JBL MRX-528S Dual 18In/1000W @ 4 Ohms Subwoofer *
#452
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
$949.99 at PSSL.com - ProSound and Stage Lighting
Find it at Amazon
Find it at Ebay
$949.99
from 1 store
Pros
  • Great sound quality (2)
  • Attractive design (1)
  • Easy to connect (1)
See less See more
Best Uses
  • Outdoors (1)
Provided by PSSL.com - ProSound and Stage Lighting
JBL MRX-528S DUAL 18IN/1000W @ 4 OHMS SUBWOOFERThe MRX528S is a compact, high power subwoofer system containing dual 2044H 18" woofer in a front-loaded, vented enclosure. The enclosure is designed to present a minimum frontal area. It is also configured in an upright format to permit the convenient stacking of fullrange enclosures on top without the need for an additional pole. The system offers complete input connection flexibility for compatibility with a variety of cabling schemes. The input panel incorporates a pair of Neutrik? Speakon? NL-4 connectors wired in parallel. The MRX528S is supplied with pins +1/-1 connected to the woofer. This may be easily reconfigured to work with cabling systems intended to drive subwoofers on pins +2/-2. The enclosure is constructed of quality plywood, coated in JBL's rugged DuraFlex? finish and is braced to maximize low-frequency performance. The attractive CNC-machined, 16-gauge steel grille is internally lined with an acoustically transparent screen to provide additional driver protection and give a very professional appearance.Features:Dual 18 inch, 2044H drivers for extendedlow-frequency outputLarge vents for reduced distortionVertical orientation for convenient ground stackingTough DuraFlex? enclosure finishSpecifications:Frequency Range: 35 Hz - 250 HzFrequency Response: 40 Hz - 250 HzSensitivity: 97 dB SPL; 103 dB SPLNominal Impedance: 4 ohmsPower Capacity: 1000 W / 2000 W / 4000WRated Maximum SPL: 133 dB SPL continuous(139 dB SPL peak)Coverage Pattern: 70? x 70? nominalSize (H x W x D): 43" x 21" x 27.5"Weight: 121 lbs.Low Frequency Driver: 2 x JBL 2044H 18" woofers
JBL MRX-528S Dual 18In/1000W @ 4 Ohms Subwoofer * Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Feb 16, 2009
JBL MRX-528S Dual 18In/1000W @ 4 Ohms Subwoofer * Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
it' a powerful sub
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
    Cons
  • None
    Best Uses
  • Outdoors
"I have a pair of jbl's rmx 528s power w/ qsc rmx 2450 one for each speaker.. and they pound hard.. i don't have a problem w/ my sub.. they are great.. i would recommend them... "
Was this Speaker & Subwoofer review on the JBL MRX-528S Dual 18In/1000W @ 4 Ohms Subwoofer * helpful to you?
Feb 16 2009
motadelcampo
fresno
I am:
  • Professional
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
