JBL EON-15-P1 Powered Speaker 15In 2 Way
3.7
based on 3 reviews
from
Ratings Distribution
5 star
1
4 star
1
3 star
0
2 star
1
1 star
0
Category Average
4.4
Pros
  • Durable (2)
  • Good value (2)
  • High quality (2)
See less See more
Cons
  • Knob placement (1)
  • Pricey (1)
  • Screw on back (1)
  • Shape (1)
  • Sound (1)
Best Uses
  • Most dj applications (1)
Provided by PSSL.com - ProSound and Stage Lighting
JBL EON 15-P1: Powered Speaker SystemThe JBL EON 15-P1 is a single input powered speaker system ideal for sound reinforcement, speech, vocals and music playback. Compact and rugged, the EON-15-P1 will serve you well on the road or in an installed setting. If you're looking for superior audio quality in a highly portable package, the EON-15-P1 is your ticket to ride.Features: 15" differential drive low frequency driver with neodymium magnet for light weight and reduced distortion1" (throat diameter) JBL compression driver with 1.75" titanium diaphragm and ferro-fluid coolingInternally bi-amped: 130 watts LF; 50 watts HFOne balanced mic/line switchable XLR inputLoop-through XLR output for daisy-chaining additional EON speakers90° x 60° (nominal) constant directivity hornThermomaster Total Thermal Management System: single piece cast-aluminum baffle integrated with the woofer frame, horn and amplifier heat sink allows air movement in the finned ports and dissipates heat; no fans requiredRugged lightweight co-polymer enclosureIntegral 35mm pole mount receptacle with securing thumbscrewMulti-angle enclosure for front of house or stage monitoring applicationIntegral attachment points for optional JBL and third-party mounting bracketsFrequency response: 47Hz - 18kHz (-10dB)Size: 27"h x 17"w x 17.5"d. Wt. 47 lbs.
JBL EON-15-P1 Powered Speaker 15In 2 Way Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: EON-15-P1 Powered Speaker 15In 2 Way
See all eBay results
  at eBay.com
Product Reviews
Last update: Mar 8, 2007
JBL EON-15-P1 Powered Speaker 15In 2 Way Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
What was JBL thinking?
2.0
    Pros
  • None
    Cons
  • Knob placement
  • Screw on back
  • Shape
  • Sound
    Best Uses
  • None
"We use these at the hotel for corporate audio visual. The sound is average. I really expected more from JBL. The control knobs, power switch, power outlet, and speaker XLR jack are in the worst place possible. If these speakers are up on stands, you had better have a step ladder to reach anything. T …"  Read Full Review »
Was this Speaker & Subwoofer review on the JBL EON-15-P1 Powered Speaker 15In 2 Way helpful to you?
 Report Abuse  (1)  (0)  0 comments
Mar 8 2007
DJCANAAN
Sacramento, CA
Reviewed at:
Nice for the price
4.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • Most DJ applications
"I like the sound of this speaker very much, and it's easy to use. There's plenty of power and I've played large rooms on three qaurters of power. My only complaint is the angled back. This can add wear and tear to your vehicle. Other than that, it ROCKS!! "
Dec 7 2006
G-man
Yorba Linda, CA
Reviewed at:
[0 of 1 customers found this review helpful]
Great
5.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • Expensive
    Best Uses
  • None
"All in all anything that you buy for JBL is goin to be good but some of the low end stuff if your arnt using a sub gets a little disorded it you have it really load but all REAlly good and worth it "
 Report Abuse  (0)  (1)  0 comments
Feb 17 2007
DJ M
Gardner Ma
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
