Close Login Module
Join
JVC DVD and VCR Combo Recorder (Model #DRMV150B)
#1
4.4
based on 17 reviews
Ratings Distribution
5 star
7
4 star
9
3 star
1
2 star
0
1 star
0
Category Average
3.5
$225.56 - $249.98
from 10 stores
More Images
Pros
  • Consistent performance (7)
  • Easy to use (7)
  • Attractive design (6)
  • Easy setup (6)
  • High quality picture (5)
  • Fast setup (4)
  • Simple controls (4)
  • Fast recording (3)
  • Compact (2)
  • Atsc tuner (1)
See less See more
Cons
  • Difficult to set up (3)
  • Ampm not automatic (1)
  • Complicated (1)
  • Deceptive (1)
  • Difficult to use (1)
  • Manual needs improvement (1)
  • Sort of hard to set up (1)
  • Sort of hard to use (1)
  • Unpredictable (1)
Best Uses
  • Home (11)
  • Movies (4)
  • Archiving tv shows (2)
  • Atsc tuner (1)
  • Hd digital tuner (1)
  • High volume usage (1)
  • Home theater (1)
  • Lots of recording (1)
  • Tv program recorder (1)
Where to Buy
BizRate Rating Outstanding 9.0
$225.56
$225.99
$225.99
Show all 10 stores
Product Reviews
Last update: Oct 20, 2009
JVC DVD and VCR Combo Recorder (Model #DRMV150B) Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
[3 of 3 customers found this review helpful]
4.0
Great dvd/vcr recorder!
"Pros: Can't believe the price! [$] through JR.com and it got better reviews than LG and Panasonic dvd/vcr recorders. At another store, they wanted $279 for an LG and $309 for the Panasonic and got not so good reviews on them. This has digital tuner, picked up an extra 12 channels. Has multiple format recording on dvd (can record on virtually any type of dvd)Navigating through menus is easy(if you're sort of a te..." Read Full Review »
Aug 10, 2009 by smithmas
See more positive JVC DVD and VCR Combo Recorder (Model #DRMV150B) reviews
3.0
.JVC Combo
"Falls short of my expectations. JVC use to make fully funtional vcrs and recorders. This is not one of them. Too many things left out of the machine. Don"t ever lose the remote control. You"l be hard pressed to know where you are. My biggest grip abouth this unit is deep into the manual it says this digital tuner enhances DTV. That, folks means this is a hybrid tuner and not a true 8vsb. This shows clearly on A@..." Read Full Review »
Jul 28, 2009 by ROB
See more negative JVC DVD and VCR Combo Recorder (Model #DRMV150B) reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
.JVC Combo
3.0
    Pros
  • Simple Controls
    Cons
  • None
    Best Uses
  • Archiving TV Shows
  • Movies
"Falls short of my expectations. JVC use to make fully funtional vcrs and recorders. This is not one of them. Too many things left out of the machine. Don"t ever lose the remote control. You"l be hard pressed to know where you are. My biggest grip abouth this unit is deep into the manual it says this …"  Read Full Review »
Jul 28 2009
ROB
Rhode Island.
I am:
  • Power User
Reviewed at:
Price: $229.00
4.0
    Pros
  • Consistent Performance
    Cons
    Best Uses
  • Home
"Pros: Can't believe the price! [$] through JR.com and it got better reviews than LG and Panasonic dvd/vcr recorders. At another store, they wanted $279 for an LG and $309 for the Panasonic and got not so good reviews on them. This has digital tuner, picked up an extra 12 channels. Has multiple forma …"  Read Full Review »
Aug 10 2009
smithmas
Charleston, SC
I am:
  • Casual User
Reviewed at:
Price: $229.00
The best DVR/DVD/VHS player around!
5.0
    Pros
  • Dolby Digital
  • Easy To Set Up
  • Easy To Use
  • Great digital tuner
  • More »
    Cons
  • None so far
    Best Uses
  • HD digital tuner
  • Home
  • TV program recorder
"I had purchased two DVD recorder before this one. The Panasonic DMR-EZ48VK which had issues with the HMDI cable and signal, digital tuner sucked, would shut off for no reason, etc. Sent it back. And a Toshiba DR570 which well let me say was very lacking. I ordered the JVC as my final attempt and I h …"  Read Full Review »
Sep 8 2009
Steve
Kamuela, HI
I am:
  • Enthusiast
Reviewed at:
Price: $229.00
[2 of 2 customers found this review helpful]
Hi tech; old user.
4.0
    Pros
  • Attractive Design
  • High Quality Picture
    Cons
  • Complicated
  • Deceptive
  • Difficult To Set Up
  • Difficult To Use
  • Unpredictable
    Best Uses
  • Home
"Undeniable high quality and superior engineering.
Unfortunately, I am, at eighty, a generation late for easy use of all this recorder's advanced features. Especially slow to understand all the different DVD formats and how to adapt the MV150B to suit.
VCR recording is easier but between recording …"  Read Full Review »
Aug 22 2009
Hugh
Nashville, TN
I am:
  • Casual User
Reviewed at:
Price: $229.00
[14 of 14 customers found this review helpful]
To Date Very, Very Satisfied
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Lots of Recording
  • Movies
"Easy to set up and easy to progam "
May 26 2009
Beverly Hills Hillbillie
Beverly Hill Florida
I am:
  • Enthusiast
Reviewed at:
Price: $229.00
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$225.56
$225.99
$225.99
$229.00
BizRate Rating Outstanding 9.3
$229.98
$229.99
$233.99
$233.99
BizRate Rating Outstanding 9.1
$239.95
$249.98
Out Of Stock
$218.99
$229.95
$1.99 Shipping on Orders Over $75
$229.95
$1.99 Shipping On Orders Over $100 at TigerDirect
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
