Jensen Jdsc-ir100a Wireless Infrared Remote Control Extender ( Jdscir100a)
#36
2.3
based on 21 reviews
Ratings Distribution
5 star
2
4 star
6
3 star
0
2 star
2
1 star
11
Category Average
4.2
$25.86 - $51.99
from 5 stores
More Images
Pros
  • Easy setup (2)
  • Easy to install (2)
  • Easy to use (2)
  • Had potential (1)
See less See more
Cons
  • Weak signal (2)
  • But failed to deliver (1)
  • It can be fixed (1)
  • Poor internal design (1)
Best Uses
  • Gun target (1)
  • Music (1)
  • Upgrade (1)
Provided by Beach Audio
  • Receivers allow infrared remote to be used up to 100' away
  • Converts any infrared remote to a through-wall RF remote
  • Includes infrared emitter for when line of sight placement is not possible and 2 AC adapters
  • Shipping package dimensions: 8.25x12.25x3 (len x wid x dep)
  • Jensen Jdsc-ir100a Wireless Infrared Remote Control Extender ( Jdscir100a) Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 17, 2009
    Jensen Jdsc-ir100a Wireless Infrared Remote Control Extender ( Jdscir100a) Reviews
    Most helpful positive review
    [5 of 5 customers found this review helpful]
    Most helpful negative review
    4.0
    PLEASE READ THIS REVIEW
    "I have a theater room and my equipment is hidden in a closet. I found this at best buy, and gave it a try. NOW YES, THE reviewers here are correct the IR range is terrible no more than 5 feet away from the remote to work, HOWEVER THIS CAN BE FIXED EASILY!...You must open up the IR Transmitter unit carefully (DONT OPEN THE IR RECEIVER THERE IS NO NEED TO). Inside you will see a goldish squared shape wires within ..." Read Full Review »
    Dec 27, 2008 by mdjiron
    See more positive Jensen Jdsc-ir100a Wireless Infrared Remote Control Extender ( Jdscir100a) reviews
    1.0
    All You Have To Do Is Take It Apart
    "It works to deliver the signal as long as the remote control is 1" from the receiver. I took the receiver apart, cut the foil, that helped, but not great. Then I noticed the little receiver thing was tucked inside the metal box too far, so I pried it up. Ok now it works ok, but as soon as I put the plastic back on, nothing. So now I have a circuit board with an antenna laying there, and the range works ok. ..." Read Full Review »
    Feb 20, 2009 by Pantyhose Guy
    See more negative Jensen Jdsc-ir100a Wireless Infrared Remote Control Extender ( Jdscir100a) reviews
    Displaying 1 - 5 of 21 Reviews
    Show
    Sort by
    4.0
    "I have a theater room and my equipment is hidden in a closet. I found this at best buy, and gave it a try. NOW YES, THE reviewers here are correct the IR range is terrible no more than 5 feet away from the remote to work, HOWEVER THIS CAN BE FIXED EASILY!...You must open up the IR Transmitter unit c …"  Read Full Review »
    Was this Satellite Radio Accessory review on the Jensen Jdsc-ir100a Wireless Infrared Remote Control Extender ( Jdscir100a) helpful to you?
     Report Abuse  (5)  (0)  0 comments
    Dec 27 2008
    mdjiron
    Raleigh, NC
    Reviewed at:
    Price: $51.99
    1.0
      Pros
    • Nothing
      Cons
    • Weak Signal
      Best Uses
    • Gun Target
    "It works to deliver the signal as long as the remote control is 1" from the receiver. I took the receiver apart, cut the foil, that helped, but not great. Then I noticed the little receiver thing was tucked inside the metal box too far, so I pried it up. Ok now it works ok, but as soon as I put t …"  Read Full Review »
    Feb 20 2009
    Pantyhose Guy
    Alto, MI
    I am:
    • Gearhead
    Reviewed at:
    [1 of 1 customers found this review helpful]
    Modify as stated below works great!
    2.0
      Pros
    • Easy To Install
    • Easy To Use
      Cons
    • Poor Internal Design
      Best Uses
    • Music
    "I thought at first batteries in remote were bad. Put a fresh set in and still only got around 5 ft. in plain view of transmitter and receiver. Read "improve" post below and modified. Now 28 ft. on next room and works great! Internal design does need to be redesigned. I would really like to know what …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Jan 2 2009
    ripperjoe
    Gaffney,SC
    I am:
    • Quality Oriented
    Reviewed at:
    [2 of 2 customers found this review helpful]
    Improve your Jensen Wireless Remote rang
    4.0
      Pros
    • Easy To Set Up
      Cons
    • It can be fixed
      Best Uses
    • Upgrade
    "I notice the same thing most reviewers state, poor transmitter performance unless you hold your IR remote very close. I split the case open, cut the tiny wire screen that seems to block the IR receiver, bingo, range is excellent, you would think the manufacturer would change the design? when every …"  Read Full Review »
     Report Abuse  (2)  (0)  0 comments
    Jun 17 2008
    dualsport
    BC canada
    I am:
    • Tech Savvy
    Reviewed at:
    Does Not Work
    1.0
    "No matter what I tried I could not get this thing to work unless I was standing in one particular spot about 5' away from the transmitter. The receiver was directly above the ceiling and literally less then 4' away from the transmitter. I even tried the IR extender but no dice. The problem seemed to …"  Read Full Review »
    Feb 5 2008
    farmergary
    Anaheim, CA
    Reviewed at:
    Price: $51.99
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
