JBL EON515 450 Watt Powered 15" Portable Speaker
#891
4.0
based on 7 reviews
Ratings Distribution
5 star
4
4 star
0
3 star
2
2 star
1
1 star
0
Category Average
4.4
$799.99 at PSSL.com - ProSound and Stage Lighting
Find it at Amazon
Find it at Ebay
$799.99
from 1 store
More Images
Pros
  • Great sound quality (10)
  • Easy to connect (6)
  • Attractive design (5)
  • Lightweight (3)
  • Powerful (2)
  • Compact (1)
  • Ease of portability (1)
  • Nice looking (1)
  • Powerful bass (1)
See less See more
Cons
  • Lack of power (3)
  • Needs bigger tweeter (1)
Best Uses
  • Basic systems (6)
  • Smaller rooms / apartments (5)
  • Outdoors (4)
  • Audiophiles (1)
  • Home theater (1)
  • Portability (1)
  • Pro audio / dj / mixing (1)
Provided by PSSL.com - ProSound and Stage Lighting
JBL EON515 450 Watt Powered 15" Portable Speaker In addition to acoustic performance the EON515 features three full size deep-well handles, light weight, and balanced ergonomics. The new generation of EON products offers true portability and ease of handling. Five standard M10 rigging points and integrated pole mount socket increase the system’s utility. The extremely rugged copolymer enclosure has been designed for main and 45° monitor orientation in the left and right hand configuration. A full screen-backed steel grille offers additional protection for both the woofer and compression driver components. Features: 450 watt High-Performance Powered Speaker System True portability weighing only 14.8 kg (32.5 lb) Multiple handles with comfort rubber grips for easy transport 15" Differential Drive® low-frequency driver with neodymium magnet for low-distortion and light weight 1" throat diameter next generation JBL neodymium compression driver Efficient Crown® Class-D amplifier technology Built-in 3 Channel Mixer 100° H x 60° V asymmetrical wave guide for uniform audience coverage Line level and direct microphone input capability Selectable Pre-engineered EQ settings Unique Mix/Loop signal flow function for extended system application Easy “daisy-chain” connections for extending the system Integrated M10 suspension points for easy rigging Multi angle enclosure for main or monitor applications Integrated 36 mm pole mount socket with stabilizing securing screw Highly designed composite enclosures for durability, lightweight, and acoustic performance Specifications: System Power Rating: 450 W continuous, 900 W peak Frequency Range (-10 dB): 39 Hz -20 kHz, (EQ in ‘Flat’ position) Dimensions (H x W x D): 27.0 in x 17.3 in x 14.4 in (685 x 438 x 366 mm) Frequency Response (±3 dB) : 42 Hz - 18 kHz (EQ in ‘Flat’ position) Coverage Pattern: 100° H x 60° V nominal Maximum SPL: 129 dB Net Weight: 14.8 kg (32.5 lb) Applications: Live sound reinforcement, speech and vocals, music playback in entertainment, A/V, and institutional venues – especially when ease of use and portability are important factors. Amplification, mixing, and monitoring for electronic musical instruments. Everywhere you need to be heard.
JBL EON515 450 Watt Powered 15" Portable Speaker Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 31, 2009
JBL EON515 450 Watt Powered 15" Portable Speaker Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
JBL REALLY ROCK !!!
5.0
Great Rave
Great Rave
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Outdoors
"I own 2 pairs of these babies, they sound incredibly crisp and the fidelity is awesome, also added to my mobile system 2 PRX518S SUBS nad already had 2 JRX118SP. You really have to hear this system, 4 JBL EON515, 2 PRX518S and 2 JRX118SP and you have a total of 3,400 Watts RMS.
I have used this sy …"  Read Full Review »
Was this Speaker & Subwoofer review on the JBL EON515 450 Watt Powered 15" Portable Speaker helpful to you?
Jun 4 2009
DJ MSK
Guatemala, City, C.A.
I am:
  • Professional
JBL EONS do it again.
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Ease of Portability
  • Easy To Connect
  • More »
    Cons
  • None
    Best Uses
  • Basic Systems
  • Outdoors
  • Smaller Rooms
"This speaker surpasses all the horror stories you have heard about Self Powered speaker systems. They do not go thermal and shut down like those other brands, you which ones.LOL! These speakers gave an impressive output and the horn delivered far beyond my expectations. If you need a good speaker th …"  Read Full Review »
JBL EON15P and G2s coveringcity of Hagtana
  • Using Product
  • Dec 08 2008
Jan 6 2009
DJ Peak-a-Boo
Guam, USA
I am:
  • Professional
  • Tech Savvy
All that & a Bag of Chips!!!
5.0
    Pros
  • Attractive Design
  • Compact
  • Crisp Sound
  • Easy To Connect
    Cons
  • NONE
    Best Uses
  • Audiophiles
  • Basic Systems
  • Home Theater
  • Outdoor Venues
  • Smaller Rooms
"Yeah we all heard the self powered horror stories... But I will say that this System Rocks! If you are a Sound Engineer/ DJ/ Musician/ or just a Fanatic, this speaker is for you. I have used Eons since the first release. I still have my first pair. I also use the G2's. Just when I thought you couldn …"  Read Full Review »
Jan 5 2009
DJ Peak-A-Boo
Guam, USA
I am:
  • Audiophile
  • End User
  • Musically Inclined
  • Professional
  • Tech Savvy
[1 of 1 customers found this review helpful]
MACKIE SRM 450 VS JBL EON 515
3.0
    Pros
  • Lightweight
  • NICE LOOKING
    Cons
  • Not Very Powerful
    Best Uses
  • Basic Systems
  • Smaller Rooms
"If you want lightweight these are the speakers for you. and you can run it all night and it does not heat up. Even outside. As for the sound, Even tho they claim higher wattage then prev models. I don't hear it. Highs are not loud enough. and I think they are approx 20% lower then the older EONS.. …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Feb 14 2009
GEOMET
MIAMI, FL
I am:
  • DJ Audio Eng
  • Tech Savvy
Eon G2 are still the BEST!!
2.0
    Pros
  • Crisp Sound
  • Easy To Connect
  • Lightweight
    Cons
  • Not Very Powerful
    Best Uses
  • Basic Systems
  • Outdoors
  • Smaller Rooms
"If you need volume to fill med,large rooms you will need a drive rack. The Eon G2s dose not need any help with power! I was about to buy the new 515s untill my fellow dj's told me about the power of the older Eon G2s and the savings at about $300. less. 46lbs on the G2s vs 34lb on the 515s only the …"  Read Full Review »
Aug 31 2009
dj geno
San Diego,CA
I am:
  • Professional
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
