JBL PRX515 - 2-Way Powered 500 Wats
#204
5.0
based on 3 reviews
Ratings Distribution
5 star
3
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
Low Price:
$849.95 at B&H Photo Video
 Trusted:
$899.00 at Musician's Friend
Find it at Amazon
$849.95 - $949.99
from 4 stores
Pros
  • Great sound quality (3)
  • Attractive design (2)
  • Easy to connect (2)
  • Powerful (2)
  • Compact (1)
  • Powerful bass (1)
See less See more
Best Uses
  • Audiophiles (1)
  • Medium events (1)
  • Wedding halls (1)
  • When you want to impress (1)
Provided by PSSL.com - ProSound and Stage Lighting
For every musician, DJ, venue and audio/video provider, high-performance self-powered speaker systems offer a degree of simplicity unmatched by traditional amp and speaker PA systems. Not only are all components matched right out of the box, but they are optimized for maximum reliability. By considering every element in each system and its contribution to the final application PRX500 redefines high performance portable PA. Through design, PRX500 delivers the power, performance and simplicity you need in a package that’s been designed to move. The 2-way 15"; the most recognizable form of portable PA loudspeakers, the perfect balance between size and performance. The PRX515 truly is an exception; it’s smaller and lighter without compromising on performance. Features: Differential Drive® woofer 1.5" annual polymer diaphragm compression driver Class-D, Crown® digital amplifier DSP input section with crossover, dynamic limiting, component optimization, selectable system EQ Professional XLR line and 1/4" Mic/Instrument inputs, with loop through Illuminated logo for clear Power-On status Integrated pole mount socket DuraFlex™ coated plywood construction Polypropylene end-caps enhance durability Wrap around heavy duty steel grille provides protection without obstructing performance. Large die-cast aluminum handle bar with a fine tuned ergonomic rubber grip for maximum comfort Specifications: Frequency Range: 45 Hz – 20 kHz Frequency Response: 52 Hz – 20 kHz Nominal Impedance: 64 K Ohms (balanced), 32 K Ohms (unbalanced) Power Capacity: 500 W continuous, 1000 W peak Rated Maximum SPL: 133 dB SPL peak Coverage Pattern: 70º x 70º nominal Dimensions (H x W x D): 815 mm x 440 mm x 465 mm (32 in x 17.25 in x 18.25 in) Weight: 26 kg (57 lb) High Frequency Driver: 1 x JBL 2408F 37.5 mm (1.5 in) annular polymer diaphragm, neodymium compression driver Low Frequency Driver: 1 x JBL 265F 380 mm (15 in) Differential Drive® woofer The 2-way 15"; the most recognizable form of portable PA loudspeakers, the perfect balance between size and performance. The PRX515 truly is an exception; it’s smaller and lighter without compromising on performance. For applications requiring full bandwidth sound reproduction, using only a pair of speakers, the PRX515 delivers the optimum balance. For live music, recorded music playback and speech the user has the option of tailoring the EQ, ‘flat’ for speech intelligibility, and ‘boost’ for enhanced bass and crisp highs in recorded music playback. A microphone can be directly connected to the speaker input for quick on-the-fly PA applications. The PRX515 is a self-powered, lightweight two-way loudspeaker system capable of delivering a very high level of performance. The PRX515 is comprised of a 380 mm (15 in) 265F Differential Drive® woofer, a 2408H 37.5 mm (1.5 in) annular polymer diaphragm, neodymium compression driver mounted to a 70° by 70° horn, all driven by a multi-channel Crown International Class-D digital power amplifier. A propriety DSP chip is at the
JBL PRX515 - 2-Way Powered 500 Wats Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 16, 2009
JBL PRX515 - 2-Way Powered 500 Wats Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
Best powered speakers out there!
5.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • NONE
    Best Uses
  • Medium Events
"After owning JBL eon's I was hesitant in getting another pair so when I went shopping for new powered speakers I didn't even think about looking at the PRX line. I had my mind set on the QSC's. After going to my local music store to hear the QSC's they sounded great but were 100lbs each!!!! I'm not …"  Read Full Review »
Was this Speaker & Subwoofer review on the JBL PRX515 - 2-Way Powered 500 Wats helpful to you?
Apr 25 2008
John
Long Beach, CA
I am:
  • Professional DJ 10 years
Awesome Sound, Lightweight
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Wedding Halls
"These speakers are compact and very lightweight. They produce a great sound. I have them connected to the PRX-718 Powered Sub by JBL. All of it together sounds great and produces more than enough sound for a larger wedding or School dance. (Thats all I've used them for) I would expect them to work g …"  Read Full Review »
Sep 16 2009
BREW CITY DJ'S
Milwaukee, WI
I am:
  • Audiophile
  • Professional
  • Tech Savvy
You get what you pay for!
5.0
    Pros
  • Great Bass
    Cons
  • No Cons
    Best Uses
  • Audiophiles
  • when you want to impress
"When I was shopping for a new set of powered speakers,I started to look at another set of Mackies,noticed the JBL's next to them,sure they are more money,but they completely blew away every other powered speaker on display.Mackies,no match,QSC's,oh please!I will be trading in my Mackie's,and trading …"  Read Full Review »
Nov 2 2007
DJ JEEM
Branchburg,NJ
I am:
  • Audiophile
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
