Jensen Water Resistant Gimble Mount Stereo Housing w/Ipod/Mp3 Slot
2.7
based on 3 reviews
Ratings Distribution
5 star
0
4 star
1
3 star
1
2 star
0
1 star
1
Category Average
4.4
More Images
Pros
  • Attractive design (2)
  • Easy to install (1)
See less See more
Cons
  • Difficult to set up (1)
  • Mount legs not sturdy (1)
Best Uses
  • Large boats (1)
  • Small boats (1)
Provided by BoatersWorld.com
The MGH300 is the fundamental Gimble Mount water resistant housing unit for securing marine stereo systems in any outside environment. This unit is designed to hold a standard DIN mount marine stereo. Along with the added bonus of a side pocket storage area, the gimble housing unit is developed for easy universal installation, reliability, and precise fit. Keep any stereo system dry even when rocking the boat.
Holds standard DIN size stereo with extra side pocket for iPod or MP3 Player
Simple bracket design
Single piece front door
DIN stereo compatibility
Wide, adjustable side brackets for universal installation
Rear rubber support for stereo security
UV stable plastic
Jensen Water Resistant Gimble Mount Stereo Housing w/Ipod/Mp3 Slot Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Water Resistant Gimble Mount Stereo Housing w/Ipod/Mp3 Slot
See all eBay results
  at eBay.com
Product Reviews
Last update: Jan 5, 2009
Jensen Water Resistant Gimble Mount Stereo Housing w/Ipod/Mp3 Slot Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
dont alwas trust the big name
1.0
    Pros
  • Attractive Design
    Cons
  • Difficult Setup
    Best Uses
  • None
"this product is fair at best
the top does not fit well and needs to be screwed down
the side mount screws dint not work on one side
I had to buy rubber washers to take up the spce that the screws would not fasten
the directions show a space for an MP3 and the cord going out the back BUT there …"  Read Full Review »
Was this Speaker Stand & Mount review on the Jensen Water Resistant Gimble Mount Stereo Housing w/Ipod/Mp3 Slot helpful to you?
Jan 5 2009
Drew
Cheshire
I am:
  • Tech Savvy
Reviewed at:
works ok, cheap mount legs
3.0
    Pros
  • Easy To Install
    Cons
    Best Uses
  • Large Boats
  • Small Boats
"Product works as advertized. The mount legs are cheaply made. I have read other reviews about them breaking. I made .030 stainless metal legs to mount on the inside of the plastic legs to add strenght. "
Jun 14 2007
Scuba00573
Savannah, Ga
I am:
  • Recreational
Reviewed at:
Jensen Gimble Mount Stereo Housing
4.0
    Pros
  • Attractive Design
    Cons
  • None
    Best Uses
  • None
"The plastic door doesn't stay closed but otherwise works great as I mounted inside T-top storage compartment being water resistant is not a big deal. Under this condition I recommend it to a friend. "
Dec 14 2008
Snapper
Orlando, FL
I am:
  • Practical
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
