JBL Control 2.4G Wireless Speaker System
#979
3.9
based on 20 reviews
Ratings Distribution
5 star
6
4 star
9
3 star
2
2 star
2
1 star
1
Category Average
4.4
Low Price:
$204.95 at B&H Photo Video
$329.00 at J&R Electronics
Find it at Amazon
$204.95 - $329.00
from 2 stores
Pros
  • Great sound quality (8)
  • Good value (7)
  • High quality (5)
  • Attractive design (4)
  • Durable (3)
  • Easy to connect (3)
  • Quality construction (3)
  • Compact (2)
  • Great price (1)
  • Great sound impressive b (1)
See less See more
Cons
  • Pricey (2)
  • Difficult to set up (1)
  • Heavy / bulky (1)
  • Limited range (1)
  • Lots of wires for wireles (1)
  • Nothing bad i could say (1)
  • Signal pickup lags (1)
Best Uses
  • About 15 ft from tv (1)
  • Audiophiles (1)
  • Basic systems (1)
  • Best wireless choice (1)
  • Educational setting (1)
  • Home sound extension (1)
  • Home theater (1)
  • Multimedia projector (1)
  • Outdoors (1)
  • Play indoors and out (1)
Provided by B&H Photo Video
With JBL's Control 2.4G Wireless Speaker System you can bring high performance sound anywhere in your home. Simply hook your iPod or portable audio player to the wireless transmitter and place the speakers wherever you want great sound. Or use this powered speaker pair as rear surround speakers without having wires all over the place. With 15W per channel and frequency response of 50Hz - 20kHz these wireless speakers will add legendary JBL sound without the nuisance of traditional speaker wires
JBL Control 2.4G Wireless Speaker System Questions
Questions and Answers
Where to Buy
$204.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$329.00
Product Reviews
Last update: Jul 18, 2009
JBL Control 2.4G Wireless Speaker System Reviews
Most helpful positive review
Most helpful negative review
[1 of 2 customers found this review helpful]
5.0
Ideal wireless speackers for my needs
"These wireless speakers fit my needs perfectly, plus I got them refurbished but as good as new for only $120. Sound fine. Easy hook up. Look good. No problems at all. I have them hooked up to a Yamaha RX 497 receiver that can play one audio source through them wirelessly in one area - the den or outside - and the same or a different source through 2 other wired Mission speakers in the living room. The sound i..." Read Full Review »
Jul 18, 2009 by RG
See more positive JBL Control 2.4G Wireless Speaker System reviews
1.0
wireless is misleading
"I wanted a wireless speaker system. The 2 speakers have to be connected to each other, so they have to be in the same room(connected by wires). You can not plug each speaker into an oultet in different rooms ( as I thought I would be able to do). The 2 speakers are remote, but not what I was wanting and what I had bought in the past. Also when using the speakers you can not hear the main radio in the room i..." Read Full Review »
May 27, 2009 by FERAL CHILD
See more negative JBL Control 2.4G Wireless Speaker System reviews
Displaying 1 - 5 of 20 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Great price
  • Great Sound Quality
    Cons
  • None worth mentioning
    Best Uses
I have them hooked up to a Yamaha RX 497 receiver that can play one audio source through them wirelessly in one area - the den or …"  Read Full Review »
Was this Speaker & Subwoofer review on the JBL Control 2.4G Wireless Speaker System helpful to you?
Jul 18 2009
RG
Los Angeles CA
I am:
  • No technical expertise
Reviewed at:
Price: $329.00
One annoying flaw as surround speakers
4.0
    Pros
  • High Quality
    Cons
  • signal pickup lags
    Best Uses
  • Zone 2 speakers
"I have two sets of these. One is out on my deck as a zone 2 speaker set in stereo or from a computer playing rhapsody unlimited to go. They absolutely excel as stereo zone 2 wireless speakers or a single set of stereo speakers. You can plug your computer, IPOD or other MP3 device, in fact anything t …"  Read Full Review »
Jun 19 2008
Jazzman
Knoxville, TN
[1 of 1 customers found this review helpful]
GREAT [wireless] sound, but....
4.0
    Pros
    Cons
  • Difficult To Set Up
    Best Uses
  • Basic Systems
"My JBLs are set up in a bathroom and linked to a bedroom shelf system [a Sharp XL-UH270] via the headphone jack.
I use the Sharp as a glorified alarm clock: the JBLs allow me to sing duets in the shower with Pavarotti and shave to Bach after I do get up. Usually I listen to XM music channels by …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Feb 19 2008
wnaegele
Albuquerque NM
I am:
  • Technically Challenged
Reviewed at:
Price: $204.95
2nd time was a charme
4.0
    Pros
  • Attractive Design
    Cons
  • None
    Best Uses
  • Smaller Rooms
"I wanted these speakers so I can duplicate in the kitchen whatever I'm listening to in the living room - radio, CDs, tapes,... Installation is a bit involved (quite a few wires for a "wireless system") but not hard. The first set of speakers I got simply stopped working right away (didn't receive FM …"  Read Full Review »
Feb 20 2009
Zap
Norfolk, VA
I am:
  • Musically Inclined
  • Tech Savvy
Reviewed at:
Price: $329.00
1.0
    Pros
  • Crisp Sound
    Cons
  • None
    Best Uses
  • None
The 2 speakers are remote, but not what I …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
May 27 2009
FERAL CHILD
SAN ANTONIO, TX
Reviewed at:
Price: $329.00
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
