JBL EON-15-G2 Powered 15In 2 Way Speaker +
#771
4.2
based on 10 reviews
from $599.99
Ratings Distribution
5 star
5
4 star
4
3 star
0
2 star
0
1 star
1
Category Average
4.4
Low Price:
$599.99 at GuitarTrader.com
$599.99 at MusiciansPlace.com
Find it at Amazon
More Images
Pros
  • Great sound quality (9)
  • Easy to connect (7)
  • Powerful (7)
  • Attractive design (6)
  • Compact (5)
  • Durable (2)
  • Easy setup (2)
  • Built in mixer and eq (1)
  • Easy for for private gigs (1)
  • Just plug and play (1)
See less See more
Cons
  • Poor sound quality (2)
  • A little muddy without eq (1)
  • Does have lock on xlr inp (1)
  • Harsh highs (1)
  • Heats up quick (1)
  • Heavy / bulky (1)
  • Lower end stuff is better (1)
  • Muddy mids (1)
  • Need heavy duty stands (1)
  • Overpriced as hell (1)
Best Uses
  • Basic systems (7)
  • Smaller rooms / apartments (7)
  • Large rooms (5)
  • Anywhere (1)
  • Entertainment (1)
  • Large halls (1)
  • Mobile dj pwrd monitor (1)
  • Outdoors (1)
  • Pro audio / dj / mixing (1)
  • Small gigs (1)
Provided by PSSL.com - ProSound and Stage Lighting
Powered Speaker SystemJBL's EON15-G2 is a full range professional speaker system with an integrated amplifier and basic mixer built into one compact and affordable package. This versatile system is ideal for a wide variety of applications and is especially easy to set up and transport. Features: 2-channel amplifier built in (300 watts for the woofer and 100 watts for the high frequency driver) Separate amps get just the right amount of power to each driver Built-in 3-input mixer with one balanced XLR mic/line input, two 1/4" line level inputs, plus 2-band equalizer Can also be driven directly from a mixer Innovative shape allows speakers to function as an upright speaker or a tilted stage monitor Built-in pole socket for speaker stands (35mm) Size: 27"h x 17"w x 17.5"d. Wt. 46 lbs.
JBL EON-15-G2 Powered 15In 2 Way Speaker + Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Mar 26, 2009
JBL EON-15-G2 Powered 15In 2 Way Speaker + Reviews
Most helpful positive review
Most helpful negative review
5.0
AMAZING SOUND AND CLARITY....
"These are sick.....very sick! These are the first powered speakers that i ever bought and i will never own another passive....on the mic these make me sound so much more professional (not that i already am not) that was funny right? For real these are well worth the money...if u want some more pounding bass i suggest gettin the powered subs as well...prolly won't need em but that will be the icing..I will never ..." Read Full Review »
Apr 03, 2008 by DJ Dizzle
See more positive JBL EON-15-G2 Powered 15In 2 Way Speaker + reviews
1.0
What are these guys talking about?
"These are very very expensive and overpriced especially when lower end brands like Behringer, who only have a couple good products can beat them in terms of sound quality. They can get loud but sound horrible for anything more than a low to mid volume, and overpriced at that, monitor...." Read Full Review »
Jan 24, 2009 by DJzrule
See more negative JBL EON-15-G2 Powered 15In 2 Way Speaker + reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Connect
  • Great Sound Quality
  • Powerful
  • More »
    Cons
  • Too perfect
    Best Uses
  • ANY ROOM
  • Larger Rooms
  • Smaller Rooms
"These are sick.....very sick! These are the first powered speakers that i ever bought and i will never own another passive....on the mic these make me sound so much more professional (not that i already am not) that was funny right? For real these are well worth the money...if u want some more pound …"  Read Full Review »
Was this Speaker & Subwoofer review on the JBL EON-15-G2 Powered 15In 2 Way Speaker + helpful to you?
Apr 3 2008
DJ Dizzle
Rimersburg, PA
I am:
  • Mobile entertainer
  • Musically Inclined
  • Professional
Reviewed at:
Awsome Speaker
5.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Larger Rooms
"The EON's have been around for a while, and in all reality JBL is the poineer of the powered speakers. I have used these many a time in my business, and I Absolutly love them! They have more than enough power than I needed for a large high school cafetria, as a matter of fact, I had had the volume …"  Read Full Review »
Sep 2 2007
Fastracks Music Services
Omaha, NE
I am:
  • Professional
Reviewed at:
Great speaker on Mobile DJ's
4.0
    Pros
  • Easy To Connect
  • Powerful
    Cons
  • Very front heavy
    Best Uses
  • Basic Systems
  • Mobile DJ
  • Smaller Rooms
"Pretty good speaker for the money. My buddy uses Mackie's. These are certainly comparible dollar for dollar. I do know that the Mackie's add another 50 watts for the highs. It's an unnecassary 50 watts, they're high enough. These are a really well balanced sounding speaker. They are front heavy so l …"  Read Full Review »
Aug 21 2007
DJ Brew
New York
I am:
  • Professional
  • Use them every Saturday
Reviewed at:
1.0
    Pros
  • Loud
    Cons
  • Distorted Sound
  • Harsh Highs
  • Muddy Mids
  • More »
    Best Uses
  • none
"These are very very expensive and overpriced especially when lower end brands like Behringer, who only have a couple good products can beat them in terms of sound quality. They can get loud but sound horrible for anything more than a low to mid volume, and overpriced at that, monitor. "
Jan 24 2009
DJzrule
Merrick, NY
I am:
  • Audiophile
  • DJ
  • PA Mixer
  • Professional
  • Tech Savvy
Reviewed at:
small ones doo damage
4.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Powerful
    Cons
  • Screws get loose
    Best Uses
  • Basic Systems
  • Large halls
  • Outdoors
  • Smaller Rooms
"im a mobile dj these were my first speakers and before i would not use them as loud butt now that i found out the strength of them the people seem to like the sound they put out.. in large rooms as well as small ones... one little con is that the screws get loose after a while and only once has the …"  Read Full Review »
Jan 26 2009
dj peetey
Buellton ,CA
I am:
  • Begginer compared to some
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
