JVC HA-FX300R Red In-Ear Headphones
#656
3.7
based on 6 reviews
Ratings Distribution
5 star
2
4 star
2
3 star
1
2 star
0
1 star
1
Category Average
3.9
$49.97 - $99.99
from 10 stores
More Images
Pros
  • Compact (1)
  • Lightweight (1)
  • Powerful bass (1)
See less See more
Cons
  • Flimsy (1)
  • Too much ambient noise (1)
  • Uncomfortable (1)
Best Uses
  • Music (1)
  • Portable devices (1)
Provided by OneCall
The new JVC HA-FX300 employs a range of sound-enhancing technologies, including an aluminum evaporation diaphragm, a new internal dual-metal structure and aluminum housing. The new aluminum evaporation diaphragm used in the HA-FX300 reproduces high-frequency detail more accurately than conventional cellulose or polymer-based diaphragm designs. To further enhance performance, the headphone features JVC`s new Bi-METAL structure — the drive unit is housed in a stainless steel base wrapped in a high-specific-gravity brass ring to eliminate vibration and energy loss, enhancing performance across the frequency range. Other innovations are aluminum housings, designed to reduce resonance, and the use of OFC (oxygen-free copper) to minimize transmission loss in the 1.0 meter friction noise reduction cord. The HA-FX300 also offers a plug that is compatible with Apple`s iPhone. To ensure a snug, comfortable fit the headphones come with three different sized silicon rubber earpieces and a pair of memory foam earpieces for a customized fit, while at the same time delivering superior isolation from external sounds and minimizing sound leakage.
  • Bi-METAL structure
  • Aluminum evaporation diaphragms
  • Superior sound isolation with contoured canal design
  • Aluminum anti-resonance housing
  • 3.28ft friction noise reduction cord
  • Specification Description
    Model HA-FX300R, HAFX300R
    UPC 046838032257
    Benefits Bi-METAL structure ensures that you get great performance by eliminating vibration and energy lossAluminum evaporation diaphragms rep
    Capacity UOM mAh
    Connectivity Technology Wired
    Connector Type Gold plated iPhone compatible 1/8" plug
    Country Of Origin Japan
    Description Header Hear just what you want to hear.
    Diaphragm Aluminum evaporation diaphragms
    Display Catalog Number 55027833
    Enclosure Color Red
    End Product Indicator Yes
    Headphone Impedance 16 ohms
    Headphone Sensitivity 100 dB/1mW
    Headphone Sound Output Mode Stereo
    Headphones Type Earbuds & earclips
    Included in the Box JVC HA-FX300 Bi-METAL Structure HeadphonesSoft silicon rubber ear pieces (3 pair)Memory foam ear pieces (1 pair)
    Manufacturer Labor Warranty 12
    Manufacturer Part Number HAFX300R
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Model HA-FX300R
    Operating Temperature UOM ° F
    Product Type Headphones
    Product Weight 0.2
    Product Weight UOM ounces
    Response Bandwidth 8Kz-25kHz
    Supported Languages English
    JVC HA-FX300R Red In-Ear Headphones Questions
    Questions and Answers
    Where to Buy
    $99.99
    $79.99
    $10 Off Orders Of Orders Over $85 + Free Shipping
    $49.97
    BizRate Rating Outstanding 9.1
    Show all 10 stores
    Product Reviews
    Last update: May 12, 2009
    JVC HA-FX300R Red In-Ear Headphones Reviews
    Displaying 1 - 5 of 6 Reviews
    Show
    Sort by
    Okay
    3.0
      Pros
    • Compact
    • Good Bass
    • Lightweight
      Cons
    • Flimsy Construction
    • Too Much Ambient Noise
    • Uncomfortable
      Best Uses
    • Music
    • Portable Devices
    "The headphones are great, not very durable though. The sound is okay but not worth the money so DON'T buy it. The marshmallow's are better. They're more durable, same sound quality and more comfortable. "
    Was this Headphones review on the JVC HA-FX300R Red In-Ear Headphones helpful to you?
    May 11 2009
    Al
    SB, CA
    I am:
    • Student
    Reviewed at:
    Price: $79.99
    Easily the best Dynamic Driver IEM I've heard so far...
    5.0
    "This 8 Hz to 25 kHz frequency response range Dynamic Driver In Ear Monitor is one of the best I've heard of any type, either Dynamic or Balanced Armature; at any price range.
    It just has so much smooth bottom end, and just enough sparkle after a 200+ or so lenth burn in time that you will really, r …"  Read Full Review »
    May 12 2009
    FLACvest
    Silicon Valley, CA
    Reviewed at:
    Price: $99.99
    JVC headphones
    4.0
    "I do enjoy the headphones. I thought they were pretty reasonable. They came with 3 different ear pieces so you can change to your fit. Also came with a small hard case to keep them in. The reason I gave them 4 stars is because you have to put earphone wire around your ears to keep them in place. I …"  Read Full Review »
    Mar 19 2009
    A. Turner
    portage, in usa
    Reviewed at:
    Price: $99.99
    Great sound, reasonable comfort
    4.0
    "The sound from these earphones is excellent for the price. I like the design and how it loops over the ear. Virtually no cable noise, which is a big problem with my apple in ear headphones. They aren't as comfortable as my JVC air cushion earphones, but these do sound better. After trying out o …"  Read Full Review »
    Apr 17 2009
    John D. Butler
    Lexington, KY
    Reviewed at:
    Price: $99.99
    love the earbuds
    5.0
    "sound good and they are comfortable and the price was great.. for this price I can easily live with red instead of black. "
    May 9 2009
    RR Scouter
    Round Rock, TX
    Reviewed at:
    Price: $99.99
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
