JBL SUB10 Venue Series Subwoofer
4.7
based on 102 reviews
Ratings Distribution
5 star
85
4 star
12
3 star
1
2 star
2
1 star
2
Category Average
4.4
More Images
Pros
  • Easy to connect (20)
  • Great sound quality (19)
  • Attractive design (17)
  • Powerful (14)
  • Compact (8)
  • Heart pounding (1)
  • High quality (1)
See less See more
Cons
  • Not durable (1)
  • Not very powerful (1)
  • Poor sound quality (1)
Best Uses
  • Larger rooms (14)
  • Basic systems (13)
  • Audiophiles (11)
  • Smaller rooms (9)
  • Enhances whole system (1)
Provided by Beach Audio
" The Venue Series SUB10 powered subwoofer is just the ticket to bring your home theater system to life.
" The SUB10 performs like a pro, with technology developed by JBLs Professional division. Equipped with JBL's tried-and-true PolyPlas" woofer, this subwoofer delivers the low-frequency goods. Special effects in your favorite movies, assisted by the FreeFlow" flared port, are loud and clear, without unwanted distortion or boominess. A powerful amplifier backs up the 10-inch woofer with high-output. LFE- and line-level inputs provide maximum connection flexibility. Convenient level and crossover-frequency controls and a phase switch let you tailor the SUB10's performance to your room's acoustics or your taste.
" Available in a black wood-grain finish with an attractive silver grille.
JBL SUB10 Venue Series Subwoofer Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: SUB10 Venue Series Subwoofer
See all eBay results
  at eBay.com
Product Reviews
Last update: Aug 20, 2009
JBL SUB10 Venue Series Subwoofer Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
5.0
Awesome Sub
"I just upgraded from a Sony 8" to this sub and there is no comparison. This 10" sub really does rattle the walls. The sound is awesome, with left and right RCA inputs it really makes a difference when your watching action movies, the bass sounds like it travels from side to side with the surround sound. It is really easy to use the gain and low frequency controls, turn it on and tune it to your preference. I als..." Read Full Review »
Nov 26, 2007 by Trewett
See more positive JBL SUB10 Venue Series Subwoofer reviews
3.0
Great When It's Not Broke
"When I first bought this system and installed it, it sounded awesome. Movies, T.V., Races, games, everything had good full sound and deep rich bass. About 6 months after having it, the sound from the sub got weaker and I kept having to turn up the gain to maintain performance. Eventually, it stopped working altogether. The power light on the front would still turn from red to blue when the receiver was turned on..." Read Full Review »
Jul 12, 2008 by electric130
See more negative JBL SUB10 Venue Series Subwoofer reviews
Displaying 1 - 5 of 102 Reviews
Show
Sort by
Awesome Sub
5.0
"I just upgraded from a Sony 8" to this sub and there is no comparison. This 10" sub really does rattle the walls. The sound is awesome, with left and right RCA inputs it really makes a difference when your watching action movies, the bass sounds like it travels from side to side with the surround so …"  Read Full Review »
Was this Speaker & Subwoofer review on the JBL SUB10 Venue Series Subwoofer helpful to you?
 Report Abuse  (2)  (0)  0 comments
Nov 26 2007
Trewett
Texas
Reviewed at:
Excellent Value
4.0
    Pros
  • Compact
  • Easy To Connect
  • Great Sound Quality
    Cons
  • None
    Best Uses
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"I needed a sub for a moderately sized room for use with my home theatre (primarily movies and TV and not much music). The price was right and the size works well for the room.
Pros: Very good response with no noticiable distortion at normal to elevated listening levels. Excellent for movie bass …"  Read Full Review »
Apr 10 2008
Padawon X
Indianapolis, IN
I am:
  • Audiophile
  • Practical
  • Tech Savvy
Reviewed at:
Great subwoofer, even better price
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"I had been looking for a sub for a while and found this one. It blows most subs in this power category away with its ability to hit at low frequencies, and still have fast clear bass for any type of music. Since its JBL you get a good warranty with it plus the assurance that you bought a high qualit …"  Read Full Review »
May 22 2008
Adam
Kennesaw, GA
I am:
  • Professional
  • Tech Savvy
Reviewed at:
My God......
5.0
"Just to let you know, i've sang in choir my entire life, i play the guitar, and piano. Music is a big part of my life, and so therefore sound is very important. I love watching movies at home. I first started out with little speakers the THX certified Logitech Z-2300, then played through my laptop w …"  Read Full Review »
Apr 7 2009
toughpinoy
Houston, TX
Reviewed at:
Excellent Value, Performance and Quality
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • High Quality
  • Powerful
    Cons
  • NONE
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"Bought the Polk Audio box surround system. Sattelites are great but the sub is pathetic. Added the JBL SUB 10 and WOW, what a difference. Can shake the room with movies, sports, etc, or can make it subtle. Using in a very large room with a 52" Sony LCD. Is very well made, high quality and looks …"  Read Full Review »
Jun 19 2008
Mariniac
Newark, DE
I am:
  • Musically Inclined
  • Perfectionist
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
