Durable (1)
  • Pricey (1)
See less See more
Cons
  • Flimsy (1)
Best Uses
  • Home (4)
  • Office (1)
Provided by Beach Audio
For recording TV programs to VHS, the deck includes JVC's Timer Link, a quick and easy solution for recording TV programs by connecting to a cable or satellite set-top box using an AV cable. The user selects the desired program using the set-top box electronic program guide and timer function. JVC's new Timer Link feature senses the signal, automatically powers up the recorder and begins recording. Recording automatically stops and the recorder shuts off when the program ends. JVC research shows that the vast majority of set-top boxes come equipped with a timer.
  • Playable Formats: VHS Hi-Fi, DVD-Video, DVD-RW/-R, +RW/+R, CD, SVCD, VCD, CD-R/RW, JPEG Digital Still (CD-R/RW)
  • Timer-Link Recording
  • Tuner-free
  • SQPB
  • VHS Hi-Fi Stereo
  • Progressive Scan Output
  • DVD to VHS Direct Rec (Not possible with copy-protected DVD content.)
  • 14bit/108MHz Video D/A Converter
  • Stylish, Slim design 3-1/8" (79mm) High
  • Specification Description
    Model HR-XVC11B, HRXVC11B, JVC HRXVC11B, JVCHRXVC11B
    UPC 046838034312
    color null
    Disc Capacity 1
    DVD Disc Compatibility (Record) DVD Play Only - Does not record
    Select DVD / VCR Combos
    size null
    sku 132617
    skuprice 84.9900
    style JVCHRXVC11B
    taxable Y
    TV Broadcast Compatibility NTSC
    Type of DVD Unit Component DVD Player and VCR Combo
    JVC HRXVC11B Progressive Scan DVD Player and VCR Combo Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Sep 17, 2009
    JVC HRXVC11B Progressive Scan DVD Player and VCR Combo Reviews
    Most helpful positive review
    [8 of 8 customers found this review helpful]
    Most helpful negative review
    [0 of 1 customers found this review helpful]
    5.0
    Simple but elegant design
    "This is a high-quality product that can rival the most popular brand in the market today. I can probably compare this to my previous VHS player that lasted almost 20 years as a dependable machine. So far i have no problem with it when it comes to picture quality. Color is lifelike, not too light and not too dark. And don't forget it's a cheap machine as compared to other machine of the same features and way expe..." Read Full Review »
    Jun 18, 2008 by Ren the Silent Joker
    See more positive JVC HRXVC11B Progressive Scan DVD Player and VCR Combo reviews
    2.0
    not user friendly
    "Pros Not to much to say on the pro's, it is just like any other dvd player Cons This unit I got so I can tape my daily story and to this day I am unable to get it to work. The book that come with it is not helpful let a lone. I am still unable to firgure out how to tape let a lone hook that portion up. Review They need to add a conection for cable to the unit. they also need to add some type of option to progr..." Read Full Review »
    Mar 11, 2009 by dale533
    See more negative JVC HRXVC11B Progressive Scan DVD Player and VCR Combo reviews
    Displaying 1 - 5 of 10 Reviews
    Show
    Sort by
    5.0
      Pros
    • Consistent Performance
    • Durable
    • Easy To Set Up
    • Easy To Use
    • High Quality Picture
      Cons
    • None
      Best Uses
    • Home
    "This is a high-quality product that can rival the most popular brand in the market today. I can probably compare this to my previous VHS player that lasted almost 20 years as a dependable machine. So far i have no problem with it when it comes to picture quality. Color is lifelike, not too light and …"  Read Full Review »
    Was this DVD Player review on the JVC HRXVC11B Progressive Scan DVD Player and VCR Combo helpful to you?
     Report Abuse  (8)  (0)  0 comments
    Jun 18 2008
    Middlesex, NJ
    I am:
    • I am a bit shy guy
    Reviewed at:
    Price: $79.99
    Comparable to the more expensive ones
    4.0
      Pros
    • Easy To Set Up
    • Easy To Use
      Cons
    • Flimsy Construction
      Best Uses
    • Home
    "Easy to transfer old home VHS movies to DVD. Convienent and space-saving to have two players in one compact machine. "
    Jun 15 2008
    Home-bound mommy
    Rockford, MI
    I am:
    • Practical
    Reviewed at:
    Price: $79.80
    [1 of 1 customers found this review helpful]
    Nice unit
    5.0
      Pros
    • Easy To Set Up
    • Easy To Use
    • Price
      Cons
    • None
      Best Uses
    • Home
    "I needed a VCR to archive off the last of my VHS tapes. Beyond that, fairly light use. This unit fits the bill just fine. Nothing fancy, but it's well-built and in every way meets my expectations. I'm glad I selected this one. "
     Report Abuse  (1)  (0)  0 comments
    Jun 30 2009
    Ted
    Connecticut
    I am:
    • Casual User
    Reviewed at:
    Price: $85.00
    Product Uses:watching ...
    5.0
    "Product Uses:watching dvds and vcr tapes, taping tv programs
    Review:Pros
    -Easy to set up
    -Easy to use
    -Manual is (mostly) in plain English
    -Space saving unit
    Cons
    Thinking...
    Still thinking...
    Nope - none come to mind
    Review
    My "entertainment system" consists of a regular old TV and a cable box. …"  Read Full Review »
    Sep 17 2009
    MonikaJ
    Nevada
    Reviewed at:
    Price: $89.99
    would purchase again
    4.0
      Pros
    • Compact
    • Easy To Set Up
    • Easy To Use
      Cons
    • None
      Best Uses
    • Office
    "office presentations
    versatile, can play discs and record/play vhs
    sony products have great track record in my office "
    Jul 18 2009
    steelmd
    new jersey
    I am:
    • Casual User
    Reviewed at:
    Price: $79.99
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
