JVC GZ-HD6 HDD HI-DEF Hard Drive Camcorder (120GB)
4.5
based on 33 reviews
from
Ratings Distribution
5 star
17
4 star
15
3 star
1
2 star
0
1 star
0
Category Average
4.1
Pros
  • Great picture quality (24)
  • Simple controls (23)
  • Comfortable to operate (21)
  • Great features (20)
  • Versatile (18)
  • Durable (14)
  • Great sound quality (12)
  • Headphone jack (2)
  • 10 hours full hd capacity (1)
  • Abundant manual controls (1)
See less See more
Cons
  • Poor battery life (10)
  • Poor sound quality (4)
  • Poor in low light (2)
  • Bad file format (1)
  • Complicated software (1)
  • Complicated to operate (1)
  • Flimsy (1)
  • Inadequate features (1)
  • Low quality night shots (1)
  • Missing night shot (1)
Best Uses
  • Travel (19)
  • Home movies (17)
  • Hd shooting (16)
  • Movies/short films (13)
  • Documentaries (11)
  • Editing (9)
  • Business (1)
  • Eng (1)
  • Family (1)
  • Special events (1)
Provided by RitzCamera.com
To provide the best possible quality, the GZ-HD6 camcorder feature a FUJINON HD len, a progressive scan 3CCD imaging system and JVC’s HD Gigabrid engine that delivers 1920 x 1080 Full HD recording. In addition, it offers 1080p 60 frame per second output via HDMI 1.3 with x.v.Color. Collectively these technologies capture and maintain optimum image quality for videos and stills through every stage, from the lens on through to recording. This camcorders offers a long recording time in 1920 x 1080 Full HD – 10 hours for the 120GB GZ-HD6 and five hours for the 60GB GZ-HD6. It records up to 24 (GZ-HD6) or 12 (GZ-HD6) hours in the 1440 LP mode. Recordings are stored on either the built-in hard disk drive or on an inserted microSD card (optional). The GZ-HD6 also offers a microphone input and a wide range of manual controls.
The GZ-HD6 also come supplied with a full set of Windows® applications for editing and authoring to DVD and Blu-ray disc, as well as plug-in software to facilitate data import into various Macintosh applications. And to make it easy to share and archive recordings, JVC will continue to offer the CU-VD40 Everio SHARE STATION for HD which enables one-button burning of video data to DVD.
FUJINON HD Lens
The HD Everio GZ-HD6 features an F1.8-F1.9 10x zoom lens that offers nearly the same brightness throughout its 39.5~395 35mm equivalent (f=3.3mm~33mm) zoom range by virtue of its three aspherical lens elements, one made of indexed glass. In addition, the lens surface is coated with a new Electronic Beam Coating (EBC) that greatly reduces degradation caused by light reflecting off the lens surfaces, leading to greater light transmission and reduced flaring and ghosting. This HD lens was specifically designed by FUJINON, a leader in the professional camera lens market for HD moving images, in conjunction with JVC engineers to offer optimal characteristics for the camcorder’s Progressive Scan 3CCD system. In addition, to ensure precise prism/CCD registration, JVC has incorporated FUJINON mounting technology used in professional camcorders.
Progressive Scan 3CCD System
For bright, realistic colors the HD Everio camcorders use three 1/5-inch CCDs – one each for the primary colors red, green and blue, incorporating 16:9 progressive scan CCDs. This voluminous raw information is then processed using pixel shift technology to essentially quadruple the pixel count to create an even more detailed image, providing 2.27 Megapixels total and 2.14 Megapixels effective resolution.
1920 x 1080 Full HD Recording
Using the highest quality FHD recording mode, the user can record approximately 10 hours (120GB model) or five hours (60GB model) of full HD 1920 x 1080 MPEG2 Transport Stream video with MPEG 1 Layer 2 audio. This is truly native HDTV resolution that requires no conversion on the part of the display device to show high definition images.
Also, because it records in the MPEG2 Transport Stream video format, HD Everio recordings can be archived onto Blu-ray discs using provided software and a high definition Blu-ray recorder.
HD Gigabrid Engine
JVC’s new HD Gigabrid video engine, which processes in full 1920 x 1080 progressive video, is the result of years of experience in signal-processing technology, and uses five digital noise-reduction algorithms as well as signal processing to improve vertical scan resolution by approximately 30 percent over JVC’s previous interlace technology for an extremely clear and sharp image.
1080p 60 Frame per second Progressive Output Function
By enabling output of a 1080p 60 fps progressive signal, this function enables HD Everio’s recordings to be enjoyed on high-end displays. Using the same high-power Genessa technology as in JVC’s advanced displays, conversion to 1920 x 1080p at 60 fps provides seamless natural video, free of motion judder during fast action, jaggy lines on angles, and moiré patterns on fine detail when zooming. 1920 x 1080 HD discs played back via the camera from the CU-VD40 SHARESTATION are also converted to 60 fps progressive.
HDMI™ (V.1.3. with x.v.Color™)*
JVC HD Everio Camcorders record using x.v.Color™ technology. In this universal standard x.v.Ycc, known as x.v.Color, provides more accurate color reproduction with more detail and shades that looks more natural to the human eye. It can display 100 percent of the colors that the human eye is capable of perceiving, whereas the traditional sRGB system can display only approximately 55 percent. The difference in color reproduction performance is especially noticeable in greens and yellows. These new HD Everio camcorders output to televisions directly using HDMI™ (V.1.3. with x.v.Color™).
Optical Image Stabilization (OIS)
To preserve the Full HD quality, the HD Everios feature optical image stabilization, avoiding the signal degradation caused by electronic image stabilization, which might be particularly noticeable in HD footage. In short, HD Everio matches its high-definition recording capability with a proven HD lens section that has proven its value in the broadcast industry.
Various Shooting Assist Functions
While HD Everio camcorders offer fully automated operation for point-and-shoot simplicity, they also offer a wide range of manual controls. These include a manual focus ring, manual white balance, exposure control, shutter priority mode, aperture priority mode and sharpness control. In addition, a Focus Assist function displays the edge of the in-focus elements in color while the rest of the image is black-and-white, making it easy to check which image elements are in focus. And a Zebra function displays a striped pattern across highlight areas on the image in the LCD monitor, making it easier to manually set the exposure.
High Capacity HDD (Hard Disk Drive)
Depending on the model, HD Everio camcorders feature either an embedded 120GB or 60GB hard disk drive, allowing upwards of 10 hours (120GB model) or five hours (60 GB model) recording at the highest quality FHD mode. In addition to this mode, three more are offered to let the user choose the appropriate mode for any situation. There is an SP mode with a resolution of 1440 x 1080 and maximum bit rate of 22 Mbps., an LP mode offering the same resolution but at a slower maximum bit rate of 15 Mbps., and an HDV-i.LINK streaming compatible constant bit rate 1440 CBR mode.
PC-less Archiving using Exclusive DVD Burner
By connecting the GZ-HD6 directly to the optional CU-VD40 HD Everio SHARE STATION via USB, the user can burn HD 12cm DVD discs to make backups and permanent archives of selected scenes in any desired order with just a few simple steps. There are several options for selecting clips to be burned to disc — all clips, manual selection of specific clips, clip files not yet copied, by date, video playlists created in-camera and comprised of multiple user-selected clips, or by event type for those clips that have been tagged with an icon representing an event category (e.g. birthday, baby, graduation, vacation, etc.).
Full Complement of Interfaces
HD Everio camcorders are equipped with three digital interfaces – USB, HDMI and Firewire/i.LINK. USB is primarily for file saving, HDMI for digital viewing on large screen displays, and Firewire/i.LINK streams high definition video in full resolution or the 1440CBR mode. High definition video streamed by Firewire/i.LINK in the 1440CBR mode is HDV-compatible and allows footage to be edited using HDV-compatible software (functionality might be limited with some applications). HD recorded material is down-converted for output in DV over Firewire/i.LINK, or in standard definition via the analog component/ S-Video/ composite output.
High Value Software Supplied
For editing and archiving via PC, the HD Everio comes with the CyberLink BD Solution software suite for Windows. This includes PowerDirector for HD video editing, PowerProducer for authoring high definition Blu-ray discs and DVD-Video discs, and PowerCinema for HD file management and playback. Also included is a plug-in that works up to 1920 x 1080i with Apple iMovie HD and Final Cut Pro video software for the Macintosh.
Specification Description
Model GZ-HD5, GZ-HD6, GZHD5US, GZHD6
UPC 046838033490
16 x 9 recording Yes
adjustable auto date/time  Yes
Audio Recording Yes
Auto Focus TTL contrast detection
Auto power save  Yes
back light compensation Yes
Battery Type Product
Benefits 60GB hard drive can record up to 10 hours of high-definition 1920x1080i video10x optical zoom (200x digital zoom) FUJINON HD lens bri
Cables Included A/V cable, USB cable, Component cable
Cables Included Component cable, A/V cable, USB cable
Camera/Camcorder Color Support Yes
Capacity 1460
Capacity 730
Capacity UOM mAh
Chemistry Lithium Ion
Connector Type USB, HDMI, Component, Composite
date/time insert Yes
Description Header Get consistent performance.
Digital Audio Format MPEG-1 Layer2
Digital Scene Transition Fader-white, fader-black, fader-B&W, wipe corner, wipe window, wipe slide, wipe door, wipe scroll wipe shutter
Digital Still Camera Function Yes
Digital Video Format MPEG-2 TS
Digital Zoom 100
Digital Zoom 200
Display Catalog Number 55028199
Display Catalog Number 55028200
Display Features 207000 pixels
Display Form Factor Rotating
Display Languages Multi-language support
Display Size 2.7 inches
Display Size 2.8 inches
Effective Sensor Resolution 530000 Pixels
Enclosure Color Black
Enclosure Color Black/Silver
End Product Indicator Yes
Expansion Slot(s) micro SD Memory Card Slot (microSDHC Compatible)
Exposure Metering Program, automatic, shutter-priority, aperture-priority
Exposure Modes Program, automatic, shutter-priority, aperture-priority
Features Optimal Image Stabilization (OIS) helps eliminate signal degradation for better HD footageRecords directly onto a standard SDHC or SD
Features Optimal Image Stabilization (OIS) helps eliminate signal degradation for better HD footageRecords directly onto a standard SDHC™
Focal Length 3.2mm-32mm
Focal Length 3.3-33mm
Focal Length Equivalent to 35mm Camera 42mm-422mm
Humidity Range Operating 35%-80%
Image Stabilizer Optical
Image Storage XP (1440x1080i, 26.6Mbps), SP (1440x1080i, 19Mbps) 1440CBR (1440x1080i, 27Mbps [CBR])
Image Storage [4:3] 1440x1080, 1024x768, 640x480, [16:9] 1920x1080
Included in the Box JVC GZ-HD5 Everio 60G camcorderAC adapterRechargeable lithium ion battery (BN-VF815U)Component cableA/V ca
Included in the Box JVC GZ-HD6 Everio 60G camcorderAC adapterRechargeable lithium ion battery (BN-VF815)Component cableA/V cab
Inputs 1 x Barrel(DC), 1 x USB/B Mini 5 pin(USB)
Inputs 1 x Phone 1/8"(Microphone), 1 x Barrel(DC11V, 1A)
Integrated Memory 60
Integrated Memory UOM GB
JPEG, JPG Yes
Lens Aperture f1.8-f1.9
Lens Aperture f1.8-f2.4
Lens Construction Aspherical lens
Lens System Features Built-in lens shield
Lens System Type Zoom
Light Sensitivity ISO100, ISO200, ISO400
MAC Operating System Support Macintosh 1.25GHz or faster Power PC G4/G5 or Intel processorMac OS X (10.4.4 to 10.4.11, 10.5.1)available USB 2.0 portAt least 512MB RAM
Manufacturer Labor Warranty 12
Manufacturer Part Number GZHD5US
Manufacturer Part Number GZHD6US
Manufacturer Parts Warranty 12
MAP Price 1199.95
MAP Price 1399.95
Max Operating Temperature 104 Fahrenheit
Megapixel Range <2MP
Microphone Type Built-in
Min Illumination 1 lux
Min Operating Temperature 32 Fahrenheit
Model GZ-HD5
MPEG Yes
NightShot Yes
Operating Temperature UOM ° F
Optical Sensor Type 16:9 1/5" Progressive 3-CCD, 570K-pixel each
Optical Sensor Type Three 1/5" Progressive Scan CCD with Pixel Shift
Optical Zoom 10
Outputs 1 x HDMI(HDMI), 1 x Component(Component), 1 x IEEE1394(i.Link), 1 x Phone 1/8"(A/V out), 1 x USB/B Mini 5 pin(USB), 1 x Phone 1/8"(Headphone)
Outputs 1 x S-Video(S-Video), 1 x Phone 1/8"(A/V out), 1 x IEEE1394(i.Link)
PC Operating System Support Windows XP, VistaIntel Pentium 4, at least 3.2GHz, or Pentium M, at least 1.8GHzAt least 512MB RAM for XP, 1GB RAM for VistaAt least 750MB
Power Device Rechargeable lithium ion battery (BN-VF815)
Power Device Rechargeable lithium ion battery (BN-VF815U)
Product Depth 3.125
Product Depth 5.438
Product Dimensions UOM inches
Product Height 2.85
Product Height 2.875
Product Type Hard drive
Product Weight 1.2
Product Weight 1.3
Product Weight UOM pounds
Product Width 3.125
Rechargeable Yes
Remote Control Full-function IR remote
Resolution 0.53 Megapixels
Resolution 530000 Megapixels
Self Timer Yes
Shooting Modes Digital photo mode
Size Pack
Software Included Cyberlink BD solution, PowerCinema NE for Everio, PowerProducer 4 NE, PowerDirector 6 NE, Digital Photo Navigator 1.5
Software Included Digital Photo Navigator (Win), CyberLink BD Solution (Win), QuickTime component for Everio (MAC)
Sound Output Mode Stereo
Special Effects Sepia, monotone, classic film, strobe
Still Image Format JPEG
Supported Flash Memory micro SD Memory Card Slot (microSDHC Compatible)
Supported Languages English
Technology IR
Total Pixels 570000 Pixels
Type TFT LCD
Video Capture FHD (1920x1080i, 26.6Mbps), SP (1440x1080i, 19Mbps), LP (1440x1080i, 11Mbps), 1440CBR (1440x1080i, 27Mbps [CBR])
Video Capture XP (1440x1080i, 26.6Mbps), SP (1440x1080i, 19Mbps), 1440CBR (1440x1080i, 27Mbps [CBR])
Voltage 7.2
Voltage UOM Volts
JVC GZ-HD6 HDD HI-DEF Hard Drive Camcorder (120GB) Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: GZ-HD6 HDD HI-DEF Hard Drive Camcorder (120GB)
See all eBay results
  at eBay.com
Product Reviews
Last update: Sep 15, 2009
JVC GZ-HD6 HDD HI-DEF Hard Drive Camcorder (120GB) Reviews
Most helpful positive review
[12 of 13 customers found this review helpful]
Most helpful negative review
[4 of 7 customers found this review helpful]
5.0
Amazingly intensely wonderful
"I'm a reporter on the tech front & often shoot products at trade shows with nothing but my messenger bag for holding gear, so size & weight are important. The GZ-HD6 is smaller than a butter box, shoots amazingly high quality HD at full 1080 and can store 10 hours of that on its hard drive. The optical image stabilizer is very effective - almost impossible to shoot poorly even at this light weight. Unlike many c..." Read Full Review »
Mar 12, 2008 by Marty
See more positive JVC GZ-HD6 HDD HI-DEF Hard Drive Camcorder (120GB) reviews
3.0
A Real Pain For Mac Users
"I purchased the HD6 on the recommendation of several reviewers that suggested that the file handling was a breeze with the JVC. Obviously they are not Mac users. My intention is to use the HD6 for video presentations, testimonials, and learning clips for my website. Using the camcorder is easy and it's results are great. The lens is spectacular and I'm pleased with the results. It's just the handling of the fil..." Read Full Review »
Oct 03, 2008 by Jake
See more negative JVC GZ-HD6 HDD HI-DEF Hard Drive Camcorder (120GB) reviews
Displaying 1 - 5 of 33 Reviews
Show
Sort by
5.0
    Pros
  • 10 hours full HD capacity
  • Comfortable to Operate
  • Crisp auto macro mode
  • Durable
  • Great Features
  • More »
    Cons
  • None
    Best Uses
  • ENG
  • Family
  • Movies/Short Films
  • Special Events
  • Sports
  • More »
"I'm a reporter on the tech front & often shoot products at trade shows with nothing but my messenger bag for holding gear, so size & weight are important. The GZ-HD6 is smaller than a butter box, shoots amazingly high quality HD at full 1080 and can store 10 hours of that on its hard drive. The opti …"  Read Full Review »
Was this Digital Camcorder review on the JVC GZ-HD6 HDD HI-DEF Hard Drive Camcorder (120GB) helpful to you?
 Report Abuse  (12)  (1)  0 comments
Mar 12 2008
Marty
Novelty OH
I am:
  • Semi-Professional
Reviewed at:
Amazing images plus versatile usage
4.0
    Pros
  • Amazing look
  • Great focus assist
  • Great picture in DVD
  • More »
    Cons
  • No sound volume control
  • Not smooth focus change
  • Poor Battery Life
  • Poor Sound
  • Software dependence
  • More »
    Best Uses
  • Documentaries
  • Editing
  • HD Shooting
  • Home Movies
  • More »
"Amazing camcorder, great pictures. This is a camcorder, not more. You won't find special effects in it, like "super slowmotion" or "time lapse recording" nor "cinema look", but you'll be able to take amazing shots, that's what really matters, a plenty of adjustments can be made even in the AUTO or i …"  Read Full Review »
Sep 2 2009
Belém, Brazil
I am:
  • Semi-pro Videographer
[3 of 3 customers found this review helpful]
Best Value for HD
4.0
    Pros
  • Durable
  • Great Picture Quality
  • Simple Controls
  • Versatile
    Cons
  • None
    Best Uses
  • Documentaries
  • HD Shooting
"I run multimedia for a church and this is a great entry level camera. The only bad thing was I couldn't import any files to Premier Pro or Windows Movie maker. They have to be uploaded to a cyberlink program and rendered, wasting precious time. Other than that I would recommend this to anyone trying …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Nov 17 2008
Kev
Portage, IN
I am:
Reviewed at:
Very Good for the Price
4.0
    Pros
  • Versatile
    Cons
  • Complicated To Operate
  • Poor Battery Life
    Best Uses
  • Home Movies
  • Travel
"I love the camcorder works great and has a good price but there are somethings you should know before buying this product. First, the batterie does not last more than one hour because the LCD screen has to be opened in order to record. Second, sometimes the hard-drive will get really hot and the cam …"  Read Full Review »
Mar 24 2009
Luciano
Santa Monica, CA
I am:
  • Casual User
Reviewed at:
Good, but a pain for some software
4.0
    Pros
  • Great Features
  • Simple Controls
    Cons
  • Bad File Format
    Best Uses
  • Home Movies
"All in all this is a good camcorder. It's got plenty of features at a great price. The only reason I'm not giving it 5 stars is because of it's proprietary video file wrapping. In other words, the MPEG format is "wrapped" by JVC to create a custom file format (extension .TOD).
Why does this matte …"  Read Full Review »
Apr 21 2009
JohnB
Portland, OR
I am:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
